[PATCH v1 5/5] testsuite: Add machine exception signal map test
Kinsey Moore
kinsey.moore at oarcorp.com
Mon Aug 23 23:50:45 UTC 2021
Add a test to verify that mapping of machine exceptions to POSIX signals
operates properly when the application requests it.
spec/build/testsuites/psxtests/grp.yml | 2 +
.../build/testsuites/psxtests/psxsignal09.yml | 22 ++++++
testsuites/psxtests/psxsignal09/init.c | 73 +++++++++++++++++++
.../psxtests/psxsignal09/psxsignal09.doc | 7 ++
.../psxtests/psxsignal09/psxsignal09.scn | 3 +
testsuites/psxtests/psxsignal09/system.h | 55 ++++++++++++++
6 files changed, 162 insertions(+)
create mode 100644 spec/build/testsuites/psxtests/psxsignal09.yml
create mode 100644 testsuites/psxtests/psxsignal09/init.c
create mode 100644 testsuites/psxtests/psxsignal09/psxsignal09.doc
create mode 100644 testsuites/psxtests/psxsignal09/psxsignal09.scn
create mode 100644 testsuites/psxtests/psxsignal09/system.h
diff --git a/spec/build/testsuites/psxtests/grp.yml b/spec/build/testsuites/psxtests/grp.yml
index fb7ce465ae..f61f45dbe9 100644
--- a/spec/build/testsuites/psxtests/grp.yml
+++ b/spec/build/testsuites/psxtests/grp.yml
@@ -205,6 +205,8 @@ links:
uid: psxsignal07
- role: build-dependency
uid: psxsignal08
+- role: build-dependency
+ uid: psxsignal09
uid: psxspin01
diff --git a/spec/build/testsuites/psxtests/psxsignal09.yml b/spec/build/testsuites/psxtests/psxsignal09.yml
new file mode 100644
index 0000000000..b09e2d62ce
--- /dev/null
+++ b/spec/build/testsuites/psxtests/psxsignal09.yml
@@ -0,0 +1,22 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2021 On-Line Applications Research (OAR)
+cppflags: []
+cxxflags: []
+enabled-by:
+- and:
+ - RTEMS_EXCEPTION_MANAGER
+ - RTEMS_POSIX_API
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/psxtests/psxsignal09/init.c
+stlib: []
+target: testsuites/psxtests/psxsignal09.exe
+type: build
+use-after: []
+use-before: []
diff --git a/testsuites/psxtests/psxsignal09/init.c b/testsuites/psxtests/psxsignal09/init.c
index 0000000000..12883cc28c
--- /dev/null
+++ b/testsuites/psxtests/psxsignal09/init.c
@@ -0,0 +1,73 @@
+ * @file
+ * @ingroup psxtests
+ * Copyright (C) 2021 On-Line Applications Research Corporation (OAR)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#define CONFIGURE_INIT
+#include "system.h"
+#include <signal.h>
+#include <errno.h>
+#include <reent.h>
+const char rtems_test_name[] = "PSXSIGNAL 9";
+static void Handler_1( int signo )
+ TEST_END();
+ rtems_test_exit(0);
+void *POSIX_Init( void *argument )
+ int status;
+ struct sigaction act;
+ TEST_BEGIN();
+ /* Hook signals that can be generated from machine exceptions */
+ act.sa_handler = Handler_1;
+ act.sa_flags = 0;
+ status = sigaction( SIGFPE, &act, NULL );
+ rtems_test_assert( !status );
+ status = sigaction( SIGILL, &act, NULL );
+ status = sigaction( SIGSEGV, &act, NULL );
+ /* Generate machine exception */
+ _CPU_Instruction_illegal();
+ return NULL;
diff --git a/testsuites/psxtests/psxsignal09/psxsignal09.doc b/testsuites/psxtests/psxsignal09/psxsignal09.doc
index 0000000000..5375ee6c20
--- /dev/null
+++ b/testsuites/psxtests/psxsignal09/psxsignal09.doc
@@ -0,0 +1,7 @@
+# COPYRIGHT (c) 2021.
+# On-Line Applications Research Corporation (OAR).
+# SPDX-License-Identifier: BSD-2-Clause
+This test ensures that machine exceptions are mapped to POSIX signals when
+required by the application.
diff --git a/testsuites/psxtests/psxsignal09/psxsignal09.scn b/testsuites/psxtests/psxsignal09/psxsignal09.scn
index 0000000000..b0d092a60c
--- /dev/null
+++ b/testsuites/psxtests/psxsignal09/psxsignal09.scn
@@ -0,0 +1,3 @@
+*** BEGIN OF TEST PSXSIGNAL 9 ***
+*** END OF TEST PSXSIGNAL 9 ***
diff --git a/testsuites/psxtests/psxsignal09/system.h b/testsuites/psxtests/psxsignal09/system.h
index 0000000000..9f83634b6d
--- /dev/null
+++ b/testsuites/psxtests/psxsignal09/system.h
@@ -0,0 +1,55 @@
+ * @file
+ * are met:
+#include <pmacros.h>
+void *POSIX_Init( void *argument );
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_EXCEPTION_TO_SIGNAL_MAPPING
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 1
+#define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS 1
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#define CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE \
+ (RTEMS_MINIMUM_STACK_SIZE * 4)
+#include <rtems/confdefs.h>
+/* end of include file */
2.20.1
