[PATCH] tester: Add MicroBlaze KCU105 QEMU BSP
Chris Johns
chrisj at rtems.org
Tue Aug 24 02:29:27 UTC 2021
Hi,
Could you please explain this file?
Where is the source?
Why would we allow a binay blob into the tester like this?
This seems specific to a set up or a BSP and not the tester. I am not
comfortable with this approach. Have alternative approaches have you considered?
On 24/8/21 4:46 am, Alex White wrote:
> tester/rtems/testing/bsps/kcu105.dtb | Bin 0 -> 15256 bytes
> tester/rtems/testing/bsps/kcu105_qemu.ini | 38 ++++++++++++++++++++++
> 2 files changed, 38 insertions(+)
> create mode 100644 tester/rtems/testing/bsps/kcu105.dtb
> create mode 100644 tester/rtems/testing/bsps/kcu105_qemu.ini
> diff --git a/tester/rtems/testing/bsps/kcu105.dtb b/tester/rtems/testing/bsps/kcu105.dtb
> new file mode 100644
> index 0000000000000000000000000000000000000000..998e8c03b74d8d9ddc82b5f6fa53242415abbd84
> GIT binary patch
> literal 15256
