[PATCH 0/1] v3: Implementation of Condclockwait and Test
Matt Joyce
mfjoyce2004 at gmail.com
Wed Aug 25 12:42:17 UTC 2021
Dr. Joel,
Please see my v3 attached for your review.
Major Changes:
1) Refactors condwaitsupp.c. Makes only one call to
set_timeout_argument(); gets clock from attributes then uses
that clock to make only one call to enqueue_with_timeout.
2) Defines CLOCK_NOT_SPECIFIED in condimpl.h, uses static assert
in condwaitsupp.c to ensure its value doesn't conflict with any
existing POSIX defined clocks. Uses this new value as a parameter
in condwait.c and condtimedwait.c
3) Removes all printf statements from psxcond03 test.
Standing by for any feedback...Thank you very much for your time!
Sincerely,
Matt
Matt Joyce (1):
Added implementation / tests for pthread_cond_clockwait()
cpukit/include/rtems/posix/condimpl.h | 9 +-
cpukit/posix/src/condclockwait.c | 78 +++
cpukit/posix/src/condtimedwait.c | 3 +-
cpukit/posix/src/condwait.c | 1 +
cpukit/posix/src/condwaitsupp.c | 108 +++-
spec/build/testsuites/psxtests/grp.yml | 2 +
spec/build/testsuites/psxtests/psxcond03.yml | 20 +
testsuites/psxtests/Makefile.am | 9 +
testsuites/psxtests/configure.ac | 1 +
testsuites/psxtests/psxcond03/init.c | 466 ++++++++++++++++++
testsuites/psxtests/psxcond03/psxcond03.doc | 44 ++
testsuites/psxtests/psxcond03/psxcond03.scn | 3 +
testsuites/psxtests/psxcond03/system.h | 61 +++
.../psxhdrs/pthread/pthread_cond_clockwait.c | 2 +-
14 files changed, 786 insertions(+), 21 deletions(-)
create mode 100644 cpukit/posix/src/condclockwait.c
create mode 100644 spec/build/testsuites/psxtests/psxcond03.yml
create mode 100644 testsuites/psxtests/psxcond03/init.c
create mode 100644 testsuites/psxtests/psxcond03/psxcond03.doc
create mode 100644 testsuites/psxtests/psxcond03/psxcond03.scn
create mode 100644 testsuites/psxtests/psxcond03/system.h
2.31.1
