[PATCH v1 1/1] gpiolib/grgpio: Add support for newer grgpio features
Daniel Hellstrom daniel at gaisler.com
Thu Aug 26 13:10:51 UTC 2021
Hi Jan,
I haven't tested the code, but it seems to be that the ordinary case
when GPIO[N] is connected to Interrupt[N] will not work? The fixup makes
GPIO[N] pin be associated with interrupt[0] (which is not available)
and  GPIO[1] with Interrupt[1] and so one which is the case with
U699/UT700/GR712RC. I believe it is the bus-driver's role to initialize
the device structure to indicate the device's all interrupts (the first
interrupt in the ambapp_bus case), and the driver's role to select which
interrupt of the available. I'm worrying that leaving "info.irq = -1"
will disable all interrupts from that GPIO core?
Kind Regards,
Daniel
On 2021-08-25 10:13, Jan.Sommer at dlr.de wrote:
> Does anyone have any objections to this?
> See also https://lists.rtems.org/pipermail/devel/2021-July/068086.html for the cover letter.
> Best regards,
>      Jan
>> -----Original Message-----
>> From: Sommer, Jan
>> Sent: Thursday, July 1, 2021 5:44 PM
>> To: devel at rtems.org
>> Cc: software at gaisler.com; Sommer, Jan <Jan.Sommer at dlr.de>
>> Subject: [PATCH v1 1/1] gpiolib/grgpio: Add support for newer grgpio
>> features
>> - Use proper typedef for isr (avoid warning in user application)
>> - Use set input enable register together with pin direction
>> - Support irqgen == 1 mode if present in capabilities register
>>   bsps/include/grlib/gpiolib.h          |  7 +++++--
>>   bsps/include/grlib/grlib.h            |  4 +++-
>>   bsps/shared/grlib/drvmgr/ambapp_bus.c |  5 +----
>>   bsps/shared/grlib/gpio/gpiolib.c      |  2 +-
>>   bsps/shared/grlib/gpio/grgpio.c       | 22 ++++++++++++++++------
>>   5 files changed, 26 insertions(+), 14 deletions(-)
>> diff --git a/bsps/include/grlib/gpiolib.h b/bsps/include/grlib/gpiolib.h index
>> f82d4fa2c2..37ac140862 100644
>> --- a/bsps/include/grlib/gpiolib.h
>> +++ b/bsps/include/grlib/gpiolib.h
>> @@ -28,6 +28,9 @@ struct gpiolib_config {  #define GPIOLIB_IRQ_POL_LOW
>> 0  #define GPIOLIB_IRQ_POL_HIGH 1
>> +/* Interrupt Service Routine (ISR) */
>> +typedef void (*gpiolib_isr)(void *arg);
>>   /* Libarary initialize function must be called befor any other */  extern int
>> gpiolib_initialize(void);
>> @@ -54,7 +57,7 @@ extern int gpiolib_irq_disable(void *handle);  extern int
>> gpiolib_irq_mask(void *handle);  extern int gpiolib_irq_unmask(void
>> *handle);  extern int gpiolib_irq_force(void *handle); -extern int
>> gpiolib_irq_register(void *handle, void *func, void *arg);
>> +extern int gpiolib_irq_register(void *handle, gpiolib_isr func, void
>> +*arg);
>>   /*** Driver Interface ***/
>> @@ -66,7 +69,7 @@ struct gpiolib_drv_ops {
>>   	int		(*config)(void *handle, struct gpiolib_config *cfg);
>>   	int		(*get)(void *handle, int *val);
>>   	int		(*irq_opts)(void *handle, unsigned int options);
>> -	int		(*irq_register)(void *handle, void *func, void *arg);
>> +	int		(*irq_register)(void *handle, gpiolib_isr func, void
>> *arg);
>>   	int		(*open)(void *handle);
>>   	int		(*set)(void *handle, int dir, int outval);
>>   	int		(*show)(void *handle);
>> diff --git a/bsps/include/grlib/grlib.h b/bsps/include/grlib/grlib.h index
>> 49d9999807..4aa3e9df4a 100644
>> --- a/bsps/include/grlib/grlib.h
>> +++ b/bsps/include/grlib/grlib.h
>> @@ -17,6 +17,7 @@
>>   #define __GRLIB_H__
>>   #include <stdbool.h>
>> +#include <bsp/utility.h>
>>   #ifdef __cplusplus
>>   extern "C" {
>> @@ -125,6 +126,7 @@ struct grgpio_regs {
>>     volatile unsigned int iedge;       /* 0x14 Interrupt edge register */
>>     volatile unsigned int bypass;      /* 0x18 Bypass register */
>>     volatile unsigned int cap;         /* 0x1C Capability register */
>> +#define GRGPIO_CAP_IRQGEN(reg) BSP_FLD32GET(reg, 8, 12)
>>     volatile unsigned int irqmap[4];   /* 0x20 - 0x2C Interrupt map registers */
>>     volatile unsigned int res_30;      /* 0x30 Reserved */
>>     volatile unsigned int res_34;      /* 0x34 Reserved */
>> @@ -132,7 +134,7 @@ struct grgpio_regs {
>>     volatile unsigned int res_3C;      /* 0x3C Reserved */
>>     volatile unsigned int iavail;      /* 0x40 Interrupt available register */
>>     volatile unsigned int iflag;       /* 0x44 Interrupt flag register */
>> -  volatile unsigned int res_48;      /* 0x48 Reserved */
>> +  volatile unsigned int input_en;    /* 0x48 Input enable (if present) */
>>     volatile unsigned int pulse;       /* 0x4C Pulse register */
>>     volatile unsigned int res_50;      /* 0x50 Reserved */
>>     volatile unsigned int output_or;   /* 0x54 I/O port output register, logical-OR
>> diff --git a/bsps/shared/grlib/drvmgr/ambapp_bus.c
>> b/bsps/shared/grlib/drvmgr/ambapp_bus.c
>> index 3c38fc16e0..0aed29224c 100644
>> --- a/bsps/shared/grlib/drvmgr/ambapp_bus.c
>> +++ b/bsps/shared/grlib/drvmgr/ambapp_bus.c
>> @@ -521,11 +521,8 @@ static int ambapp_dev_fixup(struct drvmgr_dev
>> *dev, struct amba_dev_info *pnp)
>>   		for(core = 0; core < subcores; core++)
>>   			drvmgr_dev_register(devs_to_register[core]);
>>   		return 1;
>> -	} else if ( (pnp->info.device == GAISLER_GPIO) &&
>> -		    (pnp->info.vendor == VENDOR_GAISLER) ) {
>> -		/* PIO[N] is connected to IRQ[N]. */
>> -		pnp->info.irq = 0;
>>   	return 0;
>> diff --git a/bsps/shared/grlib/gpio/gpiolib.c
>> b/bsps/shared/grlib/gpio/gpiolib.c
>> index cf0038c5bb..0cb76402cc 100644
>> --- a/bsps/shared/grlib/gpio/gpiolib.c
>> +++ b/bsps/shared/grlib/gpio/gpiolib.c
>> @@ -201,7 +201,7 @@ int gpiolib_get(void *handle, int *inval)  }
>>   /*** IRQ Functions ***/
>> -int gpiolib_irq_register(void *handle, void *func, void *arg)
>> +int gpiolib_irq_register(void *handle, gpiolib_isr func, void *arg)
>>   	struct gpiolib_port *port = handle;
>> diff --git a/bsps/shared/grlib/gpio/grgpio.c b/bsps/shared/grlib/gpio/grgpio.c
>> index 05504ef020..5bce5f530a 100644
>> --- a/bsps/shared/grlib/gpio/grgpio.c
>> +++ b/bsps/shared/grlib/gpio/grgpio.c
>> @@ -229,6 +229,7 @@ static int grgpio_grpiolib_irq_opts(void *handle,
>> unsigned int options)  {
>>   	struct grgpio_priv *priv;
>>   	int portnr;
>> +	int irq;
>>   	drvmgr_isr isr;
>>   	void *arg;
>> @@ -244,33 +245,41 @@ static int grgpio_grpiolib_irq_opts(void *handle,
>>   	isr = priv->isrs[portnr].isr;
>>   	arg = priv->isrs[portnr].arg;
>> +	/* For irqgen == 1, irq == pirq, i.e. no offset */
>> +	irq = 0;
>> +	if (GRGPIO_CAP_IRQGEN(priv->regs->cap) == 0) {
>> +		/* For irqgen == 0, irq == pirq + portnr */
>> +		irq += portnr;
>> +	/* FIXME: irqgen > 1 currently not supported */
>>   	if ( options & GPIOLIB_IRQ_DISABLE ) {
>>   		/* Disable interrupt at interrupt controller */
>> -		if ( drvmgr_interrupt_unregister(priv->dev, portnr, isr, arg) ) {
>> +		if ( drvmgr_interrupt_unregister(priv->dev, irq, isr, arg) ) {
>>   			return -1;
>>   	if ( options & GPIOLIB_IRQ_CLEAR ) {
>>   		/* Clear interrupt at interrupt controller */
>> -		if ( drvmgr_interrupt_clear(priv->dev, portnr) ) {
>> +		if ( drvmgr_interrupt_clear(priv->dev, irq) ) {
>>   			return -1;
>>   	if ( options & GPIOLIB_IRQ_ENABLE ) {
>>   		/* Enable interrupt at interrupt controller */
>> -		if ( drvmgr_interrupt_register(priv->dev, portnr, "grgpio", isr,
>> arg) ) {
>> +		if ( drvmgr_interrupt_register(priv->dev, irq, "grgpio", isr,
>> arg) )
>>   			return -1;
>>   	if ( options & GPIOLIB_IRQ_MASK ) {
>>   		/* Mask (disable) interrupt at interrupt controller */
>> -		if ( drvmgr_interrupt_mask(priv->dev, portnr) ) {
>> +		if ( drvmgr_interrupt_mask(priv->dev, irq) ) {
>>   			return -1;
>>   	if ( options & GPIOLIB_IRQ_UNMASK ) {
>>   		/* Unmask (enable) interrupt at interrupt controller */
>> -		if ( drvmgr_interrupt_unmask(priv->dev, portnr) ) {
>> +		if ( drvmgr_interrupt_unmask(priv->dev, irq) ) {
>>   			return -1;
>> @@ -278,7 +287,7 @@ static int grgpio_grpiolib_irq_opts(void *handle,
>>   	return 0;
>> -static int grgpio_grpiolib_irq_register(void *handle, void *func, void *arg)
>> +static int grgpio_grpiolib_irq_register(void *handle, gpiolib_isr func,
>> +void *arg)
>>   	int portnr;
>> @@ -313,6 +322,7 @@ static int grgpio_grpiolib_set(void *handle, int dir, int
>> outval)
>>   	/* Set Direction and Output */
>>   	mask = 1<<portnr;
>>   	priv->regs->dir = (priv->regs->dir & ~mask) | (dir ? mask : 0);
>> +	priv->regs->input_en = (priv->regs->input_en & ~mask) | (dir ? 0 :
>> +mask);
>>   	priv->regs->output = (priv->regs->output & ~mask) | (outval ? mask :
>> 0);
>>   	return 0;
>> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210826/09480e4a/attachment.html>
