[PATCH] tester: Limit simultaneous QEMU jobs to 1
Tue Aug 31 08:30:52 UTC 2021
On 31/08/2021 09:00, Chris Johns wrote:
> On 31/8/21 3:20 pm, Sebastian Huber wrote:
>> On 30/08/2021 20:32, Kinsey Moore wrote:
>>> On 8/30/2021 12:12, Sebastian Huber wrote:
>>>> On 24/08/2021 20:45, Kinsey Moore wrote:
>>>>> diff --git a/tester/rtems/testing/bsps/a53_ilp32_qemu.ini
>>>>> b/tester/rtems/testing/bsps/a53_ilp32_qemu.ini
>>>>> index 3beba06..581c59c 100644
>>>>> --- a/tester/rtems/testing/bsps/a53_ilp32_qemu.ini
>>>>> +++ b/tester/rtems/testing/bsps/a53_ilp32_qemu.ini
>>>>> @@ -36,3 +36,4 @@ bsp           = a53_ilp32_qemu
>>>>>    arch          = aarch64
>>>>>    tester        = %{_rtscripts}/qemu.cfg
>>>>>    bsp_qemu_opts = %{qemu_opts_base} -serial mon:stdio -machine
>>>>> virt,gic-version=3 -cpu cortex-a53 -m 4096
>>>>> +jobs          = 1
>>>> Does this overwrite the command line option or is this a default value?
>>> When this is set in the tester configuration, the command line switch has no
>>> effect but it can be overridden in the user-config.
>> Overruling the command line option is not that great. I have a vastly different
>> test run duration with --jobs=1 vs. --jobs=48 with more or less the same test
>> results.
> What does more or less mean?
On Qemu some tests have no reliable outcome. If I run with --jobs=48
only two of these tests fail compare to --jobs=1.
> I appreciate the efforts Kinsey has gone to looking into why we have this
> happening and I also believe we need to keep pushing towards repeatable result.
> If limiting to 1 gives us repeatable results on qemu then I prefer this over
> tainted test results with intermittent tags.
During development waiting one minute is much better than waiting 13
minutes. Repeatable tests is one aspect, but there are other aspects
too. Overruling command line options is not that great. If you run with
default values, it is all right to trade off repeatable results against
a fast test run. However, if I want to run with --jobs=N, I want to run
with N jobs and not just one.
>> I think this option should be split into a "force-jobs" and
>> "default-jobs" option.
> I am sorry I do not understand these options?
force-jobs forces the jobs to N regardless of what is specified on the
command line. Maybe a warning or error should be emitted if the command
line option conflicts with the configuration option.
default-jobs selects the job count if no --jobs command line option is
specified.
> The command line is ignored because and the value is fixed on purpose and I am
> not seeing a reason to change this.
Ignoring command line options is not really a pleasant user experience.
> When specified in a config it is a physical limit. A user being able to change
> the number of TFTP jobs on the command line does not make sense.
Yes, for physical limits this makes sense.
> This tool's focus is testing on hardware and I see that as more important. And
> as I have said before if we have problematic tests maybe the test or the tool
> generating the results needs to be investigated.
> I see this issue as something specific to the design of qemu and a few of our
> tests. I can guess at some of the reasons qemu does this but also being able to
> have the tick timer's clock be sync'ed with the CPU clock is important in some
> types of simulation, ie our case and these problematic test. We are a real-time
> operating system so needing this to be right to closer in simulation does not
> seem unreasonable.
> This discussion send a clear message, tier 1 archs and BSPs are very important
> to this project.
There are several ways to address the sporadic test failures on Qemu.
You could for example also change the tests to make them independent of
the simulator timing. For now, my approach would be to change the
default jobs count for the Qemu BSPs and still let the user overrule the
default with a custom value to get for example a faster test run.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
