[PATCH 2/5] score: Fix blocking message queue receive
Sebastian Huber
Tue Aug 31 11:24:22 UTC 2021
In order to ensure FIFO fairness across schedulers, the thread queue
surrender operation must be used to dequeue a thread from the thread
queue. The thread queue extract operation is intended for timeouts.
Add _Thread_queue_Resume() which may be used to make extracted or
surrendered threads ready again.
Remove the now unused _Thread_queue_Extract_critical() function.
Close #4509.
cpukit/include/rtems/score/coremsgimpl.h | 20 ++++----
cpukit/include/rtems/score/threadqimpl.h | 59 ++++++------------------
cpukit/score/src/coremsgseize.c | 20 ++++----
cpukit/score/src/threadqenqueue.c | 45 ++++++++++--------
4 files changed, 62 insertions(+), 82 deletions(-)
diff --git a/cpukit/include/rtems/score/coremsgimpl.h b/cpukit/include/rtems/score/coremsgimpl.h
index 161cf8f124..7f01769010 100644
--- a/cpukit/include/rtems/score/coremsgimpl.h
+++ b/cpukit/include/rtems/score/coremsgimpl.h
@@ -616,7 +616,8 @@ RTEMS_INLINE_ROUTINE Thread_Control *_CORE_message_queue_Dequeue_receiver(
Thread_queue_Context *queue_context
- Thread_Control *the_thread;
+ Thread_queue_Heads *heads;
+ Thread_Control *the_thread;
* If there are pending messages, then there can't be threads
@@ -634,14 +635,18 @@ RTEMS_INLINE_ROUTINE Thread_Control *_CORE_message_queue_Dequeue_receiver(
* There must be no pending messages if there is a thread waiting to
* receive a message.
- the_thread = _Thread_queue_First_locked(
- &the_message_queue->Wait_queue,
- the_message_queue->operations
- if ( the_thread == NULL ) {
+ heads = the_message_queue->Wait_queue.Queue.heads;
+ if ( heads == NULL ) {
return NULL;
+ the_thread = ( *the_message_queue->operations->surrender )(
+ &the_message_queue->Wait_queue.Queue,
+ heads,
+ NULL,
+ queue_context
*(size_t *) the_thread->Wait.return_argument = size;
the_thread->Wait.count = (uint32_t) submit_type;
@@ -651,9 +656,8 @@ RTEMS_INLINE_ROUTINE Thread_Control *_CORE_message_queue_Dequeue_receiver(
size
- _Thread_queue_Extract_critical(
+ _Thread_queue_Resume(
- the_message_queue->operations,
the_thread,
queue_context
diff --git a/cpukit/include/rtems/score/threadqimpl.h b/cpukit/include/rtems/score/threadqimpl.h
index 2465fc4499..0a24d2da3b 100644
--- a/cpukit/include/rtems/score/threadqimpl.h
+++ b/cpukit/include/rtems/score/threadqimpl.h
@@ -975,56 +975,23 @@ void _Thread_queue_Unblock_critical(
- * @brief Extracts the thread from the thread queue and unblocks it.
+ * @brief Resumes the extracted or surrendered thread.
- * The caller must be the owner of the thread queue lock. This function will
- * release the thread queue lock and restore the default thread lock. Thread
- * dispatching is disabled before the thread queue lock is released and an
- * unblock is necessary. Thread dispatching is enabled once the sequence to
- * unblock the thread is complete. This makes it possible to use the thread
- * queue lock to protect the state of objects embedding the thread queue and
- * directly enter _Thread_queue_Extract_critical() to finalize an operation in
- * case a waiting thread exists.
- * @code
- * #include <rtems/score/threadqimpl.h>
- * typedef struct {
- * Thread_queue_Control Queue;
- * Thread_Control *owner;
- * } Mutex;
+ * This function makes the thread ready again. If necessary, the thread is
+ * unblocked and its thread timer removed.
- * void _Mutex_Release( Mutex *mutex )
- * Thread_queue_Context queue_context;
- * Thread_Control *first;
- * _Thread_queue_Context_initialize( &queue_context, NULL );
- * _Thread_queue_Acquire( &mutex->Queue, queue_context );
- * first = _Thread_queue_First_locked( &mutex->Queue );
- * mutex->owner = first;
- * if ( first != NULL ) {
- * _Thread_queue_Extract_critical(
- * &mutex->Queue.Queue,
- * mutex->Queue.operations,
- * first,
- * &queue_context
- * @endcode
+ * The thread shall have been extracted from the thread queue or surrendered by
+ * the thread queue right before the call to this function. The caller shall
+ * be the owner of the thread queue lock.
- * @param queue The actual thread queue.
- * @param operations The thread queue operations.
- * @param[in, out] the_thread The thread to extract.
- * @param[in, out] queue_context The thread queue context of the lock acquire.
+ * @param queue is the actual thread queue.
+ * @param[in, out] the_thread is the thread to make ready and unblock.
+ * @param[in, out] queue_context is the thread queue context.
-void _Thread_queue_Extract_critical(
- Thread_queue_Queue *queue,
- const Thread_queue_Operations *operations,
- Thread_Control *the_thread,
- Thread_queue_Context *queue_context
+void _Thread_queue_Resume(
+ Thread_queue_Queue *queue,
+ Thread_Control *the_thread,
+ Thread_queue_Context *queue_context
diff --git a/cpukit/score/src/coremsgseize.c b/cpukit/score/src/coremsgseize.c
index e44538ee17..148e9dbb3c 100644
--- a/cpukit/score/src/coremsgseize.c
+++ b/cpukit/score/src/coremsgseize.c
@@ -56,7 +56,8 @@ Status_Control _CORE_message_queue_Seize(
return STATUS_SUCCESSFUL;
#else
* There could be a thread waiting to send a message. If there
@@ -65,11 +66,8 @@ Status_Control _CORE_message_queue_Seize(
* NOTE: If we note that the queue was not full before this receive,
* then we can avoid this dequeue.
_CORE_message_queue_Free_message_buffer(
the_message_queue,
the_message
@@ -78,6 +76,13 @@ Status_Control _CORE_message_queue_Seize(
+ heads,
+ NULL,
+ queue_context
* There was a thread waiting to send a message. This code
* puts the messages in the message queue on behalf of the
@@ -90,9 +95,8 @@ Status_Control _CORE_message_queue_Seize(
(size_t) the_thread->Wait.option,
(CORE_message_queue_Submit_types) the_thread->Wait.count
the_thread,
queue_context
diff --git a/cpukit/score/src/threadqenqueue.c b/cpukit/score/src/threadqenqueue.c
index d165e30da7..833d37ee61 100644
--- a/cpukit/score/src/threadqenqueue.c
+++ b/cpukit/score/src/threadqenqueue.c
@@ -7,9 +7,10 @@
* _Thread_queue_Deadlock_fatal(), _Thread_queue_Deadlock_status(),
* _Thread_queue_Do_dequeue(), _Thread_queue_Enqueue(),
* _Thread_queue_Enqueue_do_nothing_extra(), _Thread_queue_Enqueue_sticky(),
- * _Thread_queue_Extract(), _Thread_queue_Extract_critical(),
- * _Thread_queue_Extract_locked(), _Thread_queue_Path_acquire_critical(),
- * _Thread_queue_Path_release_critical(), _Thread_queue_Surrender(),
+ * _Thread_queue_Extract(), _Thread_queue_Extract_locked(),
+ * _Thread_queue_Path_acquire_critical(),
+ * _Thread_queue_Path_release_critical(),
+ * _Thread_queue_Resume(),_Thread_queue_Surrender(),
* _Thread_queue_Surrender_sticky(), and _Thread_queue_Unblock_critical().
@@ -604,28 +605,32 @@ void _Thread_queue_Unblock_critical(
bool unblock;
- unblock = _Thread_queue_Extract_locked(
- queue,
- operations,
- the_thread,
- queue_context
+ unblock = _Thread_queue_Make_ready_again( the_thread );
- _Thread_queue_Unblock_critical(
- unblock,
- queue,
- the_thread,
- &queue_context->Lock_context.Lock_context
+ if ( unblock ) {
+ Per_CPU_Control *cpu_self;
+ cpu_self = _Thread_queue_Dispatch_disable( queue_context );
+ _Thread_queue_Queue_release(
+ queue, &queue_context->Lock_context.Lock_context
+ _Thread_Remove_timer_and_unblock( the_thread, queue );
+ _Thread_Dispatch_enable( cpu_self );
+ } else {
void _Thread_queue_Extract( Thread_Control *the_thread )
2.26.2
