[PATCH] rtems: Move all Interrupt Manager stuff to intr.h
Thu Dec 2 14:12:18 UTC 2021
Since the previous Interrupt Manager Extension API moved to the
Interrupt Manager, we can move the interfaces to <rtems/rtems/intr.h> so
that they are available via #include <rtems.h>.
 cpukit/include/rtems/irq-extension.h | 2257 +-----------------------
 cpukit/include/rtems/rtems/intr.h    | 2375 +++++++++++++++++++++++++-
 2 files changed, 2315 insertions(+), 2317 deletions(-)
diff --git a/cpukit/include/rtems/irq-extension.h b/cpukit/include/rtems/irq-extension.h
index e45ea43004..76b930dc69 100644
--- a/cpukit/include/rtems/irq-extension.h
+++ b/cpukit/include/rtems/irq-extension.h
@@ -5,11 +5,11 @@
  * @ingroup RTEMSAPIClassicIntr
- * @brief This header file defines the Interrupt Manager Extension API.
+ * @brief This header file is provided for backward compatiblility.
- * Copyright (C) 2008, 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
  * modification, are permitted provided that the following conditions
@@ -55,2265 +55,12 @@
 #ifndef _RTEMS_IRQ_EXTENSION_H
 #define _RTEMS_IRQ_EXTENSION_H
-#include <stddef.h>
-#include <stdint.h>
-#include <sys/cpuset.h>
-#include <rtems/rtems/attr.h>
 #include <rtems/rtems/intr.h>
-#include <rtems/rtems/modes.h>
-#include <rtems/rtems/options.h>
-#include <rtems/rtems/status.h>
-#include <rtems/rtems/types.h>
-#include <rtems/score/chain.h>
 #ifdef __cplusplus
 extern "C" {
 #endif
-/* Generated from spec:/rtems/intr/if/handler */
- * @ingroup RTEMSAPIClassicIntr
- * @brief Interrupt handler routines shall have this type.
-typedef void ( *rtems_interrupt_handler )( void * );
-/* Generated from spec:/rtems/intr/if/per-handler-routine */
- * @brief Visitor routines invoked by rtems_interrupt_handler_iterate() shall
- *   have this type.
-typedef void ( *rtems_interrupt_per_handler_routine )(
-  void *,
-  const char *,
-  rtems_option,
-  rtems_interrupt_handler,
-  void *
-/* Generated from spec:/rtems/intr/if/shared */
- * @brief This interrupt handler install option allows that the interrupt
- *   handler may share the interrupt vector with other handler.
-#define RTEMS_INTERRUPT_SHARED ( (rtems_option) 0x00000000 )
-/* Generated from spec:/rtems/intr/if/unique */
- * @brief This interrupt handler install option ensures that the interrupt
- *   handler is unique.
- * This option prevents other handler from using the same interrupt vector.
-#define RTEMS_INTERRUPT_UNIQUE ( (rtems_option) 0x00000001 )
-/* Generated from spec:/rtems/intr/if/replace */
- * @brief This interrupt handler install option requests that the interrupt
- *   handler replaces the first handler with the same argument.
-#define RTEMS_INTERRUPT_REPLACE ( (rtems_option) 0x00000002 )
-/* Generated from spec:/rtems/intr/if/is-shared */
- * @brief Checks if the interrupt handler shared option is set.
- * @param _options is the interrupt handler option set to check.
- * @return Returns true, if the interrupt handler shared option
- *   #RTEMS_INTERRUPT_SHARED is set, otherwise false.
-#define RTEMS_INTERRUPT_IS_SHARED( _options ) \
-  ( ( _options ) & RTEMS_INTERRUPT_SHARED )
-/* Generated from spec:/rtems/intr/if/is-unique */
- * @brief Checks if the interrupt handler unique option is set.
- * @return Returns true, if the interrupt handler unique option
- *   #RTEMS_INTERRUPT_UNIQUE is set, otherwise false.
-#define RTEMS_INTERRUPT_IS_UNIQUE( _options ) \
-  ( ( _options ) & RTEMS_INTERRUPT_UNIQUE )
-/* Generated from spec:/rtems/intr/if/is-replace */
- * @brief Checks if the interrupt handler replace option is set.
- * @return Returns true, if the interrupt handler replace option
- *   #RTEMS_INTERRUPT_REPLACE is set, otherwise false.
-#define RTEMS_INTERRUPT_IS_REPLACE( _options ) \
-  ( ( _options ) & RTEMS_INTERRUPT_REPLACE )
-/* Generated from spec:/rtems/intr/if/entry */
- * @brief This structure represents an interrupt entry.
- * @par Notes
- * This structure shall be treated as an opaque data type from the API point of
- * view.  Members shall not be accessed directly.  An entry may be initialized
- * by RTEMS_INTERRUPT_ENTRY_INITIALIZER() or
- * rtems_interrupt_entry_initialize().  It may be installed for an interrupt
- * vector with rtems_interrupt_entry_install() and removed from an interrupt
- * vector by rtems_interrupt_entry_remove().
-typedef struct rtems_interrupt_entry {
-   * @brief This member is the interrupt handler routine.
-  rtems_interrupt_handler handler;
-   * @brief This member is the interrupt handler argument.
-  void *arg;
-   * @brief This member is the reference to the next entry or NULL.
-  struct rtems_interrupt_entry *next;
-   * @brief This member is the descriptive information of the entry.
-  const char *info;
-} rtems_interrupt_entry;
-/* Generated from spec:/rtems/intr/if/entry-initializer */
- * @brief Statically initializes an interrupt entry object.
- * @param _routine is the interrupt handler routine for the entry.
- * @param _arg is the interrupt handler argument for the entry.
- * @param _info is the descriptive information for the entry.
- * @par Notes
- * Alternatively, rtems_interrupt_entry_initialize() may be used to dynamically
- * initialize an interrupt entry.
-#define RTEMS_INTERRUPT_ENTRY_INITIALIZER( _routine, _arg, _info ) \
-  { _routine,  _arg, NULL, _info }
-/* Generated from spec:/rtems/intr/if/entry-initialize */
- * @brief Initializes the interrupt entry.
- * @param[out] entry is the interrupt entry to initialize.
- * @param routine is the interrupt handler routine for the entry.
- * @param arg is the interrupt handler argument for the entry.
- * @param info is the descriptive information for the entry.
- * @par Notes
- * Alternatively, RTEMS_INTERRUPT_ENTRY_INITIALIZER() may be used to statically
- * @par Constraints
- * @parblock
- * The following constraints apply to this directive:
- * * The directive may be called from within any runtime context.
- * * The directive will not cause the calling task to be preempted.
- * @endparblock
-static inline void rtems_interrupt_entry_initialize(
-  rtems_interrupt_entry  *entry,
-  rtems_interrupt_handler routine,
-  void                   *arg,
-  const char             *info
-  entry->handler = routine;
-  entry->arg = arg;
-  entry->next = NULL;
-  entry->info = info;
-/* Generated from spec:/rtems/intr/if/entry-install */
- * @brief Installs the interrupt entry at the interrupt vector.
- * @param vector is the interrupt vector number.
- * @param options is the interrupt entry install option set.
- * @param entry is the interrupt entry to install.
- * One of the following mutually exclusive options
- * * #RTEMS_INTERRUPT_UNIQUE, and
- * * #RTEMS_INTERRUPT_SHARED
- * shall be set in the ``options`` parameter.
- * The handler routine of the entry specified by ``entry`` will be called with
- * the handler argument of the entry when dispatched.  The order in which
- * shared interrupt handlers are dispatched for one vector is defined by the
- * installation order.  The first installed handler is dispatched first.
- * If the option #RTEMS_INTERRUPT_UNIQUE is set, then it will be ensured that
- * the handler will be the only one for the interrupt vector.
- * If the option #RTEMS_INTERRUPT_SHARED is set, then multiple handlers may be
- * installed for the interrupt vector.
- * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
- * @retval ::RTEMS_INVALID_ADDRESS The ``entry`` parameter was NULL.
- * @retval ::RTEMS_INCORRECT_STATE The service was not initialized.
- * @retval ::RTEMS_INVALID_ADDRESS The handler routine of the entry was NULL.
- * @retval ::RTEMS_INVALID_ID There was no interrupt vector associated with the
- *   number specified by ``vector``.
- * @retval ::RTEMS_CALLED_FROM_ISR The directive was called from within
- *   interrupt context.
- * @retval ::RTEMS_INVALID_NUMBER An option specified by ``options`` was not
- *   applicable.
- * @retval ::RTEMS_RESOURCE_IN_USE The #RTEMS_INTERRUPT_UNIQUE option was set
- *   in ``entry`` and the interrupt vector was already occupied by a handler.
- * @retval ::RTEMS_RESOURCE_IN_USE The #RTEMS_INTERRUPT_SHARED option was set
- *   in ``entry`` and the interrupt vector was already occupied by a unique
- *   handler.
- * @retval ::RTEMS_TOO_MANY The handler routine of the entry specified by
- *   ``entry`` was already installed for the interrupt vector specified by
- *   ``vector`` with an argument equal to the handler argument of the entry.
- * @par Notes
- * When the directive call was successful, the ownership of the interrupt entry
- * has been transferred from the caller to the interrupt service.  An installed
- * interrupt entry may be removed from the interrupt service by calling
- * rtems_interrupt_entry_remove().
- * @parblock
- * * The directive may be called from within device driver initialization
- *   context.
- * * The directive may be called from within task context.
- * * The directive may obtain and release the object allocator mutex.  This may
- *   cause the calling task to be preempted.
- * * The interrupt entry shall have been initialized by
- *   rtems_interrupt_entry_initialize() or RTEMS_INTERRUPT_ENTRY_INITIALIZER().
- * @endparblock
-rtems_status_code rtems_interrupt_entry_install(
-  rtems_vector_number    vector,
-  rtems_option           options,
-/* Generated from spec:/rtems/intr/if/entry-remove */
- * @brief Removes the interrupt entry from the interrupt vector.
- * @param entry is the interrupt entry to remove.
- * @retval ::RTEMS_UNSATISFIED The entry specified by ``entry`` was not
- *   installed at the interrupt vector specified by ``vector``.
- * @par Notes
- * has been transferred from the interrupt service to the caller.
- * @parblock
- *   context.
- * * The interrupt entry shall have been installed by
- *   rtems_interrupt_entry_install().
- * @endparblock
-rtems_status_code rtems_interrupt_entry_remove(
-/* Generated from spec:/rtems/intr/if/handler-install */
- * @brief Installs the interrupt handler routine and argument at the interrupt
- *   vector.
- * @param info is the descriptive information of the interrupt handler to
- *   install.
- * @param options is the interrupt handler install option set.
- * @param routine is the interrupt handler routine to install.
- * @param arg is the interrupt handler argument to install.
- * * #RTEMS_INTERRUPT_SHARED, and
- * * #RTEMS_INTERRUPT_REPLACE
- * The handler routine will be called with the argument specified by ``arg``
- * when dispatched.  The order in which shared interrupt handlers are
- * dispatched for one vector is defined by the installation order.  The first
- * installed handler is dispatched first.
- * If the option #RTEMS_INTERRUPT_SHARED is set, then multiple handler may be
- * If the option #RTEMS_INTERRUPT_REPLACE is set, then the handler specified by
- * ``routine`` will replace the first handler with the same argument for the
- * interrupt vector if it exists, otherwise an error status will be returned.
- * A second handler with the same argument for the interrupt vector will remain
- * unchanged.  The new handler will inherit the unique or shared options from
- * the replaced handler.
- * An informative description may be provided in ``info``.  It may be used for
- * system debugging and diagnostic tools.  The referenced string has to be
- * persistent as long as the handler is installed.
- * @retval ::RTEMS_INVALID_ADDRESS The ``routine`` parameter was NULL.
- * @retval ::RTEMS_NO_MEMORY There was not enough memory available to allocate
- *   data structures to install the handler.
- *   in ``options`` and the interrupt vector was already occupied by a handler.
- *   in ``options`` and the interrupt vector was already occupied by a unique
- *   handler.
- * @retval ::RTEMS_TOO_MANY The handler specified by ``routine`` was already
- *   installed for the interrupt vector specified by ``vector`` with an
- *   argument equal to the argument specified by ``arg``.
- * @retval ::RTEMS_UNSATISFIED The #RTEMS_INTERRUPT_REPLACE option was set in
- *   ``options`` and no handler to replace was installed.
- * @parblock
- *   context.
- * @endparblock
-rtems_status_code rtems_interrupt_handler_install(
-  const char             *info,
-  void                   *arg
-/* Generated from spec:/rtems/intr/if/handler-remove */
- * @brief Removes the interrupt handler routine and argument from the interrupt
- *   vector.
- * @param routine is the interrupt handler routine to remove.
- * @param arg is the interrupt handler argument to remove.
- * @retval ::RTEMS_UNSATISFIED There was no handler routine and argument pair
- *   installed specified by ``routine`` and ``arg``.
- * @parblock
- *   context.
- * @endparblock
-rtems_status_code rtems_interrupt_handler_remove(
-  void                   *arg
-/* Generated from spec:/rtems/intr/if/vector-is-enabled */
- * @brief Checks if the interrupt vector is enabled.
- * @param[out] enabled is the pointer to a ``bool`` object.  When the directive
- *   call is successful, the enabled status of the interrupt associated with
- *   the interrupt vector specified by ``vector`` will be stored in this
- *   object.  When the interrupt was enabled for the processor executing the
- *   directive call at some time point during the call, the object value will
- *   be set to true, otherwise to false.
- * The directive checks if the interrupt associated with the interrupt vector
- * specified by ``vector`` was enabled for the processor executing the
- * directive call at some time point during the call.
- * @retval ::RTEMS_INVALID_ADDRESS The ``enabled`` parameter was NULL.
- * @par Notes
- * Interrupt vectors may be enabled by rtems_interrupt_vector_enable() and
- * disabled by rtems_interrupt_vector_disable().
- * @parblock
- * * The directive may be called from within interrupt context.
- *   context.
- * @endparblock
-rtems_status_code rtems_interrupt_vector_is_enabled(
-  bool               *enabled
-/* Generated from spec:/rtems/intr/if/vector-enable */
- * @brief Enables the interrupt vector.
- * @param vector is the number of the interrupt vector to enable.
- * The directive enables the interrupt vector specified by ``vector``. This
- * allows that interrupt service requests are issued to the target processors
- * of the interrupt vector.  Interrupt service requests for an interrupt vector
- * may be raised by rtems_interrupt_raise(), rtems_interrupt_raise_on(),
- * external signals, or messages.
- * @retval ::RTEMS_UNSATISFIED The request to enable the interrupt vector has
- *   not been satisfied.
- * @par Notes
- * The rtems_interrupt_get_attributes() directive may be used to check if an
- * interrupt vector can be enabled.  Interrupt vectors may be disabled by
- * rtems_interrupt_vector_disable().
- * @parblock
- *   context.
- * @endparblock
-rtems_status_code rtems_interrupt_vector_enable( rtems_vector_number vector );
-/* Generated from spec:/rtems/intr/if/vector-disable */
- * @brief Disables the interrupt vector.
- * @param vector is the number of the interrupt vector to disable.
- * The directive disables the interrupt vector specified by ``vector``.  This
- * prevents that an interrupt service request is issued to the target
- * processors of the interrupt vector.
- * @retval ::RTEMS_UNSATISFIED The request to disable the interrupt vector has
- * @par Notes
- * interrupt vector can be disabled.  Interrupt vectors may be enabled by
- * rtems_interrupt_vector_enable().  There may be targets on which some
- * interrupt vectors cannot be disabled, for example a hardware watchdog
- * interrupt or software generated interrupts.
- * @parblock
- *   context.
- * @endparblock
-rtems_status_code rtems_interrupt_vector_disable( rtems_vector_number vector );
-/* Generated from spec:/rtems/intr/if/is-pending */
- * @brief Checks if the interrupt is pending.
- * @param[out] pending is the pointer to a ``bool`` object.  When the directive
- *   call is successful, the pending status of the interrupt associated with
- *   object.  When the interrupt was pending for the processor executing the
- * specified by ``vector`` was pending for the processor executing the
- * @retval ::RTEMS_INVALID_ADDRESS The ``pending`` parameter was NULL.
- * @retval ::RTEMS_UNSATISFIED The request to get the pending status has not
- *   been satisfied.
- * @par Notes
- * Interrupts may be made pending by calling the rtems_interrupt_raise() or
- * rtems_interrupt_raise_on() directives or due to external signals or
- * messages.  The pending state may be cleared by rtems_interrupt_clear().
- * @parblock
- *   context.
- * @endparblock
-rtems_status_code rtems_interrupt_is_pending(
-  bool               *pending
-/* Generated from spec:/rtems/intr/if/get-affinity */
- * @brief Gets the processor affinity set of the interrupt vector.
- * @param affinity_size is the size of the processor set referenced by
- *   ``affinity`` in bytes.
- * @param[out] affinity is the pointer to a cpu_set_t object.  When the
- *   directive call is successful, the processor affinity set of the interrupt
- *   vector will be stored in this object.  A set bit in the processor set
- *   means that the corresponding processor is in the processor affinity set of
- *   the interrupt vector, otherwise the bit is cleared.
- * @retval ::RTEMS_INVALID_ADDRESS The ``affinity`` parameter was NULL.
- * @retval ::RTEMS_INVALID_SIZE The size specified by ``affinity_size`` of the
- *   processor set was too small for the processor affinity set of the
- *   interrupt vector.
- * @parblock
- *   context.
- * @endparblock
-rtems_status_code rtems_interrupt_get_affinity(
-  size_t              affinity_size,
-  cpu_set_t          *affinity
-/* Generated from spec:/rtems/intr/if/set-affinity */
- * @brief Sets the processor affinity set of the interrupt vector.
- * @param affinity is the pointer to a cpu_set_t object.  The processor set
- *   defines the new processor affinity set of the interrupt vector.  A set bit
- *   in the processor set means that the corresponding processor shall be in
- *   the processor affinity set of the interrupt vector, otherwise the bit
- *   shall be cleared.
- * @retval ::RTEMS_INVALID_NUMBER The referenced processor set was not a valid
- *   new processor affinity set for the interrupt vector.
- * @retval ::RTEMS_UNSATISFIED The request to set the processor affinity of the
- *   interrupt vector has not been satisfied.
- * @par Notes
- * The rtems_interrupt_get_attributes() directive may be used to check if the
- * processor affinity of an interrupt vector can be set.
- * @parblock
- *   context.
- * @endparblock
-rtems_status_code rtems_interrupt_set_affinity(
-  const cpu_set_t    *affinity
-/* Generated from spec:/rtems/intr/if/signal-variant */
- * @brief This enumeration provides interrupt trigger signal variants.
-typedef enum {
-   * @brief This interrupt signal variant indicates that the interrupt trigger
-   *   signal is unspecified.
-  RTEMS_INTERRUPT_UNSPECIFIED_SIGNAL,
-   * @brief This interrupt signal variant indicates that the interrupt cannot be
-   *   triggered by a signal.
-  RTEMS_INTERRUPT_NO_SIGNAL,
-   * @brief This interrupt signal variant indicates that the interrupt is
-   *   triggered by a low level signal.
-  RTEMS_INTERRUPT_SIGNAL_LEVEL_LOW,
-   *   triggered by a high level signal.
-  RTEMS_INTERRUPT_SIGNAL_LEVEL_HIGH,
-   *   triggered by a falling edge signal.
-  RTEMS_INTERRUPT_SIGNAL_EDGE_FALLING,
-   *   triggered by a raising edge signal.
-  RTEMS_INTERRUPT_SIGNAL_EDGE_RAISING
-} rtems_interrupt_signal_variant;
-/* Generated from spec:/rtems/intr/if/attributes */
- * @brief This structure provides the attributes of an interrupt vector.
- * The rtems_interrupt_get_attributes() directive may be used to obtain the
- * attributes of an interrupt vector.
-typedef struct {
-   * @brief This member is true, if the interrupt vector is maskable by
-   *   rtems_interrupt_local_disable(), otherwise it is false.
-   * Interrupt vectors which are not maskable by rtems_interrupt_local_disable()
-   * should be used with care since they cannot use most operating system
-   * services.
-  bool is_maskable;
-   * @brief This member is true, if the interrupt vector can be enabled by
-   *   rtems_interrupt_vector_enable(), otherwise it is false.
-   * When an interrupt vector can be enabled, this means that the enabled state
-   * can always be changed from disabled to enabled.  For an interrupt vector
-   * which can be enabled it follows that it may be enabled.
-  bool can_enable;
-   * @brief This member is true, if the interrupt vector may be enabled by
-   * When an interrupt vector may be enabled, this means that the enabled state
-   * may be changed from disabled to enabled.  The requested enabled state change
-   * should be checked by rtems_interrupt_vector_is_enabled().  Some interrupt
-   * vectors may be optionally available and cannot be enabled on a particular
-   * target.
-  bool maybe_enable;
-   * @brief This member is true, if the interrupt vector can be disabled by
-   *   rtems_interrupt_vector_disable(), otherwise it is false.
-   * When an interrupt vector can be disabled, this means that the enabled state
-   * can be changed from enabled to disabled.  For an interrupt vector which can
-   * be disabled it follows that it may be disabled.
-  bool can_disable;
-   * @brief This member is true, if the interrupt vector may be disabled by
-   * When an interrupt vector may be disabled, this means that the enabled state
-   * may be changed from enabled to disabled.  The requested enabled state change
-   * vectors may be always enabled and cannot be disabled on a particular target.
-  bool maybe_disable;
-   * @brief This member is true, if the interrupt vector can be raised by
-   *   rtems_interrupt_raise(), otherwise it is false.
-  bool can_raise;
-   * @brief This member is true, if the interrupt vector can be raised on a
-   *   processor by rtems_interrupt_raise_on(), otherwise it is false.
-  bool can_raise_on;
-   * @brief This member is true, if the interrupt vector can be cleared by
-   *   rtems_interrupt_clear(), otherwise it is false.
-  bool can_clear;
-   * @brief This member is true, if the pending status of the interrupt
-   *   associated with the interrupt vector is cleared by an interrupt
-   *   acknowledge from the processor, otherwise it is false.
-  bool cleared_by_acknowledge;
-   * @brief This member is true, if the affinity set of the interrupt vector can
-   *   be obtained by rtems_interrupt_get_affinity(), otherwise it is false.
-  bool can_get_affinity;
-   *   be set by rtems_interrupt_set_affinity(), otherwise it is false.
-  bool can_set_affinity;
-   * @brief This member is true, if the interrupt associated with the interrupt
-   *   vector can be triggered by a message.
-   * Interrupts may be also triggered by signals, rtems_interrupt_raise(), or
-   * rtems_interrupt_raise_on().  Examples for message triggered interrupts are
-   * the PCIe MSI/MSI-X and the ARM GICv3 Locality-specific Peripheral Interrupts
-   * (LPI).
-  bool can_be_triggered_by_message;
-   * @brief This member describes the trigger signal of the interrupt associated
-   *   with the interrupt vector.
-   * Interrupts are normally triggered by signals which indicate an interrupt
-   * request from a peripheral.  Interrupts may be also triggered by messages,
-   * rtems_interrupt_raise(), or rtems_interrupt_raise_on().
-  rtems_interrupt_signal_variant trigger_signal;
-} rtems_interrupt_attributes;
-/* Generated from spec:/rtems/intr/if/get-attributes */
- * @brief Gets the attributes of the interrupt vector.
- * @param[out] attributes is the pointer to an rtems_interrupt_attributes
- *   object.  When the directive call is successful, the attributes of the
- *   interrupt vector will be stored in this object.
- * @retval ::RTEMS_INVALID_ADDRESS The ``attributes`` parameter was NULL.
- * @parblock
- *   context.
- * @endparblock
-rtems_status_code rtems_interrupt_get_attributes(
-  rtems_interrupt_attributes *attributes
-/* Generated from spec:/rtems/intr/if/handler-iterate */
- * @brief Iterates over all interrupt handler installed at the interrupt
- *   vector.
- * @param routine is the visitor routine.
- * @param arg is the visitor argument.
- * For each installed handler at the interrupt vector the visitor function
- * specified by ``routine`` will be called with the argument specified by
- * ``arg`` and the handler information, options, routine and argument.
- * @par Notes
- * @parblock
- * The directive is intended for system information and diagnostics.
- * Never install or remove an interrupt handler within the visitor function.
- * This may result in a deadlock.
- * @endparblock
- * @parblock
- *   context.
- * @endparblock
-rtems_status_code rtems_interrupt_handler_iterate(
-  rtems_interrupt_per_handler_routine routine,
-  void                               *arg
-/* Generated from spec:/rtems/intr/if/server-default */
- * @brief The constant represents the index of the default interrupt server.
-#define RTEMS_INTERRUPT_SERVER_DEFAULT 0
-/* Generated from spec:/rtems/intr/if/server-control */
- * @brief This structure represents an interrupt server.
- * @par Notes
- * view.  Members shall not be accessed directly.  The structure is initialized
- * by rtems_interrupt_server_create() and maintained by the interrupt server
- * support.
-typedef struct rtems_interrupt_server_control {
-  #if defined(RTEMS_SMP)
-     * @brief This member is the ISR lock protecting the server control state.
-    rtems_interrupt_lock lock;
-  #endif
-   * @brief This member is the chain of pending interrupt entries.
-  Chain_Control entries;
-   * @brief This member is the identifier of the server task.
-  rtems_id server;
-   * @brief This member is the error count.
-  unsigned long errors;
-   * @brief This member is the server index.
-  uint32_t index;
-   * @brief This member is the node for the interrupt server registry.
-  Chain_Node node;
-   * @brief This member is the optional handler to destroy the interrupt server
-   *   control.
-  void ( *destroy )( struct rtems_interrupt_server_control * );
-} rtems_interrupt_server_control;
-/* Generated from spec:/rtems/intr/if/server-config */
- * @brief This structure defines an interrupt server configuration.
- * @par Notes
- * See also rtems_interrupt_server_create().
-typedef struct {
-   * @brief This member is the task name of the interrupt server.
-  rtems_name name;
-   * @brief This member is the initial task priority of the interrupt server.
-  rtems_task_priority priority;
-   * @brief This member is the task storage area of the interrupt server.
-   * It shall be NULL for interrupt servers created by
-   * rtems_interrupt_server_create().
-  void *storage_area;
-   * @brief This member is the task storage size of the interrupt server.
-   * For interrupt servers created by rtems_interrupt_server_create() this is the
-   * task stack size.
-  size_t storage_size;
-   * @brief This member is the initial mode set of the interrupt server.
-  rtems_mode modes;
-   * @brief This member is the attribute set of the interrupt server.
-  rtems_attribute attributes;
-   * @brief This member is an optional handler to destroy the interrupt server
-   *   control handed over to rtems_interrupt_server_create().
-   * The destroy handler is optional and may be NULL.  If the destroy handler is
-   * present, it is called from within the context of the interrupt server to be
-   * deleted, see also rtems_interrupt_server_delete().
-  void ( *destroy )( rtems_interrupt_server_control * );
-} rtems_interrupt_server_config;
-/* Generated from spec:/rtems/intr/if/server-initialize */
- * @brief Initializes the interrupt server tasks.
- * @param priority is the initial task priority of the created interrupt
- *   servers.
- * @param stack_size is the task stack size of the created interrupt servers.
- * @param modes is the initial mode set of the created interrupt servers.
- * @param attributes is the attribute set of the created interrupt servers.
- * @param[out] server_count is the pointer to an uint32_t object or NULL. When
- *   the pointer is not equal to NULL, the count of successfully created
- *   interrupt servers is stored in this object regardless of the return
- *   status.
- * The directive tries to create an interrupt server task for each online
- * processor in the system.  The tasks will have the initial priority specified
- * by ``priority``, the stack size specified by ``stack_size``, the initial
- * mode set specified by ``modes``, and the attribute set specified by
- * ``attributes``.  The count of successfully created server tasks will be
- * returned in ``server_count`` if the pointer is not equal to NULL.
- * @retval ::RTEMS_INCORRECT_STATE The interrupt servers were already
- *   initialized.
- * @return The directive uses rtems_task_create().  If this directive fails,
- *   then its error status will be returned.
- * @par Notes
- * @parblock
- * Interrupt handlers may be installed on an interrupt server with
- * rtems_interrupt_server_handler_install() and removed with
- * rtems_interrupt_server_handler_remove() using a server index.  In case of an
- * interrupt, the request will be forwarded to the interrupt server.  The
- * handlers are executed within the interrupt server context.  If one handler
- * blocks on something this may delay the processing of other handlers.
- * Interrupt servers may be deleted by rtems_interrupt_server_delete().
- * @endparblock
- * @parblock
- *   context.
- * @endparblock
-rtems_status_code rtems_interrupt_server_initialize(
-  rtems_task_priority priority,
-  size_t              stack_size,
-  rtems_mode          modes,
-  rtems_attribute     attributes,
-  uint32_t           *server_count
-/* Generated from spec:/rtems/intr/if/server-create */
- * @brief Creates an interrupt server.
- * @param[out] control is the pointer to an rtems_interrupt_server_control
- *   object.  When the directive call was successful, the ownership of the
- *   object was transferred from the caller of the directive to the interrupt
- *   server management.
- * @param config is the interrupt server configuration.
- * @param[out] server_index is the pointer to an uint32_t object.  When the
- *   directive call was successful, the index of the created interrupt server
- *   will be stored in this object.
- * @par Notes
- * See also rtems_interrupt_server_initialize() and
- * rtems_interrupt_server_delete().
- * @parblock
- *   context.
- * @endparblock
-rtems_status_code rtems_interrupt_server_create(
-  rtems_interrupt_server_control      *control,
-  const rtems_interrupt_server_config *config,
-  uint32_t                            *server_index
-/* Generated from spec:/rtems/intr/if/server-handler-install */
- *   vector on the interrupt server.
- * @param server_index is the interrupt server index.  The constant
- *   #RTEMS_INTERRUPT_SERVER_DEFAULT may be used to specify the default
- *   interrupt server.
- *   install.
- * The handler routine specified by ``routine`` will be executed within the
- * context of the interrupt server task specified by ``server_index``.
- * @retval ::RTEMS_INVALID_ID There was no interrupt server associated with the
- *   index specified by ``server_index``.
- * @retval ::RTEMS_INVALID_NUMBER An option specified by ``info`` was not
- *   applicable.
- *   in ``info`` and the interrupt vector was already occupied by a handler.
- *   in ``info`` and the interrupt vector was already occupied by a unique
- *   handler.
- *   ``info`` and no handler to replace was installed.
- * @par Notes
- * See also rtems_interrupt_handler_install().
- * @parblock
- *   context.
- * @endparblock
-rtems_status_code rtems_interrupt_server_handler_install(
-  uint32_t                server_index,
-  const char             *info,
-  void                   *arg
-/* Generated from spec:/rtems/intr/if/server-handler-remove */
- *   vector and the interrupt server.
- * @parblock
- * * The directive sends a request to another task and waits for a response.
- *   This may cause the calling task to be blocked and unblocked.
- * * The directive shall not be called from within the context of an interrupt
- *   server.  Calling the directive from within the context of an interrupt
- *   server is undefined behaviour.
- * @endparblock
-rtems_status_code rtems_interrupt_server_handler_remove(
-  void                   *arg
-/* Generated from spec:/rtems/intr/if/server-set-affinity */
- * @brief Sets the processor affinity of the interrupt server.
- *   defines the new processor affinity set of the interrupt server.  A set bit
- *   the processor affinity set of the task, otherwise the bit shall be
- *   cleared.
- * @param priority is the new real priority for the interrupt server.
- * @return The directive uses rtems_scheduler_ident_by_processor_set(),
- *   rtems_task_set_scheduler(), and rtems_task_set_affinity().  If one of
- *   these directive fails, then its error status will be returned.
- * @par Notes
- * @parblock
- * The scheduler is set determined by the highest numbered processor in the
- * affinity set specified by ``affinity``.
- * This operation is only reliable in case the interrupt server was suspended
- * via rtems_interrupt_server_suspend().
- * @endparblock
- * @parblock
- *   context.
- * * The directive may change the processor affinity of a task.  This may cause
- *   the calling task to be preempted.
- * * The directive may change the priority of a task.  This may cause the
- *   calling task to be preempted.
- * @endparblock
-rtems_status_code rtems_interrupt_server_set_affinity(
-  const cpu_set_t    *affinity,
-/* Generated from spec:/rtems/intr/if/server-delete */
- * @brief Deletes the interrupt server.
- * @param server_index is the index of the interrupt server to delete.
- *   server index specified by ``server_index``.
- * @par Notes
- * @parblock
- * The interrupt server deletes itself, so after the return of the directive
- * the interrupt server may be still in the termination process depending on
- * the task priorities of the system.
- * @endparblock
- * @parblock
- * @endparblock
-rtems_status_code rtems_interrupt_server_delete( uint32_t server_index );
-/* Generated from spec:/rtems/intr/if/server-suspend */
- * @brief Suspends the interrupt server.
- * @param server_index is the index of the interrupt server to suspend.  The
- *   constant #RTEMS_INTERRUPT_SERVER_DEFAULT may be used to specify the
- *   default interrupt server.
- * @par Notes
- * Interrupt server may be resumed by rtems_interrupt_server_resume().
- * @parblock
- * @endparblock
-rtems_status_code rtems_interrupt_server_suspend( uint32_t server_index );
-/* Generated from spec:/rtems/intr/if/server-resume */
- * @brief Resumes the interrupt server.
- * @param server_index is the index of the interrupt server to resume.  The
- * @par Notes
- * Interrupt server may be suspended by rtems_interrupt_server_suspend().
- * @parblock
- * @endparblock
-rtems_status_code rtems_interrupt_server_resume( uint32_t server_index );
-/* Generated from spec:/rtems/intr/if/server-move */
- * @brief Moves the interrupt handlers installed at the interrupt vector and
- *   the source interrupt server to the destination interrupt server.
- * @param source_server_index is the index of the source interrupt server.  The
- * @param destination_server_index is the index of the destination interrupt
- *   server.  The constant #RTEMS_INTERRUPT_SERVER_DEFAULT may be used to
- *   specify the default interrupt server.
- *   index specified by ``source_server_index``.
- *   index specified by ``destination_server_index``.
- * @parblock
- * @endparblock
-rtems_status_code rtems_interrupt_server_move(
-  uint32_t            source_server_index,
-  uint32_t            destination_server_index
-/* Generated from spec:/rtems/intr/if/server-handler-iterate */
- * @brief Iterates over all interrupt handler installed at the interrupt vector
- *   and interrupt server.
- * @param server_index is the index of the interrupt server.
- * For each installed handler at the interrupt vector and interrupt server the
- * visitor function specified by ``vector`` will be called with the argument
- * specified by ``routine`` and the handler information, options, routine and
- * argument.
- * @par Notes
- * @parblock
- * @endparblock
- * @parblock
- *   context.
- * @endparblock
-rtems_status_code rtems_interrupt_server_handler_iterate(
-  void                               *arg
-/* Generated from spec:/rtems/intr/if/server-action */
- * @brief This structure represents an interrupt server action.
- * @par Notes
-typedef struct rtems_interrupt_server_action {
-   * @brief This member is the reference to the next action or NULL.
-  struct rtems_interrupt_server_action *next;
-   * @brief This member is the interrupt handler.
-  void *arg;
-} rtems_interrupt_server_action;
-/* Generated from spec:/rtems/intr/if/server-entry */
- * @brief This structure represents an interrupt server entry.
- * @par Notes
- * view.  Members shall not be accessed directly.  An entry is initialized by
- * rtems_interrupt_server_entry_initialize() and destroyed by
- * rtems_interrupt_server_entry_destroy().  Interrupt server actions can be
- * prepended to the entry by rtems_interrupt_server_action_prepend().  The
- * entry is submitted to be serviced by rtems_interrupt_server_entry_submit().
-typedef struct {
-   * @brief This member is the node for the interrupt entry processing.
-  Chain_Node node;
-   * @brief This member references the interrupt server used to process the
-   *   entry.
-  rtems_interrupt_server_control *server;
-   * @brief This member is the interrupt vector number.
-  rtems_vector_number vector;
-   * @brief This member is the interrupt server actions list head.
-  rtems_interrupt_server_action *actions;
-} rtems_interrupt_server_entry;
-/* Generated from spec:/rtems/intr/if/server-entry-initialize */
- * @brief Initializes the interrupt server entry.
- * @param entry is the interrupt server entry to initialize.
- * @par Notes
- * After initialization, the list of actions of the interrupt server entry is
- * empty.  Actions may be prepended by rtems_interrupt_server_action_prepend().
- * Interrupt server entries may be moved to another interrupt vector with
- * rtems_interrupt_server_entry_move().  Server entries may be submitted to get
- * serviced by the interrupt server with rtems_interrupt_server_entry_submit().
- * Server entries may be destroyed by rtems_interrupt_server_entry_destroy().
- * @parblock
- *   context.
- * @endparblock
-rtems_status_code rtems_interrupt_server_entry_initialize(
-  rtems_interrupt_server_entry *entry
-/* Generated from spec:/rtems/intr/if/server-action-prepend */
- * @brief Prepends the interrupt server action to the list of actions of the
- *   interrupt server entry.
- * @param[in,out] entry is the interrupt server entry to prepend the interrupt
- *   server action.  It shall have been initialized via
- *   rtems_interrupt_server_entry_initialize().
- * @param[out] action is the interrupt server action to initialize and prepend
- *   to the list of actions of the entry.
- * @param routine is the interrupt handler routine to set in the action.
- * @param arg is the interrupt handler argument to set in the action.
- * @par Notes
- * No error checking is performed by the directive.
- * @parblock
- *   context.
- * * The interrupt server entry shall have been initialized by
- *   rtems_interrupt_server_entry_initialize() and further optional calls to
- *   rtems_interrupt_server_action_prepend().
- * * The directive shall not be called concurrently with
- *   rtems_interrupt_server_action_prepend() with the same interrupt server
- *   entry. Calling the directive under this condition is undefined behaviour.
- *   rtems_interrupt_server_entry_move() with the same interrupt server entry.
- *   Calling the directive under this condition is undefined behaviour.
- *   rtems_interrupt_server_entry_submit() with the same interrupt server
- * * The directive shall not be called while the interrupt server entry is
- *   pending on or serviced by its current interrupt server.  Calling the
- *   directive under these conditions is undefined behaviour.
- * @endparblock
-void rtems_interrupt_server_action_prepend(
-  rtems_interrupt_server_entry  *entry,
-  rtems_interrupt_server_action *action,
-  void                          *arg
-/* Generated from spec:/rtems/intr/if/server-entry-destroy */
- * @brief Destroys the interrupt server entry.
- * @param[in,out] entry is the interrupt server entry to destroy.
- * @par Notes
- * @parblock
- * @endparblock
-void rtems_interrupt_server_entry_destroy(
-/* Generated from spec:/rtems/intr/if/server-entry-submit */
- * @brief Submits the interrupt server entry to be serviced by the interrupt
- *   server.
- * @param entry is the interrupt server entry to submit.
- * The directive appends the entry to the pending entries of the interrupt
- * server.  The interrupt server is notified that a new entry is pending.  Once
- * the interrupt server is scheduled it services the actions of all pending
- * entries.
- * @par Notes
- * @parblock
- * This directive may be used to do a two-step interrupt processing.  The first
- * step is done from within interrupt context by a call to this directive.  The
- * second step is then done from within the context of the interrupt server.
- * A submitted entry may be destroyed by
- * @endparblock
- * @parblock
- *   context.
- * * The directive may unblock a task.  This may cause the calling task to be
- *   preempted.
- * @endparblock
-void rtems_interrupt_server_entry_submit(
-/* Generated from spec:/rtems/intr/if/server-entry-move */
- * @brief Moves the interrupt server entry to the interrupt server.
- * @param entry is the interrupt server entry to move.
- * @param server_index is the index of the destination interrupt server.  The
- * @parblock
- *   context.
- * @endparblock
-rtems_status_code rtems_interrupt_server_entry_move(
-/* Generated from spec:/rtems/intr/if/server-request */
- * @brief This structure represents an interrupt server request.
- * @par Notes
- * view.  Members shall not be accessed directly.  A request is initialized by
- * rtems_interrupt_server_request_initialize() and destroyed by
- * rtems_interrupt_server_request_destroy().  The interrupt vector of the
- * request can be set by rtems_interrupt_server_request_set_vector().  The
- * request is submitted to be serviced by
- * rtems_interrupt_server_request_submit().
-typedef struct {
-   * @brief This member is the interrupt server entry.
-  rtems_interrupt_server_entry entry;
-   * @brief This member is the interrupt server action.
-  rtems_interrupt_server_action action;
-} rtems_interrupt_server_request;
-/* Generated from spec:/rtems/intr/if/server-request-initialize */
- * @brief Initializes the interrupt server request.
- * @param[out] request is the interrupt server request to initialize.
- * @param routine is the interrupt handler routine for the request action.
- * @param arg is the interrupt handler argument for the request action.
- * @par Notes
- * An interrupt server requests consists of an interrupt server entry and
- * exactly one interrupt server action.  The interrupt vector of the request
- * may be changed with rtems_interrupt_server_request_set_vector().  Interrupt
- * server requests may be submitted to get serviced by the interrupt server
- * with rtems_interrupt_server_request_submit().  Requests may be destroyed by
- * @parblock
- *   context.
- * @endparblock
-rtems_status_code rtems_interrupt_server_request_initialize(
-  rtems_interrupt_server_request *request,
-  void                           *arg
-/* Generated from spec:/rtems/intr/if/server-request-set-vector */
- * @brief Sets the interrupt vector in the interrupt server request.
- * @param[in,out] request is the interrupt server request to change.
- * @param vector is the interrupt vector number to be used by the request.
- * @par Notes
- * @parblock
- * By default, the interrupt vector of an interrupt server request is set to a
- * special value which is outside the range of vectors supported by the
- * interrupt controller hardware.
- * Calls to rtems_interrupt_server_request_submit() will disable the interrupt
- * vector of the request.  After processing of the request by the interrupt
- * server the interrupt vector will be enabled again.
- * @endparblock
- * @parblock
- *   context.
- * * The interrupt server request shall have been initialized by
- *   rtems_interrupt_server_request_initialize().
- *   rtems_interrupt_server_request_set_vector() with the same interrupt server
- *   request.  Calling the directive under this condition is undefined
- *   behaviour.
- *   rtems_interrupt_server_request_submit() with the same interrupt server
- *   behaviour.
- * @endparblock
-static inline void rtems_interrupt_server_request_set_vector(
-  request->entry.vector = vector;
-/* Generated from spec:/rtems/intr/if/server-request-destroy */
- * @brief Destroys the interrupt server request.
- * @param[in,out] request is the interrupt server request to destroy.
- * @par Notes
- * @parblock
- * @endparblock
-static inline void rtems_interrupt_server_request_destroy(
-  rtems_interrupt_server_entry_destroy( &request->entry );
-/* Generated from spec:/rtems/intr/if/server-request-submit */
- * @brief Submits the interrupt server request to be serviced by the interrupt
- *   server.
- * @param[in,out] request is the interrupt server request to submit.
- * The directive appends the interrupt server entry of the request to the
- * pending entries of the interrupt server.  The interrupt server is notified
- * that a new entry is pending.  Once the interrupt server is scheduled it
- * services the actions of all pending entries.
- * @par Notes
- * @parblock
- * A submitted request may be destroyed by
- * @endparblock
- * @parblock
- *   context.
- *   preempted.
- *   behaviour.
- * @endparblock
-static inline void rtems_interrupt_server_request_submit(
-  rtems_interrupt_server_entry_submit( &request->entry );
 #ifdef __cplusplus
 #endif
diff --git a/cpukit/include/rtems/rtems/intr.h b/cpukit/include/rtems/rtems/intr.h
index 7663541adc..b99050e9ce 100644
--- a/cpukit/include/rtems/rtems/intr.h
+++ b/cpukit/include/rtems/rtems/intr.h
@@ -7,7 +7,7 @@
- * Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+ * Copyright (C) 2008, 2021 embedded brains GmbH (http://www.embedded-brains.de)
  * Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
@@ -54,9 +54,16 @@
 #ifndef _RTEMS_RTEMS_INTR_H
 #define _RTEMS_RTEMS_INTR_H
+#include <stddef.h>
 #include <stdint.h>
+#include <sys/cpuset.h>
+#include <rtems/rtems/attr.h>
+#include <rtems/rtems/modes.h>
+#include <rtems/rtems/options.h>
+#include <rtems/rtems/types.h>
+#include <rtems/score/chain.h>
 #include <rtems/score/cpu.h>
 #include <rtems/score/isr.h>
 #include <rtems/score/isrlevel.h>
@@ -82,6 +89,286 @@ extern "C" {
  *   task to be preempted upon exit from an ISR.
+/* Generated from spec:/rtems/intr/if/handler */
+ * @ingroup RTEMSAPIClassicIntr
+ * @brief Interrupt handler routines shall have this type.
+typedef void ( *rtems_interrupt_handler )( void * );
+/* Generated from spec:/rtems/intr/if/lock */
+ * @brief This structure represents an ISR lock.
+typedef ISR_lock_Control rtems_interrupt_lock;
+/* Generated from spec:/rtems/intr/if/per-handler-routine */
+ * @brief Visitor routines invoked by rtems_interrupt_handler_iterate() shall
+ *   have this type.
+typedef void ( *rtems_interrupt_per_handler_routine )(
+  void *,
+  const char *,
+  rtems_option,
+  rtems_interrupt_handler,
+  void *
+/* Generated from spec:/rtems/intr/if/vector-number */
+ * @brief This integer type represents interrupt vector numbers.
+typedef ISR_Vector_number rtems_vector_number;
+/* Generated from spec:/rtems/intr/if/shared */
+ * @brief This interrupt handler install option allows that the interrupt
+ *   handler may share the interrupt vector with other handler.
+#define RTEMS_INTERRUPT_SHARED ( (rtems_option) 0x00000000 )
+/* Generated from spec:/rtems/intr/if/unique */
+ * @brief This interrupt handler install option ensures that the interrupt
+ *   handler is unique.
+ * This option prevents other handler from using the same interrupt vector.
+#define RTEMS_INTERRUPT_UNIQUE ( (rtems_option) 0x00000001 )
+/* Generated from spec:/rtems/intr/if/replace */
+ * @brief This interrupt handler install option requests that the interrupt
+ *   handler replaces the first handler with the same argument.
+#define RTEMS_INTERRUPT_REPLACE ( (rtems_option) 0x00000002 )
+/* Generated from spec:/rtems/intr/if/entry */
+ * @brief This structure represents an interrupt entry.
+ * @par Notes
+ * This structure shall be treated as an opaque data type from the API point of
+ * view.  Members shall not be accessed directly.  An entry may be initialized
+ * by RTEMS_INTERRUPT_ENTRY_INITIALIZER() or
+ * rtems_interrupt_entry_initialize().  It may be installed for an interrupt
+ * vector with rtems_interrupt_entry_install() and removed from an interrupt
+ * vector by rtems_interrupt_entry_remove().
+typedef struct rtems_interrupt_entry {
+   * @brief This member is the interrupt handler routine.
+  rtems_interrupt_handler handler;
+   * @brief This member is the interrupt handler argument.
+  void *arg;
+   * @brief This member is the reference to the next entry or NULL.
+  struct rtems_interrupt_entry *next;
+   * @brief This member is the descriptive information of the entry.
+  const char *info;
+} rtems_interrupt_entry;
+/* Generated from spec:/rtems/intr/if/signal-variant */
+ * @brief This enumeration provides interrupt trigger signal variants.
+typedef enum {
+   * @brief This interrupt signal variant indicates that the interrupt trigger
+   *   signal is unspecified.
+  RTEMS_INTERRUPT_UNSPECIFIED_SIGNAL,
+   * @brief This interrupt signal variant indicates that the interrupt cannot be
+   *   triggered by a signal.
+  RTEMS_INTERRUPT_NO_SIGNAL,
+   * @brief This interrupt signal variant indicates that the interrupt is
+   *   triggered by a low level signal.
+  RTEMS_INTERRUPT_SIGNAL_LEVEL_LOW,
+   *   triggered by a high level signal.
+  RTEMS_INTERRUPT_SIGNAL_LEVEL_HIGH,
+   *   triggered by a falling edge signal.
+  RTEMS_INTERRUPT_SIGNAL_EDGE_FALLING,
+   *   triggered by a raising edge signal.
+  RTEMS_INTERRUPT_SIGNAL_EDGE_RAISING
+} rtems_interrupt_signal_variant;
+/* Generated from spec:/rtems/intr/if/attributes */
+ * @brief This structure provides the attributes of an interrupt vector.
+ * The rtems_interrupt_get_attributes() directive may be used to obtain the
+ * attributes of an interrupt vector.
+typedef struct {
+   * @brief This member is true, if the interrupt vector is maskable by
+   *   rtems_interrupt_local_disable(), otherwise it is false.
+   * Interrupt vectors which are not maskable by rtems_interrupt_local_disable()
+   * should be used with care since they cannot use most operating system
+   * services.
+  bool is_maskable;
+   * @brief This member is true, if the interrupt vector can be enabled by
+   *   rtems_interrupt_vector_enable(), otherwise it is false.
+   * When an interrupt vector can be enabled, this means that the enabled state
+   * can always be changed from disabled to enabled.  For an interrupt vector
+   * which can be enabled it follows that it may be enabled.
+  bool can_enable;
+   * @brief This member is true, if the interrupt vector may be enabled by
+   * When an interrupt vector may be enabled, this means that the enabled state
+   * may be changed from disabled to enabled.  The requested enabled state change
+   * should be checked by rtems_interrupt_vector_is_enabled().  Some interrupt
+   * vectors may be optionally available and cannot be enabled on a particular
+   * target.
+  bool maybe_enable;
+   * @brief This member is true, if the interrupt vector can be disabled by
+   *   rtems_interrupt_vector_disable(), otherwise it is false.
+   * When an interrupt vector can be disabled, this means that the enabled state
+   * can be changed from enabled to disabled.  For an interrupt vector which can
+   * be disabled it follows that it may be disabled.
+  bool can_disable;
+   * @brief This member is true, if the interrupt vector may be disabled by
+   * When an interrupt vector may be disabled, this means that the enabled state
+   * may be changed from enabled to disabled.  The requested enabled state change
+   * vectors may be always enabled and cannot be disabled on a particular target.
+  bool maybe_disable;
+   * @brief This member is true, if the interrupt vector can be raised by
+   *   rtems_interrupt_raise(), otherwise it is false.
+  bool can_raise;
+   * @brief This member is true, if the interrupt vector can be raised on a
+   *   processor by rtems_interrupt_raise_on(), otherwise it is false.
+  bool can_raise_on;
+   * @brief This member is true, if the interrupt vector can be cleared by
+   *   rtems_interrupt_clear(), otherwise it is false.
+  bool can_clear;
+   * @brief This member is true, if the pending status of the interrupt
+   *   associated with the interrupt vector is cleared by an interrupt
+   *   acknowledge from the processor, otherwise it is false.
+  bool cleared_by_acknowledge;
+   * @brief This member is true, if the affinity set of the interrupt vector can
+   *   be obtained by rtems_interrupt_get_affinity(), otherwise it is false.
+  bool can_get_affinity;
+   *   be set by rtems_interrupt_set_affinity(), otherwise it is false.
+  bool can_set_affinity;
+   * @brief This member is true, if the interrupt associated with the interrupt
+   *   vector can be triggered by a message.
+   * Interrupts may be also triggered by signals, rtems_interrupt_raise(), or
+   * rtems_interrupt_raise_on().  Examples for message triggered interrupts are
+   * the PCIe MSI/MSI-X and the ARM GICv3 Locality-specific Peripheral Interrupts
+   * (LPI).
+  bool can_be_triggered_by_message;
+   * @brief This member describes the trigger signal of the interrupt associated
+   *   with the interrupt vector.
+   * Interrupts are normally triggered by signals which indicate an interrupt
+   * request from a peripheral.  Interrupts may be also triggered by messages,
+   * rtems_interrupt_raise(), or rtems_interrupt_raise_on().
+  rtems_interrupt_signal_variant trigger_signal;
+} rtems_interrupt_attributes;
 /* Generated from spec:/rtems/intr/if/isr */
@@ -117,15 +404,6 @@ typedef ISR_Handler rtems_isr;
 typedef ISR_Level rtems_interrupt_level;
-/* Generated from spec:/rtems/intr/if/lock */
- * @brief This structure represents an ISR lock.
-typedef ISR_lock_Control rtems_interrupt_lock;
 /* Generated from spec:/rtems/intr/if/lock-context */
@@ -136,15 +414,6 @@ typedef ISR_lock_Control rtems_interrupt_lock;
 typedef ISR_lock_Context rtems_interrupt_lock_context;
-/* Generated from spec:/rtems/intr/if/vector-number */
- * @brief This integer type represents interrupt vector numbers.
-typedef ISR_Vector_number rtems_vector_number;
 /* Generated from spec:/rtems/intr/if/catch */
@@ -874,111 +1143,691 @@ rtems_status_code rtems_interrupt_catch(
 #define RTEMS_INTERRUPT_LOCK_REFERENCE( _designator, _target ) \
   ISR_LOCK_REFERENCE( _designator, _target )
-/* Generated from spec:/rtems/intr/if/raise */
+/* Generated from spec:/rtems/intr/if/is-shared */
+ * @brief Checks if the interrupt handler shared option is set.
+ * @param _options is the interrupt handler option set to check.
+ * @return Returns true, if the interrupt handler shared option
+ *   #RTEMS_INTERRUPT_SHARED is set, otherwise false.
+#define RTEMS_INTERRUPT_IS_SHARED( _options ) \
+  ( ( _options ) & RTEMS_INTERRUPT_SHARED )
+/* Generated from spec:/rtems/intr/if/is-unique */
+ * @brief Checks if the interrupt handler unique option is set.
+ * @return Returns true, if the interrupt handler unique option
+ *   #RTEMS_INTERRUPT_UNIQUE is set, otherwise false.
+#define RTEMS_INTERRUPT_IS_UNIQUE( _options ) \
+  ( ( _options ) & RTEMS_INTERRUPT_UNIQUE )
+/* Generated from spec:/rtems/intr/if/is-replace */
+ * @brief Checks if the interrupt handler replace option is set.
+ * @return Returns true, if the interrupt handler replace option
+ *   #RTEMS_INTERRUPT_REPLACE is set, otherwise false.
+#define RTEMS_INTERRUPT_IS_REPLACE( _options ) \
+  ( ( _options ) & RTEMS_INTERRUPT_REPLACE )
+/* Generated from spec:/rtems/intr/if/entry-initializer */
- * @brief Raises the interrupt vector.
+ * @brief Statically initializes an interrupt entry object.
- * @param vector is the number of the interrupt vector to raise.
+ * @param _routine is the interrupt handler routine for the entry.
+ * @param _arg is the interrupt handler argument for the entry.
+ * @param _info is the descriptive information for the entry.
- * @retval ::RTEMS_UNSATISFIED The request to raise the interrupt vector has
+ * @par Notes
+ * Alternatively, rtems_interrupt_entry_initialize() may be used to dynamically
+ * initialize an interrupt entry.
+#define RTEMS_INTERRUPT_ENTRY_INITIALIZER( _routine, _arg, _info ) \
+  { _routine,  _arg, NULL, _info }
+/* Generated from spec:/rtems/intr/if/entry-initialize */
+ * @brief Initializes the interrupt entry.
+ * @param[out] entry is the interrupt entry to initialize.
+ * @param routine is the interrupt handler routine for the entry.
+ * @param arg is the interrupt handler argument for the entry.
+ * @param info is the descriptive information for the entry.
  * @par Notes
- * interrupt vector can be raised.
+ * Alternatively, RTEMS_INTERRUPT_ENTRY_INITIALIZER() may be used to statically
  * @par Constraints
  * @parblock
- *   context.
+ * * The directive may be called from within any runtime context.
  * @endparblock
-rtems_status_code rtems_interrupt_raise( rtems_vector_number vector );
+static inline void rtems_interrupt_entry_initialize(
+  rtems_interrupt_entry  *entry,
+  rtems_interrupt_handler routine,
+  void                   *arg,
+  const char             *info
+  entry->handler = routine;
+  entry->arg = arg;
+  entry->next = NULL;
+  entry->info = info;
-/* Generated from spec:/rtems/intr/if/raise-on */
+/* Generated from spec:/rtems/intr/if/entry-install */
- * @brief Raises the interrupt vector on the processor.
+ * @brief Installs the interrupt entry at the interrupt vector.
+ * @param vector is the interrupt vector number.
- * @param cpu_index is the index of the target processor of the interrupt
- *   vector to raise.
+ * @param options is the interrupt entry install option set.
+ * @param entry is the interrupt entry to install.
+ * One of the following mutually exclusive options
+ * * #RTEMS_INTERRUPT_UNIQUE, and
+ * * #RTEMS_INTERRUPT_SHARED
+ * shall be set in the ``options`` parameter.
+ * The handler routine of the entry specified by ``entry`` will be called with
+ * the handler argument of the entry when dispatched.  The order in which
+ * shared interrupt handlers are dispatched for one vector is defined by the
+ * installation order.  The first installed handler is dispatched first.
+ * If the option #RTEMS_INTERRUPT_UNIQUE is set, then it will be ensured that
+ * the handler will be the only one for the interrupt vector.
+ * If the option #RTEMS_INTERRUPT_SHARED is set, then multiple handlers may be
+ * installed for the interrupt vector.
+ * @retval ::RTEMS_INVALID_ADDRESS The ``entry`` parameter was NULL.
+ * @retval ::RTEMS_INCORRECT_STATE The service was not initialized.
+ * @retval ::RTEMS_INVALID_ADDRESS The handler routine of the entry was NULL.
- * @retval ::RTEMS_NOT_CONFIGURED The processor specified by ``cpu_index`` was
- *   not configured to be used by the application.
+ * @retval ::RTEMS_CALLED_FROM_ISR The directive was called from within
+ *   interrupt context.
- * @retval ::RTEMS_INCORRECT_STATE The processor specified by ``cpu_index`` was
- *   configured to be used by the application, however, it was not online.
+ * @retval ::RTEMS_INVALID_NUMBER An option specified by ``options`` was not
+ *   applicable.
+ * @retval ::RTEMS_RESOURCE_IN_USE The #RTEMS_INTERRUPT_UNIQUE option was set
+ *   in ``entry`` and the interrupt vector was already occupied by a handler.
+ * @retval ::RTEMS_RESOURCE_IN_USE The #RTEMS_INTERRUPT_SHARED option was set
+ *   in ``entry`` and the interrupt vector was already occupied by a unique
+ *   handler.
+ * @retval ::RTEMS_TOO_MANY The handler routine of the entry specified by
+ *   ``entry`` was already installed for the interrupt vector specified by
+ *   ``vector`` with an argument equal to the handler argument of the entry.
  * @par Notes
- * interrupt vector can be raised on a processor.
+ * When the directive call was successful, the ownership of the interrupt entry
+ * has been transferred from the caller to the interrupt service.  An installed
+ * interrupt entry may be removed from the interrupt service by calling
+ * rtems_interrupt_entry_remove().
  * @par Constraints
  * @parblock
  *   context.
+ * * The directive may obtain and release the object allocator mutex.  This may
+ *   cause the calling task to be preempted.
+ * * The interrupt entry shall have been initialized by
+ *   rtems_interrupt_entry_initialize() or RTEMS_INTERRUPT_ENTRY_INITIALIZER().
  * @endparblock
-rtems_status_code rtems_interrupt_raise_on(
-  uint32_t            cpu_index
+rtems_status_code rtems_interrupt_entry_install(
+  rtems_vector_number    vector,
+  rtems_option           options,
-/* Generated from spec:/rtems/intr/if/clear */
+/* Generated from spec:/rtems/intr/if/entry-remove */
- * @brief Clears the interrupt vector.
+ * @brief Removes the interrupt entry from the interrupt vector.
- * @param vector is the number of the interrupt vector to clear.
+ * @param entry is the interrupt entry to remove.
+ * @retval ::RTEMS_UNSATISFIED The entry specified by ``entry`` was not
+ *   installed at the interrupt vector specified by ``vector``.
  * @par Notes
+ * has been transferred from the interrupt service to the caller.
+ * @par Constraints
+ * @parblock
+ * The following constraints apply to this directive:
+ * * The directive may be called from within device driver initialization
+ *   context.
+ * * The directive may be called from within task context.
+ * * The interrupt entry shall have been installed by
+ *   rtems_interrupt_entry_install().
+ * @endparblock
+rtems_status_code rtems_interrupt_entry_remove(
+/* Generated from spec:/rtems/intr/if/handler-install */
+ * @brief Installs the interrupt handler routine and argument at the interrupt
+ *   vector.
+ * @param info is the descriptive information of the interrupt handler to
+ *   install.
+ * @param options is the interrupt handler install option set.
+ * @param routine is the interrupt handler routine to install.
+ * @param arg is the interrupt handler argument to install.
+ * * #RTEMS_INTERRUPT_SHARED, and
+ * * #RTEMS_INTERRUPT_REPLACE
+ * The handler routine will be called with the argument specified by ``arg``
+ * when dispatched.  The order in which shared interrupt handlers are
+ * dispatched for one vector is defined by the installation order.  The first
+ * installed handler is dispatched first.
+ * If the option #RTEMS_INTERRUPT_SHARED is set, then multiple handler may be
+ * If the option #RTEMS_INTERRUPT_REPLACE is set, then the handler specified by
+ * ``routine`` will replace the first handler with the same argument for the
+ * interrupt vector if it exists, otherwise an error status will be returned.
+ * A second handler with the same argument for the interrupt vector will remain
+ * unchanged.  The new handler will inherit the unique or shared options from
+ * the replaced handler.
+ * An informative description may be provided in ``info``.  It may be used for
+ * system debugging and diagnostic tools.  The referenced string has to be
+ * persistent as long as the handler is installed.
+ * @retval ::RTEMS_SUCCESSFUL The requested operation was successful.
+ * @retval ::RTEMS_INVALID_ADDRESS The ``routine`` parameter was NULL.
+ * @retval ::RTEMS_INVALID_ID There was no interrupt vector associated with the
+ *   number specified by ``vector``.
+ * @retval ::RTEMS_NO_MEMORY There was not enough memory available to allocate
+ *   data structures to install the handler.
+ *   in ``options`` and the interrupt vector was already occupied by a handler.
+ *   in ``options`` and the interrupt vector was already occupied by a unique
+ *   handler.
+ * @retval ::RTEMS_TOO_MANY The handler specified by ``routine`` was already
+ *   installed for the interrupt vector specified by ``vector`` with an
+ *   argument equal to the argument specified by ``arg``.
+ * @retval ::RTEMS_UNSATISFIED The #RTEMS_INTERRUPT_REPLACE option was set in
+ *   ``options`` and no handler to replace was installed.
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_handler_install(
+  const char             *info,
+  void                   *arg
+/* Generated from spec:/rtems/intr/if/handler-remove */
+ * @brief Removes the interrupt handler routine and argument from the interrupt
+ *   vector.
+ * @param routine is the interrupt handler routine to remove.
+ * @param arg is the interrupt handler argument to remove.
+ * @retval ::RTEMS_UNSATISFIED There was no handler routine and argument pair
+ *   installed specified by ``routine`` and ``arg``.
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_handler_remove(
+  void                   *arg
+/* Generated from spec:/rtems/intr/if/vector-is-enabled */
+ * @brief Checks if the interrupt vector is enabled.
+ * @param[out] enabled is the pointer to a ``bool`` object.  When the directive
+ *   call is successful, the enabled status of the interrupt associated with
+ *   the interrupt vector specified by ``vector`` will be stored in this
+ *   object.  When the interrupt was enabled for the processor executing the
+ *   directive call at some time point during the call, the object value will
+ *   be set to true, otherwise to false.
+ * The directive checks if the interrupt associated with the interrupt vector
+ * specified by ``vector`` was enabled for the processor executing the
+ * directive call at some time point during the call.
+ * @retval ::RTEMS_INVALID_ADDRESS The ``enabled`` parameter was NULL.
+ * @par Notes
+ * Interrupt vectors may be enabled by rtems_interrupt_vector_enable() and
+ * disabled by rtems_interrupt_vector_disable().
+ * @parblock
+ * * The directive may be called from within interrupt context.
+ *   context.
+ * * The directive will not cause the calling task to be preempted.
+ * @endparblock
+rtems_status_code rtems_interrupt_vector_is_enabled(
+  bool               *enabled
+/* Generated from spec:/rtems/intr/if/vector-enable */
+ * @brief Enables the interrupt vector.
+ * @param vector is the number of the interrupt vector to enable.
+ * The directive enables the interrupt vector specified by ``vector``. This
+ * allows that interrupt service requests are issued to the target processors
+ * of the interrupt vector.  Interrupt service requests for an interrupt vector
+ * may be raised by rtems_interrupt_raise(), rtems_interrupt_raise_on(),
+ * external signals, or messages.
+ * @retval ::RTEMS_UNSATISFIED The request to enable the interrupt vector has
+ *   not been satisfied.
+ * @par Notes
+ * The rtems_interrupt_get_attributes() directive may be used to check if an
+ * interrupt vector can be enabled.  Interrupt vectors may be disabled by
+ * rtems_interrupt_vector_disable().
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_vector_enable( rtems_vector_number vector );
+/* Generated from spec:/rtems/intr/if/vector-disable */
+ * @brief Disables the interrupt vector.
+ * @param vector is the number of the interrupt vector to disable.
+ * The directive disables the interrupt vector specified by ``vector``.  This
+ * prevents that an interrupt service request is issued to the target
+ * processors of the interrupt vector.
+ * @retval ::RTEMS_UNSATISFIED The request to disable the interrupt vector has
+ * @par Notes
+ * interrupt vector can be disabled.  Interrupt vectors may be enabled by
+ * rtems_interrupt_vector_enable().  There may be targets on which some
+ * interrupt vectors cannot be disabled, for example a hardware watchdog
+ * interrupt or software generated interrupts.
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_vector_disable( rtems_vector_number vector );
+/* Generated from spec:/rtems/intr/if/is-pending */
+ * @brief Checks if the interrupt is pending.
+ * @param[out] pending is the pointer to a ``bool`` object.  When the directive
+ *   call is successful, the pending status of the interrupt associated with
+ *   object.  When the interrupt was pending for the processor executing the
+ * specified by ``vector`` was pending for the processor executing the
+ * @retval ::RTEMS_INVALID_ADDRESS The ``pending`` parameter was NULL.
+ * @retval ::RTEMS_UNSATISFIED The request to get the pending status has not
+ *   been satisfied.
+ * @par Notes
+ * Interrupts may be made pending by calling the rtems_interrupt_raise() or
+ * rtems_interrupt_raise_on() directives or due to external signals or
+ * messages.  The pending state may be cleared by rtems_interrupt_clear().
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_is_pending(
+  bool               *pending
+/* Generated from spec:/rtems/intr/if/raise */
+ * @brief Raises the interrupt vector.
+ * @param vector is the number of the interrupt vector to raise.
+ * @retval ::RTEMS_UNSATISFIED The request to raise the interrupt vector has
+ * @par Notes
+ * interrupt vector can be raised.
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_raise( rtems_vector_number vector );
+/* Generated from spec:/rtems/intr/if/raise-on */
+ * @brief Raises the interrupt vector on the processor.
+ * @param cpu_index is the index of the target processor of the interrupt
+ *   vector to raise.
+ * @retval ::RTEMS_NOT_CONFIGURED The processor specified by ``cpu_index`` was
+ *   not configured to be used by the application.
+ * @retval ::RTEMS_INCORRECT_STATE The processor specified by ``cpu_index`` was
+ *   configured to be used by the application, however, it was not online.
+ * @par Notes
+ * interrupt vector can be raised on a processor.
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_raise_on(
+  uint32_t            cpu_index
+/* Generated from spec:/rtems/intr/if/clear */
+ * @brief Clears the interrupt vector.
+ * @param vector is the number of the interrupt vector to clear.
+ * @par Notes
  * interrupt vector can be cleared.
  * @par Constraints
@@ -995,7 +1844,1409 @@ rtems_status_code rtems_interrupt_raise_on(
  * @endparblock
-rtems_status_code rtems_interrupt_clear( rtems_vector_number vector );
+rtems_status_code rtems_interrupt_clear( rtems_vector_number vector );
+/* Generated from spec:/rtems/intr/if/get-affinity */
+ * @brief Gets the processor affinity set of the interrupt vector.
+ * @param affinity_size is the size of the processor set referenced by
+ *   ``affinity`` in bytes.
+ * @param[out] affinity is the pointer to a cpu_set_t object.  When the
+ *   directive call is successful, the processor affinity set of the interrupt
+ *   vector will be stored in this object.  A set bit in the processor set
+ *   means that the corresponding processor is in the processor affinity set of
+ *   the interrupt vector, otherwise the bit is cleared.
+ * @retval ::RTEMS_INVALID_ADDRESS The ``affinity`` parameter was NULL.
+ * @retval ::RTEMS_INVALID_SIZE The size specified by ``affinity_size`` of the
+ *   processor set was too small for the processor affinity set of the
+ *   interrupt vector.
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_get_affinity(
+  size_t              affinity_size,
+  cpu_set_t          *affinity
+/* Generated from spec:/rtems/intr/if/set-affinity */
+ * @brief Sets the processor affinity set of the interrupt vector.
+ * @param affinity is the pointer to a cpu_set_t object.  The processor set
+ *   defines the new processor affinity set of the interrupt vector.  A set bit
+ *   in the processor set means that the corresponding processor shall be in
+ *   the processor affinity set of the interrupt vector, otherwise the bit
+ *   shall be cleared.
+ * @retval ::RTEMS_INVALID_NUMBER The referenced processor set was not a valid
+ *   new processor affinity set for the interrupt vector.
+ * @retval ::RTEMS_UNSATISFIED The request to set the processor affinity of the
+ *   interrupt vector has not been satisfied.
+ * @par Notes
+ * The rtems_interrupt_get_attributes() directive may be used to check if the
+ * processor affinity of an interrupt vector can be set.
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_set_affinity(
+  const cpu_set_t    *affinity
+/* Generated from spec:/rtems/intr/if/get-attributes */
+ * @brief Gets the attributes of the interrupt vector.
+ * @param[out] attributes is the pointer to an rtems_interrupt_attributes
+ *   object.  When the directive call is successful, the attributes of the
+ *   interrupt vector will be stored in this object.
+ * @retval ::RTEMS_INVALID_ADDRESS The ``attributes`` parameter was NULL.
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_get_attributes(
+  rtems_interrupt_attributes *attributes
+/* Generated from spec:/rtems/intr/if/handler-iterate */
+ * @brief Iterates over all interrupt handler installed at the interrupt
+ *   vector.
+ * @param routine is the visitor routine.
+ * @param arg is the visitor argument.
+ * For each installed handler at the interrupt vector the visitor function
+ * specified by ``routine`` will be called with the argument specified by
+ * ``arg`` and the handler information, options, routine and argument.
+ * @par Notes
+ * @parblock
+ * The directive is intended for system information and diagnostics.
+ * Never install or remove an interrupt handler within the visitor function.
+ * This may result in a deadlock.
+ * @endparblock
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_handler_iterate(
+  rtems_interrupt_per_handler_routine routine,
+  void                               *arg
+/* Generated from spec:/rtems/intr/if/server-default */
+ * @brief The constant represents the index of the default interrupt server.
+#define RTEMS_INTERRUPT_SERVER_DEFAULT 0
+/* Generated from spec:/rtems/intr/if/server-control */
+ * @brief This structure represents an interrupt server.
+ * @par Notes
+ * view.  Members shall not be accessed directly.  The structure is initialized
+ * by rtems_interrupt_server_create() and maintained by the interrupt server
+ * support.
+typedef struct rtems_interrupt_server_control {
+  #if defined(RTEMS_SMP)
+     * @brief This member is the ISR lock protecting the server control state.
+    rtems_interrupt_lock lock;
+  #endif
+   * @brief This member is the chain of pending interrupt entries.
+  Chain_Control entries;
+   * @brief This member is the identifier of the server task.
+  rtems_id server;
+   * @brief This member is the error count.
+  unsigned long errors;
+   * @brief This member is the server index.
+  uint32_t index;
+   * @brief This member is the node for the interrupt server registry.
+  Chain_Node node;
+   * @brief This member is the optional handler to destroy the interrupt server
+   *   control.
+  void ( *destroy )( struct rtems_interrupt_server_control * );
+} rtems_interrupt_server_control;
+/* Generated from spec:/rtems/intr/if/server-config */
+ * @brief This structure defines an interrupt server configuration.
+ * @par Notes
+ * See also rtems_interrupt_server_create().
+typedef struct {
+   * @brief This member is the task name of the interrupt server.
+  rtems_name name;
+   * @brief This member is the initial task priority of the interrupt server.
+  rtems_task_priority priority;
+   * @brief This member is the task storage area of the interrupt server.
+   * It shall be NULL for interrupt servers created by
+   * rtems_interrupt_server_create().
+  void *storage_area;
+   * @brief This member is the task storage size of the interrupt server.
+   * For interrupt servers created by rtems_interrupt_server_create() this is the
+   * task stack size.
+  size_t storage_size;
+   * @brief This member is the initial mode set of the interrupt server.
+  rtems_mode modes;
+   * @brief This member is the attribute set of the interrupt server.
+  rtems_attribute attributes;
+   * @brief This member is an optional handler to destroy the interrupt server
+   *   control handed over to rtems_interrupt_server_create().
+   * The destroy handler is optional and may be NULL.  If the destroy handler is
+   * present, it is called from within the context of the interrupt server to be
+   * deleted, see also rtems_interrupt_server_delete().
+  void ( *destroy )( rtems_interrupt_server_control * );
+} rtems_interrupt_server_config;
+/* Generated from spec:/rtems/intr/if/server-initialize */
+ * @brief Initializes the interrupt server tasks.
+ * @param priority is the initial task priority of the created interrupt
+ *   servers.
+ * @param stack_size is the task stack size of the created interrupt servers.
+ * @param modes is the initial mode set of the created interrupt servers.
+ * @param attributes is the attribute set of the created interrupt servers.
+ * @param[out] server_count is the pointer to an uint32_t object or NULL. When
+ *   the pointer is not equal to NULL, the count of successfully created
+ *   interrupt servers is stored in this object regardless of the return
+ *   status.
+ * The directive tries to create an interrupt server task for each online
+ * processor in the system.  The tasks will have the initial priority specified
+ * by ``priority``, the stack size specified by ``stack_size``, the initial
+ * mode set specified by ``modes``, and the attribute set specified by
+ * ``attributes``.  The count of successfully created server tasks will be
+ * returned in ``server_count`` if the pointer is not equal to NULL.
+ * @retval ::RTEMS_INCORRECT_STATE The interrupt servers were already
+ *   initialized.
+ * @return The directive uses rtems_task_create().  If this directive fails,
+ *   then its error status will be returned.
+ * @par Notes
+ * @parblock
+ * Interrupt handlers may be installed on an interrupt server with
+ * rtems_interrupt_server_handler_install() and removed with
+ * rtems_interrupt_server_handler_remove() using a server index.  In case of an
+ * interrupt, the request will be forwarded to the interrupt server.  The
+ * handlers are executed within the interrupt server context.  If one handler
+ * blocks on something this may delay the processing of other handlers.
+ * Interrupt servers may be deleted by rtems_interrupt_server_delete().
+ * @endparblock
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_server_initialize(
+  rtems_task_priority priority,
+  size_t              stack_size,
+  rtems_mode          modes,
+  rtems_attribute     attributes,
+  uint32_t           *server_count
+/* Generated from spec:/rtems/intr/if/server-create */
+ * @brief Creates an interrupt server.
+ * @param[out] control is the pointer to an rtems_interrupt_server_control
+ *   object.  When the directive call was successful, the ownership of the
+ *   object was transferred from the caller of the directive to the interrupt
+ *   server management.
+ * @param config is the interrupt server configuration.
+ * @param[out] server_index is the pointer to an uint32_t object.  When the
+ *   directive call was successful, the index of the created interrupt server
+ *   will be stored in this object.
+ * @par Notes
+ * See also rtems_interrupt_server_initialize() and
+ * rtems_interrupt_server_delete().
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_server_create(
+  rtems_interrupt_server_control      *control,
+  const rtems_interrupt_server_config *config,
+  uint32_t                            *server_index
+/* Generated from spec:/rtems/intr/if/server-handler-install */
+ *   vector on the interrupt server.
+ * @param server_index is the interrupt server index.  The constant
+ *   #RTEMS_INTERRUPT_SERVER_DEFAULT may be used to specify the default
+ *   interrupt server.
+ *   install.
+ * The handler routine specified by ``routine`` will be executed within the
+ * context of the interrupt server task specified by ``server_index``.
+ * @retval ::RTEMS_INVALID_ID There was no interrupt server associated with the
+ *   index specified by ``server_index``.
+ * @retval ::RTEMS_INVALID_NUMBER An option specified by ``info`` was not
+ *   applicable.
+ *   in ``info`` and the interrupt vector was already occupied by a handler.
+ *   in ``info`` and the interrupt vector was already occupied by a unique
+ *   handler.
+ *   ``info`` and no handler to replace was installed.
+ * @par Notes
+ * See also rtems_interrupt_handler_install().
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_server_handler_install(
+  uint32_t                server_index,
+  const char             *info,
+  void                   *arg
+/* Generated from spec:/rtems/intr/if/server-handler-remove */
+ *   vector and the interrupt server.
+ * @parblock
+ * * The directive sends a request to another task and waits for a response.
+ *   This may cause the calling task to be blocked and unblocked.
+ * * The directive shall not be called from within the context of an interrupt
+ *   server.  Calling the directive from within the context of an interrupt
+ *   server is undefined behaviour.
+ * @endparblock
+rtems_status_code rtems_interrupt_server_handler_remove(
+  void                   *arg
+/* Generated from spec:/rtems/intr/if/server-set-affinity */
+ * @brief Sets the processor affinity of the interrupt server.
+ *   defines the new processor affinity set of the interrupt server.  A set bit
+ *   the processor affinity set of the task, otherwise the bit shall be
+ *   cleared.
+ * @param priority is the new real priority for the interrupt server.
+ * @return The directive uses rtems_scheduler_ident_by_processor_set(),
+ *   rtems_task_set_scheduler(), and rtems_task_set_affinity().  If one of
+ *   these directive fails, then its error status will be returned.
+ * @par Notes
+ * @parblock
+ * The scheduler is set determined by the highest numbered processor in the
+ * affinity set specified by ``affinity``.
+ * This operation is only reliable in case the interrupt server was suspended
+ * via rtems_interrupt_server_suspend().
+ * @endparblock
+ * @parblock
+ *   context.
+ * * The directive may change the processor affinity of a task.  This may cause
+ *   the calling task to be preempted.
+ * * The directive may change the priority of a task.  This may cause the
+ *   calling task to be preempted.
+ * @endparblock
+rtems_status_code rtems_interrupt_server_set_affinity(
+  const cpu_set_t    *affinity,
+/* Generated from spec:/rtems/intr/if/server-delete */
+ * @brief Deletes the interrupt server.
+ * @param server_index is the index of the interrupt server to delete.
+ *   server index specified by ``server_index``.
+ * @par Notes
+ * @parblock
+ * The interrupt server deletes itself, so after the return of the directive
+ * the interrupt server may be still in the termination process depending on
+ * the task priorities of the system.
+ * @endparblock
+ * @parblock
+ * @endparblock
+rtems_status_code rtems_interrupt_server_delete( uint32_t server_index );
+/* Generated from spec:/rtems/intr/if/server-suspend */
+ * @brief Suspends the interrupt server.
+ * @param server_index is the index of the interrupt server to suspend.  The
+ *   constant #RTEMS_INTERRUPT_SERVER_DEFAULT may be used to specify the
+ *   default interrupt server.
+ * @par Notes
+ * Interrupt server may be resumed by rtems_interrupt_server_resume().
+ * @parblock
+ * @endparblock
+rtems_status_code rtems_interrupt_server_suspend( uint32_t server_index );
+/* Generated from spec:/rtems/intr/if/server-resume */
+ * @brief Resumes the interrupt server.
+ * @param server_index is the index of the interrupt server to resume.  The
+ * @par Notes
+ * Interrupt server may be suspended by rtems_interrupt_server_suspend().
+ * @parblock
+ * @endparblock
+rtems_status_code rtems_interrupt_server_resume( uint32_t server_index );
+/* Generated from spec:/rtems/intr/if/server-move */
+ * @brief Moves the interrupt handlers installed at the interrupt vector and
+ *   the source interrupt server to the destination interrupt server.
+ * @param source_server_index is the index of the source interrupt server.  The
+ * @param destination_server_index is the index of the destination interrupt
+ *   server.  The constant #RTEMS_INTERRUPT_SERVER_DEFAULT may be used to
+ *   specify the default interrupt server.
+ *   index specified by ``source_server_index``.
+ *   index specified by ``destination_server_index``.
+ * @parblock
+ * @endparblock
+rtems_status_code rtems_interrupt_server_move(
+  uint32_t            source_server_index,
+  uint32_t            destination_server_index
+/* Generated from spec:/rtems/intr/if/server-handler-iterate */
+ * @brief Iterates over all interrupt handler installed at the interrupt vector
+ *   and interrupt server.
+ * @param server_index is the index of the interrupt server.
+ * For each installed handler at the interrupt vector and interrupt server the
+ * visitor function specified by ``vector`` will be called with the argument
+ * specified by ``routine`` and the handler information, options, routine and
+ * argument.
+ * @par Notes
+ * @parblock
+ * @endparblock
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_server_handler_iterate(
+  void                               *arg
+/* Generated from spec:/rtems/intr/if/server-action */
+ * @brief This structure represents an interrupt server action.
+ * @par Notes
+typedef struct rtems_interrupt_server_action {
+   * @brief This member is the reference to the next action or NULL.
+  struct rtems_interrupt_server_action *next;
+   * @brief This member is the interrupt handler.
+  void *arg;
+} rtems_interrupt_server_action;
+/* Generated from spec:/rtems/intr/if/server-entry */
+ * @brief This structure represents an interrupt server entry.
+ * @par Notes
+ * view.  Members shall not be accessed directly.  An entry is initialized by
+ * rtems_interrupt_server_entry_initialize() and destroyed by
+ * rtems_interrupt_server_entry_destroy().  Interrupt server actions can be
+ * prepended to the entry by rtems_interrupt_server_action_prepend().  The
+ * entry is submitted to be serviced by rtems_interrupt_server_entry_submit().
+typedef struct {
+   * @brief This member is the node for the interrupt entry processing.
+  Chain_Node node;
+   * @brief This member references the interrupt server used to process the
+   *   entry.
+  rtems_interrupt_server_control *server;
+   * @brief This member is the interrupt vector number.
+  rtems_vector_number vector;
+   * @brief This member is the interrupt server actions list head.
+  rtems_interrupt_server_action *actions;
+} rtems_interrupt_server_entry;
+/* Generated from spec:/rtems/intr/if/server-entry-initialize */
+ * @brief Initializes the interrupt server entry.
+ * @param entry is the interrupt server entry to initialize.
+ * @par Notes
+ * After initialization, the list of actions of the interrupt server entry is
+ * empty.  Actions may be prepended by rtems_interrupt_server_action_prepend().
+ * Interrupt server entries may be moved to another interrupt vector with
+ * rtems_interrupt_server_entry_move().  Server entries may be submitted to get
+ * serviced by the interrupt server with rtems_interrupt_server_entry_submit().
+ * Server entries may be destroyed by rtems_interrupt_server_entry_destroy().
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_server_entry_initialize(
+  rtems_interrupt_server_entry *entry
+/* Generated from spec:/rtems/intr/if/server-action-prepend */
+ * @brief Prepends the interrupt server action to the list of actions of the
+ *   interrupt server entry.
+ * @param[in,out] entry is the interrupt server entry to prepend the interrupt
+ *   server action.  It shall have been initialized via
+ *   rtems_interrupt_server_entry_initialize().
+ * @param[out] action is the interrupt server action to initialize and prepend
+ *   to the list of actions of the entry.
+ * @param routine is the interrupt handler routine to set in the action.
+ * @param arg is the interrupt handler argument to set in the action.
+ * @par Notes
+ * No error checking is performed by the directive.
+ * @parblock
+ *   context.
+ * * The interrupt server entry shall have been initialized by
+ *   rtems_interrupt_server_entry_initialize() and further optional calls to
+ *   rtems_interrupt_server_action_prepend().
+ * * The directive shall not be called concurrently with
+ *   rtems_interrupt_server_action_prepend() with the same interrupt server
+ *   entry. Calling the directive under this condition is undefined behaviour.
+ *   rtems_interrupt_server_entry_move() with the same interrupt server entry.
+ *   Calling the directive under this condition is undefined behaviour.
+ *   rtems_interrupt_server_entry_submit() with the same interrupt server
+ * * The directive shall not be called while the interrupt server entry is
+ *   pending on or serviced by its current interrupt server.  Calling the
+ *   directive under these conditions is undefined behaviour.
+ * @endparblock
+void rtems_interrupt_server_action_prepend(
+  rtems_interrupt_server_entry  *entry,
+  rtems_interrupt_server_action *action,
+  void                          *arg
+/* Generated from spec:/rtems/intr/if/server-entry-destroy */
+ * @brief Destroys the interrupt server entry.
+ * @param[in,out] entry is the interrupt server entry to destroy.
+ * @par Notes
+ * @parblock
+ * @endparblock
+void rtems_interrupt_server_entry_destroy(
+/* Generated from spec:/rtems/intr/if/server-entry-submit */
+ * @brief Submits the interrupt server entry to be serviced by the interrupt
+ *   server.
+ * @param entry is the interrupt server entry to submit.
+ * The directive appends the entry to the pending entries of the interrupt
+ * server.  The interrupt server is notified that a new entry is pending.  Once
+ * the interrupt server is scheduled it services the actions of all pending
+ * entries.
+ * @par Notes
+ * @parblock
+ * This directive may be used to do a two-step interrupt processing.  The first
+ * step is done from within interrupt context by a call to this directive.  The
+ * second step is then done from within the context of the interrupt server.
+ * A submitted entry may be destroyed by
+ * @endparblock
+ * @parblock
+ *   context.
+ * * The directive may unblock a task.  This may cause the calling task to be
+ *   preempted.
+ * @endparblock
+void rtems_interrupt_server_entry_submit(
+/* Generated from spec:/rtems/intr/if/server-entry-move */
+ * @brief Moves the interrupt server entry to the interrupt server.
+ * @param entry is the interrupt server entry to move.
+ * @param server_index is the index of the destination interrupt server.  The
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_server_entry_move(
+/* Generated from spec:/rtems/intr/if/server-request */
+ * @brief This structure represents an interrupt server request.
+ * @par Notes
+ * view.  Members shall not be accessed directly.  A request is initialized by
+ * rtems_interrupt_server_request_initialize() and destroyed by
+ * rtems_interrupt_server_request_destroy().  The interrupt vector of the
+ * request can be set by rtems_interrupt_server_request_set_vector().  The
+ * request is submitted to be serviced by
+ * rtems_interrupt_server_request_submit().
+typedef struct {
+   * @brief This member is the interrupt server entry.
+  rtems_interrupt_server_entry entry;
+   * @brief This member is the interrupt server action.
+  rtems_interrupt_server_action action;
+} rtems_interrupt_server_request;
+/* Generated from spec:/rtems/intr/if/server-request-initialize */
+ * @brief Initializes the interrupt server request.
+ * @param[out] request is the interrupt server request to initialize.
+ * @param routine is the interrupt handler routine for the request action.
+ * @param arg is the interrupt handler argument for the request action.
+ * @par Notes
+ * An interrupt server requests consists of an interrupt server entry and
+ * exactly one interrupt server action.  The interrupt vector of the request
+ * may be changed with rtems_interrupt_server_request_set_vector().  Interrupt
+ * server requests may be submitted to get serviced by the interrupt server
+ * with rtems_interrupt_server_request_submit().  Requests may be destroyed by
+ * @parblock
+ *   context.
+ * @endparblock
+rtems_status_code rtems_interrupt_server_request_initialize(
+  rtems_interrupt_server_request *request,
+  void                           *arg
+/* Generated from spec:/rtems/intr/if/server-request-set-vector */
+ * @brief Sets the interrupt vector in the interrupt server request.
+ * @param[in,out] request is the interrupt server request to change.
+ * @param vector is the interrupt vector number to be used by the request.
+ * @par Notes
+ * @parblock
+ * By default, the interrupt vector of an interrupt server request is set to a
+ * special value which is outside the range of vectors supported by the
+ * interrupt controller hardware.
+ * Calls to rtems_interrupt_server_request_submit() will disable the interrupt
+ * vector of the request.  After processing of the request by the interrupt
+ * server the interrupt vector will be enabled again.
+ * @endparblock
+ * @parblock
+ *   context.
+ * * The interrupt server request shall have been initialized by
+ *   rtems_interrupt_server_request_initialize().
+ *   rtems_interrupt_server_request_set_vector() with the same interrupt server
+ *   request.  Calling the directive under this condition is undefined
+ *   behaviour.
+ *   rtems_interrupt_server_request_submit() with the same interrupt server
+ *   behaviour.
+ * @endparblock
+static inline void rtems_interrupt_server_request_set_vector(
+  request->entry.vector = vector;
+/* Generated from spec:/rtems/intr/if/server-request-destroy */
+ * @brief Destroys the interrupt server request.
+ * @param[in,out] request is the interrupt server request to destroy.
+ * @par Notes
+ * @parblock
+ * @endparblock
+static inline void rtems_interrupt_server_request_destroy(
+  rtems_interrupt_server_entry_destroy( &request->entry );
+/* Generated from spec:/rtems/intr/if/server-request-submit */
+ * @brief Submits the interrupt server request to be serviced by the interrupt
+ *   server.
+ * @param[in,out] request is the interrupt server request to submit.
+ * The directive appends the interrupt server entry of the request to the
+ * pending entries of the interrupt server.  The interrupt server is notified
+ * that a new entry is pending.  Once the interrupt server is scheduled it
+ * services the actions of all pending entries.
+ * @par Notes
+ * @parblock
+ * A submitted request may be destroyed by
+ * @endparblock
+ * @parblock
+ *   context.
+ *   preempted.
+ *   behaviour.
+ * @endparblock
+static inline void rtems_interrupt_server_request_submit(
+  rtems_interrupt_server_entry_submit( &request->entry );
 #ifdef __cplusplus
2.26.2
