[PATCH rtems-tools 2/8] ExecutableInfo.h: Fix formatting
Ryan Long ryan.long at oarcorp.com
Fri Dec 3 14:47:53 UTC 2021
 tester/covoar/ExecutableInfo.h | 16 ++++++++--------
 1 file changed, 8 insertions(+), 8 deletions(-)
diff --git a/tester/covoar/ExecutableInfo.h b/tester/covoar/ExecutableInfo.h
index fe46e1f..fd720ba 100644
--- a/tester/covoar/ExecutableInfo.h
+++ b/tester/covoar/ExecutableInfo.h
@@ -62,12 +62,12 @@ class DesiredSymbols;
      *  This method prints the contents of all coverage maps for
      *  this executable.
-    void dumpCoverageMaps( void );
+    void dumpCoverageMaps();
      *  This method prints the contents of Executable info containers
-    void dumpExecutableInfo( void );
+    void dumpExecutableInfo();
      *  This method returns a pointer to the executable's coverage map
@@ -84,28 +84,28 @@ class DesiredSymbols;
      *  @return Returns the executable's file name
-    const std::string& getFileName( void ) const;
+    const std::string& getFileName() const;
      *  This method returns the library name associated with the executable.
      *  @return Returns the executable's library name
-    const std::string getLibraryName( void ) const;
+    const std::string getLibraryName() const;
      *  This method returns the load address of the dynamic library
      *  @return Returns the load address of the dynamic library
-    uint32_t getLoadAddress( void ) const;
+    uint32_t getLoadAddress() const;
      *  This method returns a pointer to the executable's symbol table.
      *  @return Returns a pointer to the symbol table.
-    SymbolTable* getSymbolTable( void );
+    SymbolTable* getSymbolTable();
      *  This method finds a coverage map for the specified symbol.
@@ -131,13 +131,13 @@ class DesiredSymbols;
      *  @return Returns TRUE if
-    bool hasDynamicLibrary( void );
+    bool hasDynamicLibrary();
      *  This method merges the coverage maps for this executable into
      *  the unified coverage map.
-    void mergeCoverage( void );
+    void mergeCoverage();
      *  This method sets the load address of the dynamic library
1.8.3.1
