[PATCH v2] devel/dtc: Bump dtc hash to match rtems6
Ryan Long
ryan.long at oarcorp.com
Mon Dec 6 15:08:01 UTC 2021
Bumped dtc version to get rid of build failure for dtc.
Closes #4562
bare/config/devel/dtc-1.6.1-1.cfg | 18 ++++++++++++++++++
bare/config/devel/dtc.bset | 2 +-
rtems/config/5/rtems-moxie.bset | 2 +-
3 files changed, 20 insertions(+), 2 deletions(-)
create mode 100644 bare/config/devel/dtc-1.6.1-1.cfg
diff --git a/bare/config/devel/dtc-1.6.1-1.cfg b/bare/config/devel/dtc-1.6.1-1.cfg
new file mode 100644
index 0000000..54aed09
--- /dev/null
+++ b/bare/config/devel/dtc-1.6.1-1.cfg
@@ -0,0 +1,18 @@
+# DTC (Device Tree Compiler) 1.6.1
+%if %{release} == %{nil}
+%define release 1
+%endif
+%include %{_configdir}/base.cfg
+%define dtc_version 1.6.1
+%hash sha256 dtc-%{dtc_version}.tar.gz 38a6257f2c23cb9dfa1781ac4ad122d8358e1a22d33b2da0eb492c190644a376
+# The DTC build instructions. We use 1.x.x Release 1.
+%include %{_configdir}/dtc-1-1.cfg
diff --git a/bare/config/devel/dtc.bset b/bare/config/devel/dtc.bset
index 54521f6..56fb61e 100644
--- a/bare/config/devel/dtc.bset
+++ b/bare/config/devel/dtc.bset
@@ -4,4 +4,4 @@
%define release 1
-devel/dtc-1.4.1-1
+devel/dtc-1.6.1-1
diff --git a/rtems/config/5/rtems-moxie.bset b/rtems/config/5/rtems-moxie.bset
index 5051b85..85ced02 100644
--- a/rtems/config/5/rtems-moxie.bset
+++ b/rtems/config/5/rtems-moxie.bset
@@ -8,5 +8,5 @@
%define with_libgomp
# Moxie needs dtc to build gdb, then pick up the rest of the set
-devel/dtc-1.4.1-1
+devel/dtc-1.6.1-1
%include 5/rtems-default.bset
1.8.3.1
