[PATCH v1 3/4] ConfigFile: Convert to C++
Ryan Long ryan.long at oarcorp.com
Wed Dec 8 15:15:51 UTC 2021
 tester/covoar/ConfigFile.cc | 79 +++++++++++++++++----------------------------
 tester/covoar/ConfigFile.h  |  2 +-
 2 files changed, 31 insertions(+), 50 deletions(-)
diff --git a/tester/covoar/ConfigFile.cc b/tester/covoar/ConfigFile.cc
index c16b64a..5c8949e 100644
--- a/tester/covoar/ConfigFile.cc
+++ b/tester/covoar/ConfigFile.cc
@@ -10,6 +10,10 @@
 #include <ctype.h>
+#include <iostream>
+#include <fstream>
+#include <sstream>
 namespace Configuration {
   FileReader::FileReader(
@@ -24,43 +28,40 @@ namespace Configuration {
   bool FileReader::processFile(
-    const char* const     file
+    const std::string&     file
     #define METHOD "FileReader::processFile - "
-    FILE *  in;
-    char    line[256];
-    char    option[256];
-    char    value[256];
+    #define MAX_LENGTH 256
+    std::ifstream in;
+    std::string line;
+    char option[MAX_LENGTH];
+    char value[MAX_LENGTH];
     int     line_no;
     int     i;
     int     j;
-    if ( file == NULL ) {
-      fprintf( stderr, METHOD "NULL filename\n" );
+    if ( file.empty() ) {
+      std::cerr << METHOD << "Empty filename" << std::endl;
       return false;
-    in = fopen( file, "r" );
-    if ( !in ) {
-      fprintf( stderr, METHOD "unable to open %s\n", file );
+    in.open( file );
+    if ( !in.is_open() ) {
+      std::cerr << METHOD << "unable to open " << file << std::endl;
       return false;
     line_no = 0;
-    while (fgets(line, sizeof(line), in) != NULL) {
+    while ( std::getline( line, MAX_LENGTH ) ) {
       int length;
       line_no++;
-      length = (int) strlen( line );
-      if ( line[length - 1] != '\n' ) {
-        fprintf(
-          stderr,
-          "%s: line %d is too long",
-          file,
-          line_no
+      length = (int) line.length();
+      if ( length > MAX_LENGTH ) {
+        std::cerr << file << ": line " << line_no << " is too long"
+                  << std::endl;
         continue;
@@ -96,14 +97,9 @@ namespace Configuration {
       if (line[0] == '\0')
         continue;
-      if (sscanf(line, "%s", option) != 1) {
-        fprintf(
-          stderr,
-          "%s: line %d is invalid: %s\n",
-          file,
-          line_no,
-          line
+      if (sscanf(line.c_str(), "%s", option) != 1) {
+        std::cerr << file << ": line" << line_no << " is invalid: " << line
+                  << std::endl;
         continue;
@@ -111,13 +107,8 @@ namespace Configuration {
       if (i == length) {
-        fprintf(
-          stderr,
-          file,
-          line_no,
-          line
+                  << std::endl;
         continue;
@@ -129,24 +120,14 @@ namespace Configuration {
         value[j] = line[i];
       value[j] = '\0';
       if (value[0] == '\0') {
-        fprintf(
-          stderr,
-          file,
-          line_no,
-          line
+                  << std::endl;
         continue;
       if ( !setOption(option, value) ) {
-        fprintf(
-          stderr,
-          "%s: line %d: option %s is unknown\n",
-          file,
-          line_no,
-          option
+                  << std::endl;
         continue;
@@ -190,7 +171,7 @@ namespace Configuration {
     Options_t *o;
     for ( o=options_m ; o->option ; o++ ) {
-      fprintf( stderr, "(%s)=(%s)\n", o->option, o->value );
+      std::cerr << '(' << o->option << ")=(" << o->value << ')' << std::endl;
diff --git a/tester/covoar/ConfigFile.h b/tester/covoar/ConfigFile.h
index 0bae7ac..f8bd9c5 100644
--- a/tester/covoar/ConfigFile.h
+++ b/tester/covoar/ConfigFile.h
@@ -54,7 +54,7 @@ namespace Configuration {
      *  @return Returns TRUE if the method succeeded and FALSE if it failed.
     virtual bool processFile(
     bool setOption(
1.8.3.1
