[PATCH] spec: Update location of cadence I2C
Thu Dec 9 02:30:22 UTC 2021
OK and thanks
On 9/12/21 12:08 pm, Kinsey Moore wrote:
> When the cadence I2C code was moved to a shared directory, the
> references were updated but the install locations weren't. This updates
> the install locations to match what out-of-tree applications expect.
>  spec/build/bsps/aarch64/xilinx-zynqmp/objcadencei2c.yml | 4 +++-
>  spec/build/bsps/arm/xilinx-zynq/obj.yml                 | 6 ++++--
>  2 files changed, 7 insertions(+), 3 deletions(-)
> diff --git a/spec/build/bsps/aarch64/xilinx-zynqmp/objcadencei2c.yml b/spec/build/bsps/aarch64/xilinx-zynqmp/objcadencei2c.yml
> index fd9d51dfa9..fa269d61ad 100644
> --- a/spec/build/bsps/aarch64/xilinx-zynqmp/objcadencei2c.yml
> +++ b/spec/build/bsps/aarch64/xilinx-zynqmp/objcadencei2c.yml
> @@ -9,10 +9,12 @@ enabled-by: true
>  includes: []
>  install:
>  - destination: ${BSP_INCLUDEDIR}/bsp
> +  source:
> +  - bsps/aarch64/xilinx-zynqmp/include/bsp/i2c.h
> +- destination: ${BSP_INCLUDEDIR}/dev/i2c
>    source:
>    - bsps/include/dev/i2c/cadence-i2c-regs.h
>    - bsps/include/dev/i2c/cadence-i2c.h
> -  - bsps/aarch64/xilinx-zynqmp/include/bsp/i2c.h
>  links: []
>  source:
>  - bsps/shared/dev/i2c/cadence-i2c.c
> diff --git a/spec/build/bsps/arm/xilinx-zynq/obj.yml b/spec/build/bsps/arm/xilinx-zynq/obj.yml
> index bc675cd38c..dcac09126b 100644
> --- a/spec/build/bsps/arm/xilinx-zynq/obj.yml
> +++ b/spec/build/bsps/arm/xilinx-zynq/obj.yml
> @@ -14,10 +14,12 @@ install:
>    - bsps/arm/xilinx-zynq/include/tm27.h
>    source:
> -  - bsps/include/dev/i2c/cadence-i2c-regs.h
> -  - bsps/include/dev/i2c/cadence-i2c.h
>    - bsps/arm/xilinx-zynq/include/bsp/i2c.h
>    - bsps/arm/xilinx-zynq/include/bsp/irq.h
> +  source:
> +  - bsps/include/dev/i2c/cadence-i2c-regs.h
> +  - bsps/include/dev/i2c/cadence-i2c.h
>  links: []
>  source:
>  - bsps/arm/shared/cache/cache-l2c-310.c
