[PATCH v2 1/4] TargetFactory.cc: Convert to C++
Ryan Long
ryan.long at oarcorp.com
Thu Dec 9 23:00:08 UTC 2021
tester/covoar/TargetFactory.cc | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/tester/covoar/TargetFactory.cc b/tester/covoar/TargetFactory.cc
index 57ba686..fa72f05 100644
--- a/tester/covoar/TargetFactory.cc
+++ b/tester/covoar/TargetFactory.cc
@@ -37,7 +37,7 @@ namespace Target {
typedef struct {
//! This is the string found in configuration to match.
- const char *theTarget;
+ std::string theTarget;
//! This is the static wrapper for the constructor.
TargetBase *(*theCtor)(
std::string
@@ -76,10 +76,10 @@ namespace Target {
else
cpu = targetName.substr( 0, i );
- // fprintf( stderr, "%s --> %s\n", targetName.c_str(), cpu.c_str());
+ // std::cerr << targetName << " --> " << cpu << std::endl;
// Iterate over the table trying to find an entry with a matching name
for ( i=0 ; i < sizeof(FactoryTable) / sizeof(FactoryEntry_t); i++ ) {
- if ( !strcmp(FactoryTable[i].theTarget, cpu.c_str() ) )
+ if ( FactoryTable[i].theTarget == cpu )
return FactoryTable[i].theCtor( targetName );
1.8.3.1
