[PATCH v2 3/4] ConfigFile: Convert to C++
Ryan Long
ryan.long at oarcorp.com
Thu Dec 9 23:00:10 UTC 2021
tester/covoar/ConfigFile.cc | 82 ++++++++++++++++++---------------------------
tester/covoar/ConfigFile.h | 2 +-
2 files changed, 33 insertions(+), 51 deletions(-)
diff --git a/tester/covoar/ConfigFile.cc b/tester/covoar/ConfigFile.cc
index c16b64a..7109b2c 100644
--- a/tester/covoar/ConfigFile.cc
+++ b/tester/covoar/ConfigFile.cc
@@ -7,9 +7,18 @@
#include "ConfigFile.h"
-#include <stdio.h>
#include <ctype.h>
+#include <iostream>
+#include <fstream>
+#include <sstream>
+static void print_invalid_line_number( const std::string& file, int line_no )
+ std::cerr << file << ": line" << line_no << " is invalid: " << line
+ << std::endl;
namespace Configuration {
FileReader::FileReader(
@@ -24,43 +33,40 @@ namespace Configuration {
bool FileReader::processFile(
- const char* const file
+ const std::string& file
#define METHOD "FileReader::processFile - "
- FILE * in;
- char line[256];
- char option[256];
- char value[256];
+ #define MAX_LENGTH 256
+ std::ifstream in;
+ std::string line;
+ char option[MAX_LENGTH];
+ char value[MAX_LENGTH];
int line_no;
int i;
int j;
- if ( file == NULL ) {
- fprintf( stderr, METHOD "NULL filename\n" );
+ if ( file.empty() ) {
+ std::cerr << METHOD << "Empty filename" << std::endl;
return false;
- in = fopen( file, "r" );
- if ( !in ) {
- fprintf( stderr, METHOD "unable to open %s\n", file );
+ in.open( file );
+ if ( !in.is_open() ) {
+ std::cerr << METHOD << "unable to open " << file << std::endl;
return false;
line_no = 0;
- while (fgets(line, sizeof(line), in) != NULL) {
+ while ( std::getline( line, MAX_LENGTH ) ) {
int length;
line_no++;
- length = (int) strlen( line );
- if ( line[length - 1] != '\n' ) {
- fprintf(
- stderr,
- "%s: line %d is too long",
- file,
- line_no
+ length = (int) line.length();
+ if ( length > MAX_LENGTH ) {
+ std::cerr << file << ": line " << line_no << " is too long"
+ << std::endl;
continue;
@@ -96,14 +102,8 @@ namespace Configuration {
if (line[0] == '\0')
continue;
- if (sscanf(line, "%s", option) != 1) {
- fprintf(
- stderr,
- "%s: line %d is invalid: %s\n",
- file,
- line_no,
- line
+ if (std::sscanf(line.c_str(), "%s", option) != 1) {
+ print_invalid_line_number(file, line_no);
continue;
@@ -111,13 +111,7 @@ namespace Configuration {
if (i == length) {
- fprintf(
- stderr,
- file,
- line_no,
- line
continue;
@@ -129,24 +123,12 @@ namespace Configuration {
value[j] = line[i];
value[j] = '\0';
if (value[0] == '\0') {
- fprintf(
- stderr,
- file,
- line_no,
- line
continue;
if ( !setOption(option, value) ) {
- fprintf(
- stderr,
- "%s: line %d: option %s is unknown\n",
- file,
- line_no,
- option
continue;
@@ -190,7 +172,7 @@ namespace Configuration {
Options_t *o;
for ( o=options_m ; o->option ; o++ ) {
- fprintf( stderr, "(%s)=(%s)\n", o->option, o->value );
+ std::cerr << '(' << o->option << ")=(" << o->value << ')' << std::endl;
diff --git a/tester/covoar/ConfigFile.h b/tester/covoar/ConfigFile.h
index 0bae7ac..f8bd9c5 100644
--- a/tester/covoar/ConfigFile.h
+++ b/tester/covoar/ConfigFile.h
@@ -54,7 +54,7 @@ namespace Configuration {
* @return Returns TRUE if the method succeeded and FALSE if it failed.
virtual bool processFile(
bool setOption(
1.8.3.1
