[PATCH rtems-tools 1/6] ObjdumpProcessor.cc: Fix formatting
Ryan Long
ryan.long at oarcorp.com
Mon Dec 13 16:09:28 UTC 2021
tester/covoar/ObjdumpProcessor.cc | 64 ++++++++++++++++++++++-----------------
1 file changed, 36 insertions(+), 28 deletions(-)
diff --git a/tester/covoar/ObjdumpProcessor.cc b/tester/covoar/ObjdumpProcessor.cc
index 8c0e8dc..92e812d 100644
--- a/tester/covoar/ObjdumpProcessor.cc
+++ b/tester/covoar/ObjdumpProcessor.cc
@@ -38,73 +38,81 @@ namespace Coverage {
// Find the symbol's coverage map.
try {
- CoverageMapBase& coverageMap = executableInfo->findCoverageMap(symbolName);
+ CoverageMapBase& coverageMap =
+ executableInfo->findCoverageMap( symbolName );
uint32_t firstInstructionAddress = UINT32_MAX;
// Find the address of the first instruction.
- for (auto& line : instructions) {
- if (line.isInstruction) {
+ for ( auto& line : instructions ) {
+ if ( line.isInstruction ) {
firstInstructionAddress = line.address;
break;
- if (firstInstructionAddress == UINT32_MAX) {
+ if ( firstInstructionAddress == UINT32_MAX ) {
std::ostringstream what;
what << "Could not find first instruction address for symbol "
- << symbolName << " in " << executableInfo->getFileName();
+ << symbolName << " in " << executableInfo->getFileName();
throw rld::error( what, "Coverage::finalizeSymbol" );
- int rangeIndex = -1;
+ int rangeIndex = -1;
uint32_t lowAddress = UINT32_MAX;
do {
rangeIndex++;
- lowAddress = coverageMap.getLowAddressOfRange(rangeIndex);
- } while (firstInstructionAddress != lowAddress);
+ lowAddress = coverageMap.getLowAddressOfRange( rangeIndex );
+ } while ( firstInstructionAddress != lowAddress );
- uint32_t sizeWithoutNops = coverageMap.getSizeOfRange(rangeIndex);
- uint32_t size = sizeWithoutNops;
- uint32_t highAddress = lowAddress + size - 1;
+ uint32_t sizeWithoutNops = coverageMap.getSizeOfRange( rangeIndex );
+ uint32_t size = sizeWithoutNops;
+ uint32_t highAddress = lowAddress + size - 1;
uint32_t computedHighAddress = highAddress;
// Find the high address as reported by the address of the last NOP
// instruction. This ensures that NOPs get marked as executed later.
- for (auto instruction = instructions.rbegin();
- instruction != instructions.rend();
- instruction++) {
- if (instruction->isInstruction) {
- if (instruction->isNop) {
+ for (
+ auto instruction = instructions.rbegin();
+ instruction != instructions.rend();
+ instruction++
+ if ( instruction->isInstruction ) {
+ if ( instruction->isNop ) {
computedHighAddress = instruction->address + instruction->nopSize;
break;
- if (highAddress != computedHighAddress) {
- std::cerr << "Function's high address differs between DWARF and objdump: "
- << symbolName << " (0x" << std::hex << highAddress << " and 0x"
- << computedHighAddress - 1 << ")" << std::dec << std::endl;
+ if ( highAddress != computedHighAddress ) {
+ std::cerr << "Function's high address differs between DWARF and "
+ << "objdump: " << symbolName << " (0x" << std::hex
+ << highAddress << " and 0x"
+ << computedHighAddress - 1 << ")" << std::dec << std::endl;
size = computedHighAddress - lowAddress;
// If there are NOT already saved instructions, save them.
SymbolInformation* symbolInfo = symbolsToAnalyze.find( symbolName );
- if (symbolInfo->instructions.empty()) {
- symbolInfo->sourceFile = executableInfo;
- symbolInfo->baseAddress = lowAddress;
+ if ( symbolInfo->instructions.empty() ) {
+ symbolInfo->sourceFile = executableInfo;
+ symbolInfo->baseAddress = lowAddress;
symbolInfo->instructions = instructions;
// Add the symbol to this executable's symbol table.
SymbolTable* theSymbolTable = executableInfo->getSymbolTable();
theSymbolTable->addSymbol(
- symbolName, lowAddress, highAddress - lowAddress + 1
+ symbolName,
+ lowAddress,
+ highAddress - lowAddress + 1
// Mark the start of each instruction in the coverage map.
- for (auto& instruction : instructions) {
+ for ( auto& instruction : instructions ) {
coverageMap.setIsStartOfInstruction( instruction.address );
@@ -116,16 +124,16 @@ namespace Coverage {
sizeWithoutNops,
verbose
- } catch (const ExecutableInfo::CoverageMapNotFoundError& e) {
+ } catch ( const ExecutableInfo::CoverageMapNotFoundError& e ) {
// Allow execution to continue even if a coverage map could not be
// found.
std::cerr << "Coverage map not found for symbol " << e.what()
- << std::endl;
+ << std::endl;
ObjdumpProcessor::ObjdumpProcessor(
- DesiredSymbols& symbolsToAnalyze,
+ DesiredSymbols& symbolsToAnalyze,
std::shared_ptr<Target::TargetBase>& targetInfo
): symbolsToAnalyze_m( symbolsToAnalyze ),
targetInfo_m( targetInfo )
1.8.3.1
