[PATCH rtems-tools 3/6] ConfigFile: Fix formatting
Ryan Long
ryan.long at oarcorp.com
Mon Dec 13 16:09:30 UTC 2021
tester/covoar/ConfigFile.cc | 66 +++++++++++++++++++++++----------------------
tester/covoar/ConfigFile.h | 8 +++---
2 files changed, 37 insertions(+), 37 deletions(-)
diff --git a/tester/covoar/ConfigFile.cc b/tester/covoar/ConfigFile.cc
index 7109b2c..1fbefd1 100644
--- a/tester/covoar/ConfigFile.cc
+++ b/tester/covoar/ConfigFile.cc
@@ -21,9 +21,7 @@ static void print_invalid_line_number( const std::string& file, int line_no )
namespace Configuration {
- FileReader::FileReader(
- Options_t *options
+ FileReader::FileReader( Options_t *options )
options_m = options;
@@ -32,19 +30,18 @@ namespace Configuration {
- bool FileReader::processFile(
- const std::string& file
+ bool FileReader::processFile( const std::string& file )
#define METHOD "FileReader::processFile - "
#define MAX_LENGTH 256
std::ifstream in;
std::string line;
char option[MAX_LENGTH];
char value[MAX_LENGTH];
- int line_no;
- int i;
- int j;
+ int line_no;
+ int i;
+ int j;
if ( file.empty() ) {
std::cerr << METHOD << "Empty filename" << std::endl;
@@ -78,7 +75,7 @@ namespace Configuration {
* LHS = RHS # comment
- for (i=0 ; i<length ; i++ ) {
+ for ( i = 0; i < length; i++ ) {
if ( line[i] == '#' ) {
line[i] = '\0';
length = i;
@@ -89,46 +86,51 @@ namespace Configuration {
* Strip off trailing white space
- for (i=length-1 ; i>=0 && isspace(line[i]) ; i-- )
+ for ( i = length - 1; i >= 0 && isspace( line[i] ); i-- )
line[i+1] = '\0';
- length = i+1;
+ length = i + 1;
/* Ignore empty lines. We have stripped
* all comments and blanks therefore, only
* an empty string needs to be checked.
- if (line[0] == '\0')
+ if ( line[0] == '\0' ) {
continue;
- if (std::sscanf(line.c_str(), "%s", option) != 1) {
- print_invalid_line_number(file, line_no);
+ if ( std::sscanf( line.c_str(), "%s", option ) != 1 ) {
+ print_invalid_line_number( file, line_no );
continue;
- for (i=0; ((line[i] != '=') && (i<length)); i++)
+ for ( i=0; ( ( line[i] != '=' ) && ( i < length ) ); i++ )
- if (i == length) {
+ if ( i == length ) {
continue;
i++;
value[0] = '\0';
- while ( isspace(line[i]) )
+ while ( isspace( line[i] ) ) {
i++;
- for (j=0; line[i] != '\0'; i++, j++ )
+ for ( j = 0; line[i] != '\0'; i++, j++ ) {
value[j] = line[i];
value[j] = '\0';
- if (value[0] == '\0') {
+ if ( value[0] == '\0' ) {
continue;
- if ( !setOption(option, value) ) {
+ if ( !setOption( option, value ) ) {
continue;
@@ -142,36 +144,36 @@ namespace Configuration {
const char* const value
- Options_t *o;
+ Options_t* o;
- for ( o=options_m ; o->option ; o++ ) {
+ for ( o = options_m; o->option; o++ ) {
if ( !strcmp( o->option, option ) ) {
o->value = strdup( value );
return true;
return false;
- const char *FileReader::getOption(
- const char* const option
+ const char *FileReader::getOption( const char* const option )
Options_t *o;
return o->value;
return NULL;
- void FileReader::printOptions(void)
+ void FileReader::printOptions()
Options_t *o;
std::cerr << '(' << o->option << ")=(" << o->value << ')' << std::endl;
diff --git a/tester/covoar/ConfigFile.h b/tester/covoar/ConfigFile.h
index f8bd9c5..0339c12 100644
--- a/tester/covoar/ConfigFile.h
+++ b/tester/covoar/ConfigFile.h
@@ -53,9 +53,7 @@ namespace Configuration {
* @return Returns TRUE if the method succeeded and FALSE if it failed.
- virtual bool processFile(
+ virtual bool processFile( const std::string& file );
bool setOption(
const char* const option,
@@ -66,7 +64,7 @@ namespace Configuration {
- void printOptions(void);
+ void printOptions();
private:
@@ -78,7 +76,7 @@ namespace Configuration {
- Options_t *options_m;
+ Options_t* options_m;
1.8.3.1
