[PATCH 05/35] libfdt: fix undefined behaviour in fdt_splice_()
Sebastian Huber
Tue Dec 14 19:37:51 UTC 2021
Along the lines of commit d0b3ab0a0f46 ("libfdt: Fix undefined behaviour
in fdt_offset_ptr()"), fdt_splice_() similarly may not use pointer
arithmetic to do overflow checks. (The left side of the checks added by
d4c7c25c9ed1 ["libfdt: check for potential overrun in _fdt_splice()"]
doesn't really lend itself to similar replacement though.)
Signed-off-by: Jan Beulich <jbeulich at suse.com>
Message-Id: <f2d09e81-7cb8-c5cc-9699-1ac05b0626ff at suse.com>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
cpukit/dtc/libfdt/fdt_rw.c | 13 +++++++------
1 file changed, 7 insertions(+), 6 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt_rw.c b/cpukit/dtc/libfdt/fdt_rw.c
index 13854253ff..524b520c84 100644
--- a/cpukit/dtc/libfdt/fdt_rw.c
+++ b/cpukit/dtc/libfdt/fdt_rw.c
@@ -46,7 +46,7 @@ static int fdt_rw_probe_(void *fdt)
return err_; \
-static inline int fdt_data_size_(void *fdt)
+static inline unsigned int fdt_data_size_(void *fdt)
return fdt_off_dt_strings(fdt) + fdt_size_dt_strings(fdt);
@@ -54,15 +54,16 @@ static inline int fdt_data_size_(void *fdt)
static int fdt_splice_(void *fdt, void *splicepoint, int oldlen, int newlen)
char *p = splicepoint;
- char *end = (char *)fdt + fdt_data_size_(fdt);
+ unsigned int dsize = fdt_data_size_(fdt);
+ size_t soff = p - (char *)fdt;
- if (((p + oldlen) < p) || ((p + oldlen) > end))
+ if ((oldlen < 0) || (soff + oldlen < soff) || (soff + oldlen > dsize))
return -FDT_ERR_BADOFFSET;
- if ((p < (char *)fdt) || ((end - oldlen + newlen) < (char *)fdt))
+ if ((p < (char *)fdt) || (dsize + newlen < oldlen))
- if ((end - oldlen + newlen) > ((char *)fdt + fdt_totalsize(fdt)))
+ if (dsize - oldlen + newlen > fdt_totalsize(fdt))
return -FDT_ERR_NOSPACE;
- memmove(p + newlen, p + oldlen, end - p - oldlen);
+ memmove(p + newlen, p + oldlen, ((char *)fdt + dsize) - (p + oldlen));
return 0;
2.31.1
