[PATCH 00/35] Update libfdt
Sebastian Huber
Tue Dec 14 19:37:46 UTC 2021
This patch set updates libfdt (which is a part of the dtc repository) to
the latest version.
Andre Przywara (14):
libfdt: fdt_offset_ptr(): Fix comparison warnings
libfdt: fdt_mem_rsv(): Fix comparison warnings
libfdt: fdt_grab_space_(): Fix comparison warning
libfdt: fdt_splice_(): Fix comparison warning
libfdt: fdt_resize(): Fix comparison warning
libfdt: fdt_node_offset_by_phandle(): Fix comparison warning
libfdt: fdt_add_string_(): Fix comparison warning
libfdt: fdt_move(): Fix comparison warnings
libfdt: fdt_create_with_flags(): Fix comparison warning
libfdt: libfdt_wip: Fix comparison warning
libfdt: fdt_get_string(): Fix sequential write comparison warnings
libfdt: fdt_strerror(): Fix comparison warning
libfdt: Fix kernel-doc comments
fdtget: Fix signedness comparisons warnings
David Gibson (3):
libfdt: Tweak description of assume-aligned load helpers
libfdt: Fix a possible "unchecked return value" warning
Fix CID 1461557
Elvira Khabirova (1):
libfdt: fix an incorrect integer promotion
Frank Mehnert (1):
libfdt: fix fdt_check_node_offset_ w/ VALID_INPUT
Georg Kotheimer (1):
libfdt: Add ALIGNMENT error string
Jan Beulich (1):
libfdt: fix undefined behaviour in fdt_splice_()
Justin Covell (1):
Set last_comp_version correctly in new dtb and fix potential version
issues in fdt_open_into
Patrick Oppenlander (2):
libfdt: trivial typo fix
libfdt: add extern "C" for C++
Rob Herring (1):
libfdt: Add FDT alignment check to fdt_check_header()
Sebastian Huber (1):
dtc: Update VERSION
Simon Glass (6):
libfdt: Fix a few typos
libfdt: Improve comments in some of the assumptions
libfdt: Add support for disabling internal checks
libfdt: Use VALID_INPUT for FDT_ERR_BADSTATE checks
libfdt: Correct condition for reordering blocks
libfdt: fdt_get_string(): Fix comparison warnings
Tom Rini (2):
libfdt: Check for 8-byte address alignment in fdt_ro_probe_()
libfdt: Internally perform potentially unaligned loads
Vikram Garhwal (1):
libfdt: overlay: make overlay_get_target() public
cpukit/dtc/VERSION | 6 +-
cpukit/dtc/libfdt/fdt.c | 41 ++++++--
cpukit/dtc/libfdt/fdt_addresses.c | 2 +-
cpukit/dtc/libfdt/fdt_ro.c | 44 ++++----
cpukit/dtc/libfdt/fdt_rw.c | 37 ++++---
cpukit/dtc/libfdt/fdt_strerror.c | 5 +-
cpukit/dtc/libfdt/fdt_sw.c | 38 ++++---
cpukit/dtc/libfdt/fdt_wip.c | 2 +-
cpukit/dtc/libfdt/libfdt_internal.h | 49 +++++++--
cpukit/include/libfdt.h | 157 ++++++++++++++++++++--------
10 files changed, 264 insertions(+), 117 deletions(-)
2.31.1
