[PATCH 12/35] libfdt: fdt_grab_space_(): Fix comparison warning
Tue Dec 14 19:37:58 UTC 2021
With -Wsign-compare, compilers warn about a mismatching signedness
in a comparison in fdt_grab_space_().
All the involved values cannot be negative, so let's switch the types of
the local variables to unsigned to make the compiler happy.
Signed-off-by: Andre Przywara <andre.przywara at arm.com>
Message-Id: <20200921165303.9115-4-andre.przywara at arm.com>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/dtc/libfdt/fdt_sw.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt_sw.c b/cpukit/dtc/libfdt/fdt_sw.c
index 94ce4bb91a..d10a720f94 100644
--- a/cpukit/dtc/libfdt/fdt_sw.c
+++ b/cpukit/dtc/libfdt/fdt_sw.c
@@ -93,8 +93,8 @@ static inline uint32_t sw_flags(void *fdt)
 static void *fdt_grab_space_(void *fdt, size_t len)
-	int offset = fdt_size_dt_struct(fdt);
-	int spaceleft;
+	unsigned int offset = fdt_size_dt_struct(fdt);
+	unsigned int spaceleft;
 	spaceleft = fdt_totalsize(fdt) - fdt_off_dt_struct(fdt)
 		- fdt_size_dt_strings(fdt);
2.31.1
