[PATCH 09/35] libfdt: fix fdt_check_node_offset_ w/ VALID_INPUT
Tue Dec 14 19:37:55 UTC 2021
From: Frank Mehnert <frank.mehnert at kernkonzept.com>
fdt_check_node_offset_() checks for a valid offset but also changes the
offset by calling fdt_next_tag(). Hence, do not skip this function if
ASSUME_VALID_INPUT is set but only omit the initial offset check in that
case.
As this function works very similar to fdt_check_prop_offset_(), do the
offset check there as well depending on ASSUME_VALID_INPUT.
Message-Id: <1913141.TlUzK5foHS at noys4>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/dtc/libfdt/fdt.c | 16 ++++++++++------
 1 file changed, 10 insertions(+), 6 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt.c b/cpukit/dtc/libfdt/fdt.c
index c28fcc1157..37b7b93556 100644
--- a/cpukit/dtc/libfdt/fdt.c
+++ b/cpukit/dtc/libfdt/fdt.c
@@ -206,10 +206,11 @@ uint32_t fdt_next_tag(const void *fdt, int startoffset, int *nextoffset)
 int fdt_check_node_offset_(const void *fdt, int offset)
-	if (can_assume(VALID_INPUT))
-		return offset;
-	if ((offset < 0) || (offset % FDT_TAGSIZE)
-	    || (fdt_next_tag(fdt, offset, &offset) != FDT_BEGIN_NODE))
+	if (!can_assume(VALID_INPUT)
+	    && ((offset < 0) || (offset % FDT_TAGSIZE)))
+		return -FDT_ERR_BADOFFSET;
+	if (fdt_next_tag(fdt, offset, &offset) != FDT_BEGIN_NODE)
 	return offset;
@@ -217,8 +218,11 @@ int fdt_check_node_offset_(const void *fdt, int offset)
 int fdt_check_prop_offset_(const void *fdt, int offset)
-	    || (fdt_next_tag(fdt, offset, &offset) != FDT_PROP))
+	if (fdt_next_tag(fdt, offset, &offset) != FDT_PROP)
 	return offset;
2.31.1
