[PATCH 22/35] libfdt: fdt_strerror(): Fix comparison warning
Tue Dec 14 19:38:08 UTC 2021
With -Wsign-compare, compilers warn about a mismatching signedness
in a comparison in fdt_strerror().
Force FDT_ERRTABSIZE to be signed (it's surely small enough to fit), so
that the types match. Also move the minus sign to errval, as this is
actually what we use in the next line.
Signed-off-by: Andre Przywara <andre.przywara at arm.com>
Message-Id: <20201001164630.4980-7-andre.przywara at arm.com>
Signed-off-by: David Gibson <david at gibson.dropbear.id.au>
 cpukit/dtc/libfdt/fdt_strerror.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/cpukit/dtc/libfdt/fdt_strerror.c b/cpukit/dtc/libfdt/fdt_strerror.c
index 768db66ead..b4356931b0 100644
--- a/cpukit/dtc/libfdt/fdt_strerror.c
+++ b/cpukit/dtc/libfdt/fdt_strerror.c
@@ -40,7 +40,7 @@ static struct fdt_errtabent fdt_errtable[] = {
 	FDT_ERRTABENT(FDT_ERR_NOPHANDLES),
 	FDT_ERRTABENT(FDT_ERR_BADFLAGS),
-#define FDT_ERRTABSIZE	(sizeof(fdt_errtable) / sizeof(fdt_errtable[0]))
+#define FDT_ERRTABSIZE	((int)(sizeof(fdt_errtable) / sizeof(fdt_errtable[0])))
 const char *fdt_strerror(int errval)
@@ -48,7 +48,7 @@ const char *fdt_strerror(int errval)
 		return "<valid offset/length>";
 	else if (errval == 0)
 		return "<no error>";
-	else if (errval > -FDT_ERRTABSIZE) {
+	else if (-errval < FDT_ERRTABSIZE) {
 		const char *s = fdt_errtable[-errval].str;
 		if (s)
2.31.1
