[PATCH 33/35] libfdt: fix an incorrect integer promotion
Sebastian Huber
Tue Dec 14 19:38:19 UTC 2021
UINT32_MAX is an integer of type unsigned int. UINT32_MAX + 1 overflows
unless explicitly computed as unsigned long long. This led to some
invalid addresses being treated as valid.
Cast UINT32_MAX to uint64_t explicitly.
Signed-off-by: Elvira Khabirova <e.khabirova at omp.ru>
cpukit/dtc/libfdt/fdt_addresses.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/cpukit/dtc/libfdt/fdt_addresses.c b/cpukit/dtc/libfdt/fdt_addresses.c
index 9a82cd0ba2..c40ba094f1 100644
--- a/cpukit/dtc/libfdt/fdt_addresses.c
+++ b/cpukit/dtc/libfdt/fdt_addresses.c
@@ -73,7 +73,7 @@ int fdt_appendprop_addrrange(void *fdt, int parent, int nodeoffset,
/* check validity of address */
prop = data;
if (addr_cells == 1) {
- if ((addr > UINT32_MAX) || ((UINT32_MAX + 1 - addr) < size))
+ if ((addr > UINT32_MAX) || (((uint64_t) UINT32_MAX + 1 - addr) < size))
return -FDT_ERR_BADVALUE;
fdt32_st(prop, (uint32_t)addr);
2.31.1
