New validation test suites
Sebastian Huber
Thu Dec 16 07:36:04 UTC 2021
On 16/12/2021 04:51, Chris Johns wrote:
> On 16/12/21 3:27 am, Sebastian Huber wrote:
>> On 15/12/2021 06:46, Chris Johns wrote:
>>> On 14/12/21 6:24 pm, Sebastian Huber wrote:
>>>> Hello Chris,
>>>> On 13/12/2021 22:01, Chris Johns wrote:
>>>>> On 14/12/21 1:53 am, Sebastian Huber wrote:
>>>>>> We finished the specification of the pre-qualified RTEMS feature set. The
>>>>>> specification is available in an RTEMS Project repository:
>>>>>> https://git.rtems.org/rtems-central/tree/spec
>>>>> I had a quick look. Is there a more user friendly view of this data?
>>>>> I think the term "specification" is a little bit misleading because the data
>>>>> files are not easily read by a person. I understand this is the specification
>>>>> data set however it is not what I am traditionally use to seeing.
>>>> You can use the "./specview.py" script to get views of the specification. For
>>>> example, this command displays the transition map for the rtems_signal_send()
>>>> directive:
>>> Is specview.py part of rtems.git?
>> No, this script is in rtems-central. This is also the location of the
>> specification items.
> I am not sure linking a script from that repo like this is helpful.
>>> If not part of rtems.git how much data is there for all the output? That is it
>>> is generated and held in the repo with the tests?
>> In rtems.git, there are only the generated sources.
> There should be no reach back to the upstream specs, scripts etc and for good
> reasons. The information you posted is nice and useful and I do not wish to
> release manage rtems-central to accommodate these tests in a release.
> Would capturing that information with the tests be something worth doing?
I don't think it would be useful. If you want to modify the tests you
should work with the specification items and the corresponding scripts.
Adding the tables as comments would blow up the sources considerably.
Some tests have about 50000 table entries and the table entries depend
on C preprocessor defines.
>>>> In an earlier version of the header, we had a link which you didn't like:
>>> If I need to look at the formatting rules the heading "Software Development
>>> Management" is easy to see and then a click on "Coding Standards" gives me what
>>> I am looking for.
>>> To generate these headers I click on "Software Requirements Engineering" and
>>> then do I just guess until I find it in the "How To" section? I am actually
>>> asking this be sorted out so it is not left hanging and we are not left guessing
>>> what to do. If it can be rearrange into something meaningful it would help. :)
>> Well, if you read the text in the header:
>> * For information on updating and regenerating please refer to the How-To
>> * section in the Software Requirements Engineering chapter of the
>> * RTEMS Software Engineering manual. The manual is provided as a part of
>> * a release. For development sources please refer to the online
>> * documentation at:
>> * https://docs.rtems.org
>> You should read the How-to section or not?
> Yes I should have and thanks for pointing this out but I did not see this and
> the manual as it stands did not help. I think it should change. It can be
> performed post this patch set but I think the documentation would read better if
> changed.
Could you please make a suggestions how the text should be changed?
>>>>> What hardware have the validation tests been run on? Any tier 1 archs?
>>>> I tested with the sparc/leon3 BSPs and the arm/realview_pbx_a9_qemu.
>>> Is the leon3 tested on hardware or simulation?
>>>> You need a
>>>> full implementation of the new Interrupt Manager directives and a working Cache
>>>> Manager implementation.
>>> Is this documented?
>>> I am sorry I do not know the list of archs and bsps that support the new
>>> interrupt manager directives. Maybe it would be good to list them?
>> All BSPs have at least a stub implementation of the new directives. The
>> directives are tested in a dedicated test suite. You will notice failures in
>> this test suite if the directives are not implemented.
> Are these expected failures?
Yes, they would be expected failures. I can add the test information.
For which BSPs should I do this?
>>>> I noticed an issue with the thread restart on aarch64/a53_lp64_qemu.
>>>> On powerpc/psim there is an issue in one test case, due to:
>>>> #define CPU_ALL_TASKS_ARE_FP CPU_HARDWARE_FP
>>> Sorry, I am not following what the issue is? Does this effect all PPC BSPS?
>> Not all, the newer BSPs have no separate floating-point context.
> Which ones have the issue, the newer BSPs or the older ones?
The older ones.
>> This is something which needs to be fixed in the specification.
> Of?
> < From my point of view this is just a minor issue.
> As in fixing these tests?
>>>> Another issue is that the tm27 interrupt must be independent of the clock driver
>>>> interrupt. This is not the case for powerpc/psim.
>>>> There is definitely some work left to cover all edge cases. Some tests are quite
>>>> complicated.
>>> Sure. I would like to understand the effects this has?
>> Maybe I can rearrange the test cases so that the tm27 support is only used if no
>> clock driver is needed. The tm27 support is used to run handlers in interrupt
>> context.
> OK.
I will try to fix these issues, but this will delay the integration for
a couple of weeks.
>>>>> Is there anything that interprets the new test output format? It looks like
>>>>> lots
>>>>> of great info but a little difficult to read.
>>>> EDISOFT worked on a test report generator, however, it is not yet in a
>>>> reviewable state.
>>> OK. I think something that handles this data would be good to have.
>> Yes, maybe we could let a student work on this. In theory, this is not
>> difficult. Read the report.yaml generated by the RTEMS Tester and convert it to
>> a Python objects representation. Then use this high-level representation to
>> generate a report in format X.
> Sounds good.
> And we need to get all the BSPs baselined with 0 failures so we know where we
> stand as changes are being made.
All BSPs is a bit too much.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
