[PATCH] c-user: Clarify time formats
Joel Sherrill
joel at rtems.org
Thu Dec 16 14:36:00 UTC 2021
This looks good.
Will bintime and sbintime show up in the index?
On Thu, Dec 16, 2021 at 1:21 AM Sebastian Huber
> Update #4572.
> c-user/clock/background.rst | 33 +++++++++++++++++++++------------
> 1 file changed, 21 insertions(+), 12 deletions(-)
> diff --git a/c-user/clock/background.rst b/c-user/clock/background.rst
> index 64e8311..9e76a02 100644
> --- a/c-user/clock/background.rst
> +++ b/c-user/clock/background.rst
> @@ -1,5 +1,6 @@
> .. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
> .. Copyright (C) 1988, 2008 On-Line Applications Research Corporation (OAR)
> Background
> @@ -29,7 +30,7 @@ and date format:
> .. code-block:: c
> - struct rtems_tod_control {
> + typedef struct {
> uint32_t year; /* greater than 1987 */
> uint32_t month; /* 1 - 12 */
> uint32_t day; /* 1 - 31 */
> @@ -37,20 +38,28 @@ and date format:
> uint32_t minute; /* 0 - 59 */
> uint32_t second; /* 0 - 59 */
> uint32_t ticks; /* elapsed between seconds */
> - typedef struct rtems_tod_control rtems_time_of_day;
> + } rtems_time_of_day;
> The native date and time format is the only format supported when setting the
> -system date and time using the ``rtems_clock_set`` directive. Some
> +system date and time using the :ref:`InterfaceRtemsClockSet` directive. Some
> applications expect to operate on a *UNIX-style* date and time data structure.
> -The ``rtems_clock_get_tod_timeval`` always returns the date and time in
> -``struct timeval`` format.
> -The ``struct timeval`` data structure has two fields: ``tv_sec`` and
> -``tv_usec`` which are seconds and microseconds, respectively. The ``tv_sec``
> -field in this data structure is the number of seconds since the POSIX epoch of
> -*January 1, 1970* but will never be prior to the RTEMS epoch of *January 1,
> -1988*.
> +For example, the :ref:`InterfaceRtemsClockGetTodTimeval` returns the date and
> +time in ``struct timeval`` format.
> +Some directives use data structures defined by :term:`POSIX`. The ``struct
> +timeval`` data structure has two members: ``tv_sec`` and ``tv_usec`` which are
> +seconds and microseconds, respectively. The ``struct timespec`` data structure
> +has two members: ``tv_sec`` and ``tv_nsec`` which are seconds and nanoseconds,
> +respectively. For :term:`CLOCK_REALTIME` time points, the ``tv_sec`` member in
> +these data structures is the number of seconds since the :term:`Unix epoch` but
> +will never be prior to the :term:`RTEMS epoch`.
> +The ``struct bintime`` and ``sbintime_t`` time formats used by some directives
> +originate in FreeBSD. The ``struct bintime`` data structure which represents
> +time in a binary time format has two members: ``sec`` and ``frac`` which are
> +seconds and fractions of a second in units of :math:`1 / 2^{64}` seconds,
> +respectively. The ``sbintime_t`` type is a signed 64-bit integer type used to
> +represent time in units of :math:`1 / 2^{32}` seconds.
> .. index:: timeslicing
> 2.31.1
> devel mailing list
> devel at rtems.org
