[PATCH rtems-docs] Update package list for Ubuntu
Karel Gardas karel at functional.vision
Fri Dec 17 21:56:54 UTC 2021
On 12/17/21 10:52 PM, Ryan Long wrote:
> Ah, I thought they only put the .04 on the LTS releases. I'll change
> that and send in V2.
No LTS line is 12.04, 14.04, 16.04, 18.04, 20.04 and next future is
22.04. Always released in April of the year (hence .04) and the number
before it is obviously year number.
Basically since LTS does not change that much or should not besides
security fixes and perhaps hardware support, then you can freely use
"Ubuntu 20.04.x LTS" since I guess RTEMS will not find difference
between .1, .2, .3 spins of 20.04.
Thanks,
Karel
> On 12/17/2021 3:49 PM, Karel Gardas wrote:
>> On 12/17/21 10:35 PM, Ryan Long wrote:
>>> diff --git a/user/hosts/posix.rst b/user/hosts/posix.rst
>>> index 818eb25..6fbf401 100644
>>> --- a/user/hosts/posix.rst
>>> +++ b/user/hosts/posix.rst
>>> @@ -137,23 +137,23 @@ prefix under your home directory as recommended
>>> and end up on the SD card.
>>>   Ubuntu
>>>   -The latest version is Ubuntu 18.04.1 LTS 64-bit. This section also
>>> includes
>>> +The latest version is Ubuntu 21.04.1 LTS 64-bit. This section also
>>> includes
>> This is certainly not correct. Either you mean 20.04.03 LTS or you mean
>> regular Ubuntu which is 21.10 of this time (and no "LTS" attached!).
>> Simply your version "21.04.1 LTS" is non existent in this galaxy...
>> Cheers,
>> Karel
