qemu (gettext) build failure on FreeBSD 12
Sun Dec 19 23:52:03 UTC 2021
Hi
Any FreeBSD users have an idea how to resolve this build failure?
Thanks
/bin/sh ../libtool  --tag=CC   --mode=link /usr/bin/cc -O2 -pipe
-fbracket-depth=1024
-I/usr/home/tester/rtems-cron-6/rtems-source-builder/bare/build/tmp/sb-1002/devel/qemu/home/tester/rtems-cron-6/tools/6/include
   -no-undefined   ../intl/libintl.la     -fopenmp  -release 0.18.3
-L/usr/home/tester/rtems-cron-6/rtems-source-builder/bare/build/tmp/sb-1002/devel/qemu/home/tester/rtems-cron-6/tools/6/lib
-lglib-2.0 -lpthread
-lintl -R/usr/home/tester/rtems-cron-6/rtems-source-builder/bare/build/tmp/sb-1002/devel/qemu/home/tester/rtems-cron-6/tools/6/lib
   -lncurses -L/usr/home/tester/rtems-cron-6/rtems-source-builder/bare/build/tmp/sb-1002/devel/qemu/home/tester/rtems-cron-6/tools/6/lib
-o libgettextlib.la -rpath /home/tester/rtems-cron-6/tools/6/lib
copy-acl.lo set-acl.lo allocator.lo areadlink.lo argmatch.lo
gl_array_list.lo backupfile.lo addext.lo basename.l
 o binary-io.lo c-ctype.lo c-strcasecmp.lo c-strncasecmp.lo
c-strcasestr.lo c-strstr.lo careadlinkat.lo classpath.lo clean-temp.lo
cloexec.lo closeout.lo concat-filename.lo copy-file.lo csharpcomp.lo
csharpexec.lo error-progname.lo execute.lo exitfail.lo fatal-signal.lo
fd-hook.lo fd-ostream.lo fd-safer-flag.lo dup-safer-flag.lo
file-ostream.lo findprog.lo fstrcmp.lo full-write.lo fwriteerror.lo
gcd.lo  hash.lo html-ostream.lo html-styled-ostream.lo  javacomp.lo
javaexec.lo javaversion.lo gl_linkedhash_list.lo gl_list.lo
localcharset.lo localename.lo glthread/lock.lo malloca.lo mbchar.lo
mbiter.lo mbslen.lo mbsstr.lo mbswidth.lo mbuiter.lo ostream.lo
pipe-filter-ii.lo pipe-filter-aux.lo pipe2.lo pipe2-safer.lo
progname.lo propername.lo acl-errno-valid.lo file-has-acl.lo
qcopy-acl.lo qset-acl.lo quotearg.lo safe-read.lo safe-write.lo
sh-quote.lo sig-handler.lo spawn-pipe.lo striconv.lo striconveh.lo
striconveha.lo strnlen1.lo styled-ostream.lo tempname.lo
term-ostream.lo term-styled-o
 stream.lo  glthread/threadlib.lo glthread/tls.lo tmpdir.lo trim.lo
uniconv/u8-conv-from-enc.lo unilbrk/lbrktables.lo
unilbrk/u8-possible-linebreaks.lo unilbrk/u8-width-linebreaks.lo
unilbrk/ulc-common.lo unilbrk/ulc-width-linebreaks.lo
uniname/uniname.lo unistd.lo dup-safer.lo fd-safer.lo pipe-safer.lo
unistr/u16-mbtouc.lo unistr/u16-mbtouc-aux.lo unistr/u8-check.lo
unistr/u8-mblen.lo unistr/u8-mbtouc.lo unistr/u8-mbtouc-aux.lo
unistr/u8-mbtouc-unsafe.lo unistr/u8-mbtouc-unsafe-aux.lo
unistr/u8-mbtoucr.lo unistr/u8-prev.lo unistr/u8-uctomb.lo
unistr/u8-uctomb-aux.lo uniwidth/width.lo wait-process.lo wctype-h.lo
xmalloc.lo xstrdup.lo xconcat-filename.lo xerror.lo gl_xlist.lo
xmalloca.lo xreadlink.lo xsetenv.lo xsize.lo xstriconv.lo
xstriconveh.lo xvasprintf.lo xasprintf.lo acl_entries.lo asnprintf.lo
canonicalize-lgpl.lo error.lo getopt.lo getopt1.lo obstack.lo
printf-args.lo printf-parse.lo rawmemchr.lo secure_getenv.lo
spawn_faction_addclose.lo spawn_faction_adddup2.lo spawn_factio
 n_addopen.lo vasnprintf.lo libcroco_rpl.la  libxml_rpl.la
libtool: link: warning: library
`/usr/home/tester/rtems-cron-6/rtems-source-builder/bare/build/tmp/sb-1002/devel/qemu/home/tester/rtems-cron-6/tools/6/lib/libglib-2.0.la'
was moved.
grep: /home/tester/rtems-cron-6/tools/6/lib/libintl.la: No such file
or directory
/usr/bin/sed: can't read
/home/tester/rtems-cron-6/tools/6/lib/libintl.la: No such file or
directory
libtool: link: `/home/tester/rtems-cron-6/tools/6/lib/libintl.la' is
not a valid libtool archive
gmake[4]: *** [Makefile:2507: libgettextlib.la] Error 1
