Alternative download paths for RSB?
Mon Dec 20 21:52:23 UTC 2021
On 21/12/21 2:33 am, Joel Sherrill wrote:
> On Mon, Dec 20, 2021 at 8:54 AM Joel Sherrill <joel at rtems.org> wrote:
>> On Mon, Dec 20, 2021 at 6:59 AM Sebastian Huber
>> <sebastian.huber at embedded-brains.de> wrote:
>>> Hello,
>>> it seems the GNU web server is down:
>> Yep. Still down.
>> i reached out to the sourceware admins to see if they knew who to
>> contact. I couldn't find a gnu.org address.
> Social media post from FSF forwarded by one of the sourceware admins
> about a general outage at the FSF:
> https://hostux.social/@fsfstatus/107479476196064925
> Looks to be up now. RSB handling mirrors would be good. Although
> it would seem to be complex to ensure that all entries and mirrors are
> correct.
>>> download: https://ftp.gnu.org/gnu/mpfr/mpfr-3.1.4.tar.bz2 ->
>>> sources/mpfr-3.1.4.tar.bz2
>>> download: https://ftp.gnu.org/gnu/mpfr/mpfr-3.1.4.tar.bz2: error:
>>> <urlopen error [Errno 101] Network is unreachable>
>>> error: downloading https://ftp.gnu.org/gnu/mpfr/mpfr-3.1.4.tar.bz2: all
>>> paths have failed, giving up
>>> Build FAILED
>>> Build Set: Time 0:04:23.318509
>>> Build FAILED
>>> The error message suggests that it is possible to add alternative
>>> download sources. How can I do this? This didn't work:
>>> diff --git a/source-builder/config/gcc-9.cfg
>>> b/source-builder/config/gcc-9.cfg
>>> index f8cf69b..1d7c716 100644
>>> --- a/source-builder/config/gcc-9.cfg
>>> +++ b/source-builder/config/gcc-9.cfg
>>> @@ -21,4 +21,8 @@
>>>   %source set gmp https://ftp.gnu.org/gnu/gmp/gmp-%{gmp_version}.tar.bz2
>>>   %source set mpfr https://ftp.gnu.org/gnu/mpfr/mpfr-%{mpfr_version}.tar.bz2
>>> +%source set mpc
>>> https://ftp.mpi-inf.mpg.de/pub/mirrors/gnu/mirror/gcc.gnu.org/pub/gcc/infrastructure/mpc-%{mpc_version}.tar.gz
>>> +%source set gmp
>>> https://ftp.mpi-inf.mpg.de/pub/mirrors/gnu/mirror/gcc.gnu.org/pub/gcc/infrastructure/gmp-%{gmp_version}.tar.bz2
>>> +%source set mpfr
>>> https://ftp.mpi-inf.mpg.de/pub/mirrors/gnu/mirror/gcc.gnu.org/pub/gcc/infrastructure/mpfr-%{mpfr_version}.tar.bz2
>>>   %include %{_configdir}/gcc-common-1.cfg
>> This would be Chris' department. Sorry
I would update the `%source` keyword to accept:
%source mirror mpc 1 https://ftp.mpi-inf.mpg.de/../mpc-%{mpc_version}.tar.gz
where `1` is an integer priority and 1 is highest. The code is here:
https://git.rtems.org/rtems-source-builder/tree/source-builder/sb/sources.py#n55
There is no such thing as a list in the macros so I suspect you would need to
dereference the source where the results of `_make_key` would reference another
series of macro keys that are the mirrors.
Do we want to start maintaining lists of mirrors in RSB configurations? I am
undecided. As developers we do not notice the online status due to the RSB
cache. For sites and users would deployment be a better long term solution?
