[PATCH rtems-tools v1] ReportsBase: Change raw pointer to unique_ptr
Chris Johns
chrisj at rtems.org
Mon Dec 20 23:03:12 UTC 2021
On 21/12/21 7:24 am, Ryan Long wrote:
> Replaced raw pointer used with ReportsBase-derived classes to make code
> cleaner and make it to where pointers do not have to be manually
> deleted.
> Closes #4376
> tester/covoar/ReportsBase.cc | 21 ++++++---------------
> 1 file changed, 6 insertions(+), 15 deletions(-)
> diff --git a/tester/covoar/ReportsBase.cc b/tester/covoar/ReportsBase.cc
> index 219e5af..8ec65c0 100644
> --- a/tester/covoar/ReportsBase.cc
> +++ b/tester/covoar/ReportsBase.cc
> @@ -591,17 +591,16 @@ void GenerateReports(
> bool branchInfoAvailable
> - typedef std::list<ReportsBase *> reportList_t;
> + typedef std::vector<std::unique_ptr<ReportsBase>> reportList_t;
Are we OK to use `*_t` in types?
Plus I have moved to ...
using reportList = std::vector<std::unique_ptr<ReportsBase>>
so I would use the following to avoid '>>':
using reportList_ptr = std::unique_ptr<ReportsBase>;
using reportLists = std::vector<reportList_ptr>;
The vector is a container of report lists and not a container of report list
singular.
A minor point, I do not embed the container type into the type alias because
someone may decide to change this to `std::deque` or `std::forward_list` and the
name becomes misleading.
> reportList_t reportList;
Then make this `reports`.
> reportList_t::iterator ritr;
> std::string reportName;
> - ReportsBase* reports;
> time_t timestamp;
> timestamp = time( NULL ); /* get current cal time */
> - reports = new ReportsText(
> + reportList.emplace_back(new ReportsText(
Should `std::make_unique<ReportsText>(...)` be used?
Thanks
> timestamp,
> symbolSetName,
> allExplanations,
> @@ -609,9 +608,8 @@ void GenerateReports(
> outputDirectory,
> symbolsToAnalyze,
> branchInfoAvailable
> - reportList.push_back( reports );
> - reports = new ReportsHtml(
> + reportList.emplace_back(new ReportsHtml(
> timestamp,
> symbolSetName,
> allExplanations,
> @@ -619,11 +617,9 @@ void GenerateReports(
> outputDirectory,
> symbolsToAnalyze,
> branchInfoAvailable
> - for ( ritr = reportList.begin(); ritr != reportList.end(); ritr++ ) {
> - reports = *ritr;
> + for ( auto& reports: reportList ) {
> reportName = "index" + reports->ReportExtension();
> if ( verbose ) {
> @@ -662,11 +658,6 @@ void GenerateReports(
> reports->WriteSymbolSummaryReport( reportName, symbolsToAnalyze );
> - reports = *ritr;
> - delete reports;
> ReportsBase::WriteSummaryReport(
> "summary.txt",
> symbolSetName,
