[PATCH v2] ReportsBase: Change raw pointer to unique_ptr
    Chris Johns
    chrisj at rtems.org
    Wed Dec 22 03:58:55 UTC 2021
OK
Thanks
On 22/12/21 7:49 am, Ryan Long wrote:
> Replaced raw pointer used with ReportsBase-derived classes to make code
> cleaner and make it to where pointers do not have to be manually
> deleted.
> Closes #4376
>  tester/covoar/ReportsBase.cc | 77 +++++++++++++++++++++-----------------------
>  1 file changed, 36 insertions(+), 41 deletions(-)
> diff --git a/tester/covoar/ReportsBase.cc b/tester/covoar/ReportsBase.cc
> index 219e5af..0fb9ce0 100644
> --- a/tester/covoar/ReportsBase.cc
> +++ b/tester/covoar/ReportsBase.cc
> @@ -591,80 +591,75 @@ void GenerateReports(
>    bool                            branchInfoAvailable
> -  typedef std::list<ReportsBase *> reportList_t;
> +  using reportList_ptr = std::unique_ptr<ReportsBase>;
> +  using reportList = std::vector<reportList_ptr>;
> -  reportList_t           reportList;
> -  reportList_t::iterator ritr;
> +  reportList             reports;
>    std::string            reportName;
> -  ReportsBase*           reports;
>    time_t                 timestamp;
>    timestamp = time( NULL ); /* get current cal time */
> -  reports = new ReportsText(
> -    timestamp,
> -    symbolSetName,
> -    allExplanations,
> -    projectName,
> -    outputDirectory,
> -    symbolsToAnalyze,
> -    branchInfoAvailable
> +  reports.emplace_back(
> +    new ReportsText(
> +      timestamp,
> +      symbolSetName,
> +      allExplanations,
> +      projectName,
> +      outputDirectory,
> +      symbolsToAnalyze,
> +      branchInfoAvailable
> -  reportList.push_back( reports );
> -  reports = new ReportsHtml(
> -    timestamp,
> -    symbolSetName,
> -    allExplanations,
> -    projectName,
> -    outputDirectory,
> -    symbolsToAnalyze,
> +    new ReportsHtml(
> +      timestamp,
> +      symbolSetName,
> +      allExplanations,
> +      projectName,
> +      outputDirectory,
> +      symbolsToAnalyze,
> -  for ( ritr = reportList.begin(); ritr != reportList.end(); ritr++ ) {
> -    reports = *ritr;
> +  for ( auto& report: reports ) {
> -    reportName = "index" + reports->ReportExtension();
> +    reportName = "index" + report->ReportExtension();
>      if ( verbose ) {
>        std::cerr << "Generate " << reportName << std::endl;
> -    reports->WriteIndex( reportName );
> +    report->WriteIndex( reportName );
> -    reportName = "annotated" + reports->ReportExtension();
> +    reportName = "annotated" + report->ReportExtension();
>      if ( verbose ) {
> -    reports->WriteAnnotatedReport( reportName );
> +    report->WriteAnnotatedReport( reportName );
> -    reportName = "branch" + reports->ReportExtension();
> +    reportName = "branch" + report->ReportExtension();
>      if ( verbose ) {
> -    reports->WriteBranchReport( reportName );
> +    report->WriteBranchReport( reportName );
> -    reportName = "uncovered" + reports->ReportExtension();
> +    reportName = "uncovered" + report->ReportExtension();
>      if ( verbose ) {
> -    reports->WriteCoverageReport( reportName );
> +    report->WriteCoverageReport( reportName );
> -    reportName = "sizes" + reports->ReportExtension();
> +    reportName = "sizes" + report->ReportExtension();
>      if ( verbose ) {
> -    reports->WriteSizeReport( reportName );
> +    report->WriteSizeReport( reportName );
> -    reportName = "symbolSummary" + reports->ReportExtension();
> +    reportName = "symbolSummary" + report->ReportExtension();
>      if ( verbose ) {
> -    reports->WriteSymbolSummaryReport( reportName, symbolsToAnalyze );
> -    reports = *ritr;
> -    delete reports;
> +    report->WriteSymbolSummaryReport( reportName, symbolsToAnalyze );
>    ReportsBase::WriteSummaryReport(
