[PATCH v2] score: Define _Assert() for static analysis runs
Mon Feb 1 06:06:48 UTC 2021
The goal is to reduce false positive NULL_RETURNS,
PW.NORETURN_FUNCTION_DOES_RETURN, PW.SET_BUT_NOT_USED,
UNUSED_VALUE, etc. issues produced by Coverity.
Define RTEMS_STATIC_ANALYSIS if a static analysis run by Coverity is
performed.
 cpukit/include/rtems/score/assert.h   |  4 ++--
 cpukit/include/rtems/score/basedefs.h | 11 +++++++++++
 2 files changed, 13 insertions(+), 2 deletions(-)
diff --git a/cpukit/include/rtems/score/assert.h b/cpukit/include/rtems/score/assert.h
index 2bf1703f19..cc3244844c 100644
--- a/cpukit/include/rtems/score/assert.h
+++ b/cpukit/include/rtems/score/assert.h
@@ -46,9 +46,9 @@ extern "C" {
  * @brief Assertion similar to assert() controlled via RTEMS_DEBUG instead of
- * NDEBUG.
+ *   NDEBUG and static analysis runs.
-#if defined( RTEMS_DEBUG )
+#if defined( RTEMS_DEBUG ) || defined( RTEMS_STATIC_ANALYSIS )
    * @brief Macro with method name used in assert output
diff --git a/cpukit/include/rtems/score/basedefs.h b/cpukit/include/rtems/score/basedefs.h
index a98b80f0dd..fe5f4ab7c7 100644
--- a/cpukit/include/rtems/score/basedefs.h
+++ b/cpukit/include/rtems/score/basedefs.h
@@ -748,6 +748,17 @@ extern "C" {
   #define RTEMS_SECTION( _section )
 #endif
+/* Generated from spec:/rtems/basedefs/if/static-analysis */
+ * @ingroup RTEMSAPIBaseDefs
+ * @brief It is defined if a static analysis run is performed.
+#if defined(__COVERITY__)
+  #define RTEMS_STATIC_ANALYSIS
+#endif
 /* Generated from spec:/rtems/basedefs/if/static-assert */
2.26.2
