How to Classify Intermittent Test Failures
Peter Dufault
dufault at hda.com
Mon Feb 1 17:56:18 UTC 2021
Can the test be marked as a possible emulator failure? For example (I haven't looked at the report) use "?" (Huh?) and not "!" (Failed!) or "." )(Passed), that is, the test failed as an emulated system and the RTEMS project suspects the emulation itself is causing this.
You shouldn't be allowed to use this on physical devices.
> On Feb 1, 2021, at 12:31 , Joel Sherrill <joel at rtems.org> wrote:
> On Mon, Feb 1, 2021 at 11:14 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Mon, Feb 1, 2021 at 9:42 AM Joel Sherrill <joel at rtems.org> wrote:
> Hi
> On the aarch64 qemu testing, we are seeing some tests which seem to pass most of the time but fail intermittently. It appears to be based somewhat on host load but there may be other factors.
> There does not appear to be a good test results state for these. Marking them expected pass or fail means they will get flagged incorrectly sometimes.
> Are they expected to pass every time?
> Normally yes. But there appears to be some external factors particularly load impacting qemu which lead to failures on target side code.
> Intermittent failures are suspicious, and there is limited value to running a test that has an "intermittent failure" state, since it will always be successful if you don't care if it passes or fails.
> Yeah. No matter what you mark them, it sucks.
> I don't see not running them as a good option. Beyond adding a new state to reflect this oddity, any suggestions?
> --joel
> devel mailing list
> devel at rtems.org
> devel mailing list
> devel at rtems.org
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
Type: application/pgp-signature
Desc: Message signed with OpenPGP
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210201/eb5e38b7/attachment.bin>
