How to Classify Intermittent Test Failures
Chris Johns
chrisj at rtems.org
Tue Feb 2 00:50:40 UTC 2021
On 2/2/21 9:12 am, Joel Sherrill wrote:
> On Mon, Feb 1, 2021 at 3:50 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 2/2/21 3:42 am, Joel Sherrill wrote:
> > Hi
> > On the aarch64 qemu testing, we are seeing some tests which seem to pass
> most of
> > the time but fail intermittently. It appears to be based somewhat on host load
> > but there may be other factors.
> > There does not appear to be a good test results state for these. Marking them
> > expected pass or fail means they will get flagged incorrectly sometimes.
> We have the test state 'indeterminate' ...
> https://docs.rtems.org/branches/master/user/testing/tests.html#expected-test-states
> <https://docs.rtems.org/branches/master/user/testing/tests.html#expected-test-states>
> It is for this type of test result.
> > I don't see not running them as a good option. Beyond adding a new state to
> > reflect this oddity, any suggestions?
> I prefer we used the already defined and documented state.
> +1
> Kinsey had already marked them as indeterminate and the guys were in the
> process of documenting why. I interpreted the question of what to do more
> broadly than it needed to be but the discussion was good.
A discussion is needed and welcome. Handling these intermittent simulator
failures is hard. I once looked into some gdb simulator cases when I first put
rtems-test together and found myself quickly heading into a deep dark hole. I
have not been back since.
