[PATCH] c-user: Clarify object services
Tue Feb 2 15:56:12 UTC 2021
On Tue, Feb 2, 2021 at 8:42 AM Sebastian Huber <
> On 02/02/2021 16:37, Gedare Bloom wrote:
> >     -.. rubric:: NOTES:
> >     +.. rubric:: CONSTRAINTS:
> >     -This directive is strictly local and does not impact task
> scheduling.
> > I may have missed the discussion, but this note is being removed
> > without being added elsewhere.
> > Is it implied that all functions are local and do not impact task
> > scheduling, unless otherwise constrained?
> No, I replaced the above with below:
> >     +The following constraints apply to this directive:
> >     +* The directive is implemented by a macro and may be called from
> >     within C/C++
> >     +  constant expressions.  In addition, a function implementation
> >     of the
> >     +  directive exists for bindings to other programming languages.
> I could also add this:
> * The directive will not cause the calling task to be preempted.
> I think that will help for clarity, perhaps. It is good to know which
rtems_ services can/cannot preempt
>  From my point of view it was clear that something which "may be called
> from within C/C++ constant expressions" cannot impact task scheduling.
may is not must. If you call it from a non-constant expression it still
will not preempt.
Also, I think it is a bit odd to say "called from within" a constant. maybe
"used from within" is better? You don't actually make a call when it is
constant.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210202/7a63a3e6/attachment-0001.html>
