[PATCH] score: _Objects_Build_name() signed/unsigned char
Gedare Bloom
gedare at rtems.org
Tue Feb 2 16:59:54 UTC 2021
On Tue, Feb 2, 2021 at 9:57 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Feb 2, 2021 at 9:44 AM Sebastian Huber <
> sebastian.huber at embedded-brains.de> wrote:
>> On 02/02/2021 17:22, Gedare Bloom wrote:
>> > OK. This one surprised me (and I'm sure I'm not the only one.)
>> > On Tue, Feb 2, 2021 at 7:42 AM Sebastian Huber
>> > <sebastian.huber at embedded-brains.de
>> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
>> > Change _Objects_Build_name() so that the result is independent of
>> the
>> > signedness of char.
>> > Close #4228.
>> I don't think it is practically an issue, however, if you want to
>> specify this function, then it gets a problem. You would have to write
>> something like: Where the char is signed, ...
> Maybe. I wrote a simple program because I was curious about this behavior.
> int main(int argc, char *argv[])
> unsigned char a = 0xff;
> signed char b = 0xff;
> printf("(uint32_t)a: %u\n(uint32_t)b %u\n", (uint32_t)a, (uint32_t)b);
> printf("(uint32_t)(uint8_t)a: %u\n(uint32_t)(uint8_t)b %u\n",
> (uint32_t)(uint8_t)a, (uint32_t)(uint8_t)b);
> return 0;
> $ ./a.out
> (uint32_t)a: 255
> (uint32_t)b 4294967295
> (uint32_t)(uint8_t)a: 255
> (uint32_t)(uint8_t)b 255
> So, you would get some maybe unpleasant behavior if you have a signed char
> in the less-significant bytes that you end up sign-extending through the
> more significant bytes.
Only a problem if one uses non-ASCII (extended) characters though. So not a
real problem in practice.
>> embedded brains GmbH
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.huber at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210202/d5fda622/attachment.html>
