Help in installing rtems
Gedare Bloom
gedare at rtems.org
Tue Feb 2 18:43:36 UTC 2021
Hi Rohan,
You should not generally post the same thing to both lists, nor should you
cross-post (CC both lists). Both users and devel mailing lists are
monitored and should get responses sometimes in the same day but within a
few days at a minimum. If you don't get a response within a couple days
(excluding weekends and holidays), then you could politely follow-up with a
"ping" to request an answer.
Gedare
On Tue, Feb 2, 2021 at 11:10 AM Rohan kumar <krohan8870 at gmail.com> wrote:
> Hello all.
> My name is Rohan Kumar. I am very much interested in contributing to
> RTEMS for this year's GSOC.
> Actually I am trying to install rtems on my laptop. I am following the
> document "Quick Start : GSOC" . I completed the step Installing the tool
> suite but in the next step "Build a BSP" I am stuck.
> Actually it's giving the error "bash: ./waf: No such file or directory"
> I am thinking that I may have done wrong placements of folders while doing
> setup because I did not much understand the prefix concept.
> So if anyone can help me about this or give any direction it will be very
> helpful.
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210202/98b4af22/attachment.html>
