[PATCH] c-user: Clarify object services
    Gedare Bloom
    gedare at rtems.org
    Tue Feb  2 19:53:59 UTC 2021
On Tue, Feb 2, 2021 at 12:19 PM Sebastian Huber <
> On 02/02/2021 16:56, Gedare Bloom wrote:
> > On Tue, Feb 2, 2021 at 8:42 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> >     On 02/02/2021 16:37, Gedare Bloom wrote:
> >     >     -.. rubric:: NOTES:
> >     >     +.. rubric:: CONSTRAINTS:
> >     >     -This directive is strictly local and does not impact task
> >     scheduling.
> >     > I may have missed the discussion, but this note is being removed
> >     > without being added elsewhere.
> >     > Is it implied that all functions are local and do not impact task
> >     > scheduling, unless otherwise constrained?
> >     No, I replaced the above with below:
> >     >     +The following constraints apply to this directive:
> >     >     +* The directive is implemented by a macro and may be called
> >     from
> >     >     within C/C++
> >     >     +  constant expressions.  In addition, a function
> implementation
> >     >     of the
> >     >     +  directive exists for bindings to other programming
> languages.
> >     I could also add this:
> >     * The directive will not cause the calling task to be preempted.
> > I think that will help for clarity, perhaps. It is good to know which
> > rtems_ services can/cannot preempt
> Ok, I will try to add at least one context and at least one preemption
> constraint to each directive.
> >      From my point of view it was clear that something which "may be
> >     called
> >     from within C/C++ constant expressions" cannot impact task
> scheduling.
> > may is not must. If you call it from a non-constant expression it
> > still will not preempt.
> > Also, I think it is a bit odd to say "called from within" a constant.
> > maybe "used from within" is better? You don't actually make a call
> > when it is constant.
> I would keep the "called from within". It is called by the compiler and
> not the processor. In C++ you nowadays have a lot of constexpr functions
> (or templates).
> ok
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210202/f37419e2/attachment.html>
