[PATCH] Basic lwIP for STM32H7 BSP
Robin Müller robin.mueller.m at gmail.com
Wed Feb 3 14:26:00 UTC 2021
Also, Andrei Chichak provided a very good explanation:
The STM32x7 ethernet controllers need their descriptors and data areas to
> be located on 32-byte boundaries with a combination of cache being turned
> off and buffering being turned off. This is a side effect of the STM32x7
> DMA and data caching.
> The examples that ST have for LWiP under FreeRTOS have some issues with
> the linker file having overlapping sections and the stack (above the ETH
> data areas) being left with no cache and no buffering. The space above the
> rx/tx buffers is also less than the stack space minimum specified in the
> linker file as well.  Some rearranging of the ETH descriptors and data
> areas would be prudent. Like push them to the top of SRAM and locate the
> stack below.
> To get this all going, they set up the MPU for two overlapping sections,
> one being the top 16kB of SRAM and the other the 256B that contain the ETH
> descriptors. I believe the MPU regions can be set in increments of 32Bytes,
> so setting up the cache and buffering should be do-able without affecting
> the stack.
Kind Regards
Robin Müller
On Wed, 3 Feb 2021 at 14:50, Robin Müller <robin.mueller.m at gmail.com> wrote:
> The following link contains more theoretical information about why these
> sections were placed at these addresses:
> https://community.st.com/s/article/FAQ-DMA-is-not-working-on-STM32H7-devices
> Kind Regards
> Robin
> On Wed, 3 Feb 2021 at 14:44, Robin Müller <robin.mueller.m at gmail.com>
> wrote:
>> The DMA descriptors need to be placed at the start of the SRAM3 and need
>> to be aligned in a certain way. The RX buffer will take up the first
>> (slightly less than) 16 kB of SRAM3 but needs to be placed
>> behind the DMA descriptors. It also needs to be placed in a way that the
>> MPU configuration required for the DMA descriptors will not do something
>> with the RX buffers.
>> In the example provided by STM32, the first 256 bytes are configured by
>> MPU Config.
>> Kind Regards
>> Robin
>> On Wed, 3 Feb 2021 at 13:43, Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>>> On 02/02/2021 20:10, Robin Mueller wrote:
>>> > +     /* Not an ideal solution but required for lwIP on the STM32H7
>>> BSP.
>>> > +     This places the DMA descriptors for lwIP at the start of SRAM3.
>>> > +     The MPU still needs to be configured for the DMA descriptor
>>> regions to be
>>> > +     bufferable, non-cacheable, non-shareable (first 256 bytes) */
>>> > +     .lwip_sec_stm32h7 (NOLOAD) : ALIGN_WITH_INPUT {
>>> > +             . = ABSOLUTE(0x30040000);
>>> > +             *(.RxDecripSection)
>>> > +             . = ABSOLUTE(0x30040060);
>>> > +             *(.TxDecripSection)
>>> > +             . = ABSOLUTE(0x30040200);
>>> > +             *(.RxArraySection)
>>> > +     } >SRAM_3 AT> REGION_TEXT_LOAD
>>> This is the wrong linker command file. This stuff should be in
>>> spec/build/bsps/arm/stm32h7/linkcmdsmemory.yml
>>> with an output section name like ".stm32h7_sram_3" and corresponding
>>> input section names. Why do you need absolute addresses here?
>>> embedded brains GmbH
>>> Herr Sebastian HUBER
>>> Dornierstr. 4
>>> 82178 Puchheim
>>> Germany
>>> email: sebastian.huber at embedded-brains.de
>>> phone: +49-89-18 94 741 - 16
>>> fax:   +49-89-18 94 741 - 08
>>> Registergericht: Amtsgericht München
>>> Registernummer: HRB 157899
>>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>>> Unsere Datenschutzerklärung finden Sie hier:
>>> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210203/1eb7d890/attachment.html>
