[PATCH 1/2] libtest: Add T_get_thread_timer_state()
Fri Feb 5 15:13:02 UTC 2021
 cpukit/include/rtems/test.h        | 11 ++++++++++-
 cpukit/libtest/t-test-rtems-objs.c | 29 +++++++++++++++++++++++++++++
 2 files changed, 39 insertions(+), 1 deletion(-)
diff --git a/cpukit/include/rtems/test.h b/cpukit/include/rtems/test.h
index f96a5a6892..b42bf5f058 100644
--- a/cpukit/include/rtems/test.h
+++ b/cpukit/include/rtems/test.h
@@ -1,7 +1,7 @@
  * SPDX-License-Identifier: BSD-2-Clause
- * Copyright (C) 2017, 2020 embedded brains GmbH
+ * Copyright (C) 2017, 2021 embedded brains GmbH
  * modification, are permitted provided that the following conditions
@@ -2503,6 +2503,15 @@ void T_check_posix_shms(T_event, const char *);
 void T_check_posix_threads(T_event, const char *);
 void T_check_posix_timers(T_event, const char *);
+typedef enum {
+	T_THREAD_TIMER_NO_THREAD,
+	T_THREAD_TIMER_SCHEDULED,
+	T_THREAD_TIMER_PENDING,
+	T_THREAD_TIMER_INACTIVE
+} T_thread_timer_state;
+T_thread_timer_state T_get_thread_timer_state(uint32_t);
 #endif /* __rtems__ */
diff --git a/cpukit/libtest/t-test-rtems-objs.c b/cpukit/libtest/t-test-rtems-objs.c
index ed7222e98e..a0f2ba3b73 100644
--- a/cpukit/libtest/t-test-rtems-objs.c
+++ b/cpukit/libtest/t-test-rtems-objs.c
@@ -43,6 +43,35 @@
+T_get_thread_timer_state(uint32_t id)
+	Thread_Control *the_thread;
+	ISR_lock_Context lock_context;
+	T_thread_timer_state state;
+	the_thread = _Thread_Get(id, &lock_context);
+	if ( the_thread == NULL ) {
+		return T_THREAD_TIMER_NO_THREAD;
+	switch (_Watchdog_Get_state(&the_thread->Timer.Watchdog)) {
+		case WATCHDOG_SCHEDULED_BLACK:
+		case WATCHDOG_SCHEDULED_RED:
+			state = T_THREAD_TIMER_SCHEDULED;
+			break;
+		case WATCHDOG_PENDING:
+			state = T_THREAD_TIMER_PENDING;
+			break;
+		default:
+			state = T_THREAD_TIMER_INACTIVE;
+			break;
+	_ISR_lock_ISR_enable(&lock_context);
+	return state;
 Objects_Maximum
 T_objects_count(Objects_APIs api, uint16_t cls)
2.26.2
