[PATCH v2] Test suite for FTW.H methods
Eshan Dhawan eshandhawan51 at gmail.com
Fri Feb 5 16:54:53 UTC 2021
On Fri, Feb 5, 2021 at 7:31 PM Joel Sherrill <joel at rtems.org> wrote:
> Does the waf support actually build psxftw01.tar or is that a constant
> magic file?
> I might have missed it but I didn't see any logic to create it.
Its the constant magic file modified from libtests/tar01
> Other than that, I don't have any issues.
> --joel
> On Wed, Feb 3, 2021 at 3:34 PM Eshan Dhawan <eshandhawan51 at gmail.com>
> wrote:
>> From: Eshan dhawan <eshandhawan51 at gmail.com>
>> Signed-off-by: Eshan Dhawan <eshandhawan51 at gmail.com>
>>  spec/build/testsuites/psxtests/grp.yml      |   2 +
>>  spec/build/testsuites/psxtests/psxftw01.yml |  34 ++++
>>  testsuites/psxtests/Makefile.am             |  26 +++
>>  testsuites/psxtests/configure.ac            |   1 +
>>  testsuites/psxtests/psxftw01/init.c         | 204 ++++++++++++++++++++
>>  testsuites/psxtests/psxftw01/psxftw01.doc   |  18 ++
>>  testsuites/psxtests/psxftw01/psxftw01.scn   |  10 +
>>  testsuites/psxtests/psxftw01/psxftw01.tar   | Bin 0 -> 3584 bytes
>>  8 files changed, 295 insertions(+)
>>  create mode 100644 spec/build/testsuites/psxtests/psxftw01.yml
>>  create mode 100644 testsuites/psxtests/psxftw01/init.c
>>  create mode 100644 testsuites/psxtests/psxftw01/psxftw01.doc
>>  create mode 100644 testsuites/psxtests/psxftw01/psxftw01.scn
>>  create mode 100644 testsuites/psxtests/psxftw01/psxftw01.tar
>> diff --git a/spec/build/testsuites/psxtests/grp.yml
>> b/spec/build/testsuites/psxtests/grp.yml
>> index 47dedac275..fb7ce465ae 100644
>> --- a/spec/build/testsuites/psxtests/grp.yml
>> +++ b/spec/build/testsuites/psxtests/grp.yml
>> @@ -109,6 +109,8 @@ links:
>>    uid: psxfile02
>>  - role: build-dependency
>>    uid: psxfilelock01
>> +- role: build-dependency
>> +  uid: psxftw01
>>    uid: psxgetattrnp01
>> diff --git a/spec/build/testsuites/psxtests/psxftw01.yml
>> b/spec/build/testsuites/psxtests/psxftw01.yml
>> new file mode 100644
>> index 0000000000..c8b2a4fb59
>> --- /dev/null
>> +++ b/spec/build/testsuites/psxtests/psxftw01.yml
>> @@ -0,0 +1,34 @@
>> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>> +build-type: script
>> +cflags: []
>> +copyrights:
>> +- Copyright (C) 2020 Eshan Dhawan
>> +cppflags: []
>> +do-build: |
>> +  path = "testsuites/psxtests/psxftw01/"
>> +  tar = path + "psxftw01.tar"
>> +  tar_gz = self.gzip(bld, tar)
>> +  tar_xz = self.xz(bld, tar)
>> +  tar_c, tar_h = self.bin2c(bld, tar)
>> +  tar_gz_c, tar_gz_h = self.bin2c(bld, tar_gz)
>> +  tar_xz_c, tar_xz_h = self.bin2c(bld, tar_xz)
>> +  objs = []
>> +  objs.append(self.cc(bld, bic, tar_c))
>> +  objs.append(self.cc(bld, bic, tar_gz_c))
>> +  objs.append(self.cc(bld, bic, tar_xz_c))
>> +  objs.append(self.cc(bld, bic, path + "init.c", deps=[tar_h, tar_gz_h,
>> tar_xz_h], cppflags=bld.env.TEST_psxftw01_CPPFLAGS))
>> "testsuites/psxtests/psxfile01/test_cat.c", target=path + "test_cat.o"))
>> +  self.link_cc(bld, bic, objs, "testsuites/psxtests/psxftw01.exe")
>> +do-configure: null
>> +enabled-by: true
>> +includes:
>> +- testsuites/psxtests/psxftw01
>> +ldflags: []
>> +links: []
>> +prepare-build: null
>> +prepare-configure: null
>> +stlib: []
>> +type: build
>> +use-after:
>> +- z
>> +use-before: []
>> diff --git a/testsuites/psxtests/Makefile.am
>> b/testsuites/psxtests/Makefile.am
>> index d89bcd8801..a35f00b665 100755
>> --- a/testsuites/psxtests/Makefile.am
>> +++ b/testsuites/psxtests/Makefile.am
>> @@ -453,6 +453,32 @@ psxfilelock01_CPPFLAGS = $(AM_CPPFLAGS)
>> $(TEST_FLAGS_psxfilelock01) \
>>         $(support_includes)
>>  endif
>> +if TEST_psxftw01
>> +psx_tests += psxftw01
>> +psx_screens += psxftw01/psxftw01.scn
>> +psx_docs += psxftw01/psxftw01.doc
>> +psxftw01_SOURCES = psxftw01/init.c psxfile01/test_cat.c \
>> +       psxftw01-tar.c psxftw01-tar.h psxftw01-tar-gz.c psxftw01-tar-gz.h
>> +psxftw01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxftw01) \
>> +       $(support_includes) $(test_includes) -I$(top_srcdir)/include
>> +psxftw01_LDADD = $(RTEMS_ROOT)cpukit/librtemscpu.a
>> $(RTEMS_ROOT)cpukit/libz.a $(LDADD)
>> +psxftw01-tar.c: psxftw01/psxftw01.tar
>> +       $(AM_V_GEN)$(BIN2C) -C $< $@
>> +psxftw01-tar.h: psxftw01/psxftw01.tar
>> +       $(AM_V_GEN)$(BIN2C) -H $< $@
>> +psxftw01-tar.o: psxftw01-tar.c psxftw01-tar.h
>> +psxftw01.tar.gz: psxftw01/psxftw01.tar
>> +       $(AM_V_GEN)$(GZIP) < $< > $@
>> +psxftw01-tar-gz.c: psxftw01.tar.gz
>> +psxftw01-tar-gz.h: psxftw01.tar.gz
>> +CLEANFILES += psxftw01.tar psxftw01-tar.c psxftw01-tar.h \
>> +       psxftw01.tar.gz psxftw01-tar-gz.c psxftw01-tar-gz.h
>> +psxftw01/init.c: psxftw01-tar.h psxftw01-tar-gz.h $(TAR01_XZ_H)
>> +endif
>>  if TEST_psxgetattrnp01
>>  psx_tests += psxgetattrnp01
>>  psx_screens += psxgetattrnp01/psxgetattrnp01.scn
>> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/
>> configure.ac
>> index 139787cccb..3f95010cd3 100644
>> --- a/testsuites/psxtests/configure.ac
>> +++ b/testsuites/psxtests/configure.ac
>> @@ -90,6 +90,7 @@ RTEMS_TEST_CHECK([psxfenv01])
>>  RTEMS_TEST_CHECK([psxfile01])
>>  RTEMS_TEST_CHECK([psxfile02])
>>  RTEMS_TEST_CHECK([psxfilelock01])
>> +RTEMS_TEST_CHECK([psxftw01])
>>  RTEMS_TEST_CHECK([psxgetattrnp01])
>>  RTEMS_TEST_CHECK([psxgetrusage01])
>>  RTEMS_TEST_CHECK([psxglobalcon01])
>> diff --git a/testsuites/psxtests/psxftw01/init.c
>> b/testsuites/psxtests/psxftw01/init.c
>> index 0000000000..bc3858395f
>> --- /dev/null
>> +++ b/testsuites/psxtests/psxftw01/init.c
>> @@ -0,0 +1,204 @@
>> + *  @file
>> + *  @brief Test suite for ftw.h methods
>> + * SPDX-License-Identifier: BSD-2-Clause
>> + * Copyright (C) 2020 Eshan Dhawan, embedded brains GmbH, Joel Sherrill
>> + * Redistribution and use in source and binary forms, with or without
>> + * modification, are permitted provided that the following conditions
>> + * are met:
>> + * 1. Redistributions of source code must retain the above copyright
>> + *    notice, this list of conditions and the following disclaimer.
>> + * 2. Redistributions in binary form must reproduce the above copyright
>> + *    notice, this list of conditions and the following disclaimer in the
>> + *    documentation and/or other materials provided with the
>> distribution.
>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>> "AS IS"
>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
>> THE
>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE
>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
>> BE
>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> BUSINESS
>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
>> IN
>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>> OTHERWISE)
>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>> OF THE
>> + * POSSIBILITY OF SUCH DAMAGE.
>> +#ifdef HAVE_CONFIG_H
>> +#include "config.h"
>> +#endif
>> +/* Header files */
>> +#include <bsp.h> /* for device driver prototypes */
>> +#include "tmacros.h"
>> +#include <rtems.h>
>> +#include <rtems/bspIo.h>
>> +#include <rtems/untar.h>
>> +#include <rtems/error.h>
>> +#include <ftw.h>
>> +#include <dirent.h>
>> +#include <sys/stat.h>
>> +#include <errno.h>
>> +#include <unistd.h>
>> +#include <string.h>
>> +#include <stdio.h>
>> +#include <stdlib.h>
>> +#include <rtems/test.h>
>> +#include "psxftw01-tar.h"
>> +#include "psxftw01-tar-gz.h"
>> +#define TARFILE_START    psxftw01_tar
>> +#define TARFILE_SIZE     psxftw01_tar_size
>> +#define TARFILE_GZ_START psxftw01_tar_gz
>> +#define TARFILE_GZ_SIZE  psxftw01_tar_gz_size
>> +const char rtems_test_name[] = "psxftw01";
>> +/* Function decleration to avoid warning */
>> +void *POSIX_Init (void * argument);
>> +static char  file_traverse_order[6][20];
>> +static int file_order;
>> +static char buffer[512];
>> +static const T_action actions[] = {
>> +  T_report_hash_sha256,
>> +  T_check_task_context,
>> +  T_check_file_descriptors,
>> +  T_check_rtems_barriers,
>> +  T_check_rtems_extensions,
>> +  T_check_rtems_message_queues,
>> +  T_check_rtems_partitions,
>> +  T_check_rtems_periods,
>> +  T_check_rtems_regions,
>> +  T_check_rtems_semaphores,
>> +  T_check_rtems_tasks,
>> +  T_check_rtems_timers,
>> +  T_check_posix_keys
>> +static const T_config config = {
>> +  .name = "psxftw01",
>> +  .buf = buffer,
>> +  .buf_size = sizeof(buffer),
>> +  .putchar = rtems_put_char,
>> +  .verbosity = T_VERBOSE,
>> +  .now = T_now_clock,
>> +  .action_count = T_ARRAY_SIZE(actions),
>> +  .actions = actions
>> +static int fn_function (const char *fpath, const struct stat *sb,
>> +int tflag, struct FTW *ftwbuf)
>> +  strcpy(file_traverse_order [file_order], fpath + ftwbuf->base) ;
>> +  file_order = file_order + 1;
>> +  return 0; /* to make nftw run further */
>> +T_TEST_CASE(ftw)
>> +  /* VARIABLE DECLEARATION */
>> +  int r;
>> +  char *files_path;
>> +  int flags;
>> +  int i;
>> +  /* setting up filesystem */
>> +  rtems_status_code sc;
>> +  /*Untaring from memory */
>> +  sc = Untar_FromMemory_Print(
>> +   (void *)TARFILE_START,
>> +   TARFILE_SIZE,
>> +   &rtems_test_printer
>> +  if (sc != RTEMS_SUCCESSFUL) {
>> +     printf ("error: untar failed: %s\n", rtems_status_text (sc));
>> +  /* Array with expected file order */
>> +  char arr_ftw_depth[5][20] = { "test_file", "test_script", "def",
>> "abc", "home" };
>> +  char arr_ftw_phys[5][20] = { "home", "test_file", "abc", "def",
>> "test_script" };
>> +  /* defining the path to run nftw*/
>> +  files_path = "/home";
>> +  /* nftw test with FTW_DEPTH flag*/
>> +  flags = 0;
>> +  file_order = 0;
>> +  flags |= FTW_DEPTH;
>> +  r = nftw( files_path, fn_function, 5, flags );
>> +  T_quiet_psx_success(r);
>> +  /*comparing the nftw file tree to the expexted file tree traversal */
>> +  for (i = 0; i < file_order; i++){
>> +    r = strcmp( arr_ftw_depth[i], file_traverse_order[i]);
>> +    if (r){
>> +      printf( "Incorrect Order " );
>> +    /*----------------Test Block 2--------------------*/
>> +  flags = 0;
>> +  file_order = 0;
>> +  flags |= FTW_PHYS;
>> +  /*comparing the nftw file tree to the expected file tree traversal*/
>> +    r = strcmp( arr_ftw_phys[i], file_traverse_order[i]);
>> +    if (r){
>> +  int exit_code;
>> +  TEST_BEGIN();
>> +  T_register();
>> +  exit_code = T_main(&config);
>> +  if (exit_code == 0) {
>> +    TEST_END();
>> + rtems_test_exit(exit_code);
>> +/* NOTICE: the clock driver is explicitly disabled */
>> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
>> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
>> +#define CONFIGURE_MAXIMUM_TASKS                  1
>> +#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 6
>> +#define CONFIGURE_MAXIMUM_POSIX_THREADS  2
>> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
>> +#define CONFIGURE_POSIX_INIT_THREAD_TABLE
>> +#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
>> +#include <rtems/confdefs.h>
>> +/* end of file */
>> diff --git a/testsuites/psxtests/psxftw01/psxftw01.doc
>> b/testsuites/psxtests/psxftw01/psxftw01.doc
>> index 0000000000..7b2863a2da
>> --- /dev/null
>> +++ b/testsuites/psxtests/psxftw01/psxftw01.doc
>> @@ -0,0 +1,18 @@
>> +#  COPYRIGHT (c) 2019
>> +#  On-Line Applications Research Corporation (OAR).
>> +# SPDX-License-Identifier: BSD-2-Clause
>> +This file describes the directives and concepts tested by this test set.
>> +test set name:  psxftw01
>> +Directives:
>> +nftw
>> +Concepts:
>> ++ This test exercises the ftw.h methods.
>> diff --git a/testsuites/psxtests/psxftw01/psxftw01.scn
>> b/testsuites/psxtests/psxftw01/psxftw01.scn
>> index 0000000000..650d365033
>> --- /dev/null
>> +++ b/testsuites/psxtests/psxftw01/psxftw01.scn
>> @@ -0,0 +1,10 @@
>> +*** BEGIN OF TEST psxftw01 ***
>> +untar: memory at 0x12608c (10240)
>> +untar: file: home/test_file (s:73,m:0644)
>> +untar: file: home/abc/def/test_script (s:21,m:0755)
>> +untar: symlink: home/test_file -> symlink
>> +*** END OF TEST psxftw01 ***
>> diff --git a/testsuites/psxtests/psxftw01/psxftw01.tar
>> b/testsuites/psxtests/psxftw01/psxftw01.tar
>> index
>> 0000000000000000000000000000000000000000..e45d10793a9fbcadc7d1ee84d42d13ff8eb2655e
>> GIT binary patch
>> literal 3584
>> zcmeHJ!EVAZ4DFe(@U-)WlQ!uW?6}Lu9R)~fM4C=@nZ)1Eq3gsD8sbnuTCGY}>(?ZH
>> z$+J_|m7TVh+Iiu;O$ISU)L8}z$~2RB;5iUY2mvD1LQAC(Q$V4$zyxrR)f^4FrPeeF
>> zBH4wZ)|oIbj}YDKs;-O+uqE5jDL|JBC$~2^1-Zv>v(gdpV;~*^s0;A5S-G$V6X0$3
>> z^7;<(V9<_QTS3v(6$d6RIHt-2QwOdxYx_L8$K=K}on at em`ZtT^bY+XK4$!i3AMM#6
>> zF95J2a;2g)M6RO#e|#qvlo~|FMM7yQ8Nm8amAtb4L+xGhM*%z+?{(k%3;4Mu^zi{K
>> zl`Lsb at Z=2vAB4|Q%(vW<tIkck%Db=`bk3;%JU{6B{XO7Y{_KADe~DZN5|I1iH1Or*
>> TpZEVkH+~#^WME|At{M0OLN<HT
>> literal 0
>> HcmV?d00001
>> 2.27.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210205/017a5787/attachment-0001.html>
