[PATCH 1/4] bsps/shared/ofw: Fix coverity reported defects
G S Niteesh Babu niteesh.gs at gmail.com
Fri Feb 5 17:40:48 UTC 2021
Fixed use after free and null pointer dereference defects
FIXES:
1) CID 1472601 (NULL_RETURNS)
2) CID 1472600 (USE_AFTER_FREE)
3) CID 1472599 (USE_AFTER_FREE)
4) CID 1472598 (USE_AFTER_FREE)
5) CID 1472596 (USE_AFTER_FREE)
The below two defects have to marked false positive
1) CID 1472597 (ARRAY_VS_SINGLETON)
2) CID 1472595 (ARRAY_VS_SINGLETON)
 bsps/shared/ofw/ofw.c | 10 +++++-----
 1 file changed, 5 insertions(+), 5 deletions(-)
diff --git a/bsps/shared/ofw/ofw.c b/bsps/shared/ofw/ofw.c
index 82924b2600..fa94bfbf05 100644
--- a/bsps/shared/ofw/ofw.c
+++ b/bsps/shared/ofw/ofw.c
@@ -313,7 +313,7 @@ ssize_t rtems_ofw_get_prop_alloc(
     if (rtems_ofw_get_prop(node, propname, *buf, len) == -1) {
-      rtems_ofw_free(buf);
+      rtems_ofw_free(*buf);
       *buf = NULL;
       return -1;
@@ -344,7 +344,7 @@ ssize_t rtems_ofw_get_prop_alloc_multi(
       *buf = NULL;
       return -1;
@@ -373,7 +373,7 @@ ssize_t rtems_ofw_get_enc_prop_alloc(
     if (rtems_ofw_get_enc_prop(node, propname, *buf, len) == -1) {
       *buf = NULL;
       return -1;
@@ -404,7 +404,7 @@ ssize_t rtems_ofw_get_enc_prop_alloc_multi(
       *buf = NULL;
       return -1;
@@ -614,7 +614,7 @@ int rtems_ofw_get_reg(
     offset = rtems_fdt_phandle_to_offset(parent);
     ptr = fdt_getprop(fdtp, offset, "ranges", &len);
-    if (len < 0) {
+    if (ptr == NULL) {
       break;
2.17.1
