Standalone repository for libnetworking stack
Fri Feb 5 23:04:18 UTC 2021
On Fri, Feb 5, 2021 at 4:41 PM Chris Johns <chrisj at rtems.org> wrote:
> On 6/2/21 8:28 am, Joel Sherrill wrote:
> > On Fri, Feb 5, 2021 at 2:54 PM Christian Mauderer <oss at c-mauderer.de
> > <mailto:oss at c-mauderer.de>> wrote:
> >     Hello Vijay,
> >     On 05/02/2021 19:41, Vijay Kumar Banerjee wrote:
> >     > Hello,
> >     > I'm currently working on separating the libnetworking stack into
> its
> >     > standalone repository that can be built separately with waf. The
> current
> >     > status of the project is that I have a working rtems-libnetworking
> >     > repository [1] that builds with waf (hasn't been tested with any
> test
> >     > cases yet). And In my fork of RTEMS I have separated the
> libnetworking
> >     > stack [2].
> If you have not already done so I suggest you create repos in your
> personal area
> on dispatch.rtems.org and these will appear on the cgit page. It is a
> simple way
> to get exposure to the work.
> >     Sounds like an interesting work. If I didn't miss an earlier
> discussion:
> >     I think the name might could trigger one. It gives the impression
> that
> >     it is _the_ networking stack to use. But for newer BSPs most of the
> time
> >     libbsd is the better choice.
> > We could make it painful and obvious using something like
> > rtems-legacy-networking :)
> .. or rtems-net-legacy ... small, clear and simple.
> > I assume you are also taking all legacy network drivers with you.
> Yes this is a good point. They will have to move as well. I hope this does
> not
> create links back into BSP specific headers that are not currently being
> installed.
> > One random thought is whether this should only build for specific BSPs.
> We
> > currently can build the stack for nearly all architectures but I don't
> think that
> > realistically there are BSPs which run it on all architectures. Should
> there be
> > a whitelist of supported BSPs?
> There are BSPs where the drivers are not in RTEMS because of chip vendor
> licensing issues. Why not follow the rtems-libbsd model?
And by this, what do you mean? Be able to build it even if there are no BSP
specific drivers available?
> > And I used "supported" quite loosely. I expect that other than a
> > small number of BSPs you can check on simulators, this is not going to
> > be heavily tested beyond building. This is not a criticism. I think it is
> > just a reality of doing something better than removing it entirely.
> If it is tested when split and then maintained so it builds it should stay
> in a
> reasonable state. We just need to state clearly our intentions and if
> someone
> really needs support there are commercial support options.
> >     > I need suggestions with the following questions:
> >     > 1. What to do with the codes in RTEMS outside the libnetworking
> stack,
> >     > which uses the networking library. Libraries for example libpppd
> uses
> >     > libnetworking. Do we want to shift these to the separate
> repository for
> >     > libnetworking or do we want to keep them in RTEMS and use the waf
> system
> >     > to selectively built those when the libnetworking is available in
> >     > PREFIX. We can add a common header file that #defines
> RTEMS_NETWORKING,
> >     > so that the related codes can be built and used.
> >     I think it depends:
> >     Can they be used with libbsd or only with the legacy stack?
> > I thought the point of having the network headers in newlib was to enable
> > user space networking applications that could build independent of the
> > network stack in use. I think these should stay in rtems/ as much as
> possible.
> Do we need to audit which pieces are generic networking applications and
> which
> are tied to libnetworking. For example libbsd has an NFS network client
> and so
> does the legacy stack.
Probably. If they are in both, move the one in rtems/ to the legacy kit.
> >     If they can be used with libbsd: Can they be build without a
> networking
> >     stack? In that case it might would be possible to build them in RTEMS
> >     and link them later with either libbsd, with libnetworking or (maybe)
> >     some-when with lwIP. I don't think there is a reason to not build
> them
> >     for any BSP if they can be build without a networking stack.
> > Yes. This is how it is supposed to work and should with libbsd now.
> This is also my understanding.
> >     If they can't be used with libbsd (or another stack) I would suggest
> to
> >     keep them together with the legacy stack in your new libnetworking
> >     repository.
> > +1
> +1
> >     > 2. There are a few header files in cpukit/include that are
> required by
> >     > the libnetworking stack. Currently the rtems-libnetworking is
> building
> >     > in sort of a hackish way by using the header file from the RTEMS
> source
> >     > directory. Do we want to add these header files (like tftp.h) and
> >     > related source files to the libnetworking directory? The other way
> to
> >     > use them would be to install the required headers in the PREFIX
> and use
> >     > them from libnetworking.
> >     If I understand correctly, the headers are not installed? In that
> case:
> >     Who else uses these headers? If no one except for the network stack
> >     needs them: Move them to your new library.
> > +1
> +1
> >     In case of the tftp.h: It seems that this file is installed, isn't
> it?
> >     So why can't you just use it from libnetworking?
> > Hmm... that appears to be used only by the tftp client filesystem. That
> should
> > be in libfs/src really.  There is also an ftp client filesystem which
> also needs to
> > move. They SHOULD work independent of the network stack.
> > Move those files so either stack can use them.
> > I'm thrilled to see this happening.
> I am as well. Vijay thank you for taking on the task.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210205/1476d576/attachment.html>
