spcontext01 failure
Richi Dubey
richidubey at gmail.com
Sat Feb 6 04:20:58 UTC 2021
Thank you for the help.
I wanted to make sure that the SMP Strong APA scheduler works on the single
processor tests as well. Is there any bsp and debugger which I can use to
check this?
On Fri, Feb 5, 2021 at 11:21 AM Sebastian Huber <
> On 05/02/2021 06:26, Richi Dubey wrote:
> > Also, I forgot to mention that I ran the qemu system arm like this:
> > :~/quick-start/CurrentMaster/rtems/6/bin$ qemu-system-arm -net none
> > -nographic -M realview-pbx-a9 -m 256M -kernel
> ~/quick-start/CurrentMaster/build/bsp/arm-rtems6/c/realview_pbx_a9_qemu/testsuites/samples/unlimited.exe
> > -smp 4 -s -S
> If you start applications configured for one processor on more than one
> processor on arm, then you have currently an undefined behaviour.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210206/1d5bb90b/attachment.html>
