[PATCH 3/4] bsps/shared/ofw: Make rtems_ofw_get_effective_phandle iterative
Niteesh G. S.
niteesh.gs at gmail.com
Sat Feb 6 04:46:31 UTC 2021
Hello Gedare,
On Fri, Feb 5, 2021 at 11:53 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Feb 5, 2021 at 10:41 AM G S Niteesh Babu <niteesh.gs at gmail.com>
> wrote:
>> Refactored recursive rtems_ofw_get_effective_phandle into a
>> iterative function.
>> bsps/shared/ofw/ofw.c | 9 +++++----
>> 1 file changed, 5 insertions(+), 4 deletions(-)
>> diff --git a/bsps/shared/ofw/ofw.c b/bsps/shared/ofw/ofw.c
>> index 9dec310247..e3626747fa 100644
>> --- a/bsps/shared/ofw/ofw.c
>> +++ b/bsps/shared/ofw/ofw.c
>> @@ -509,11 +509,12 @@ static phandle_t rtems_ofw_get_effective_phandle(
>> phandle_t child;
>> phandle_t ref;
>> + int node_offset;
>> - for (child = rtems_ofw_child(node); child != 0; child =
>> rtems_ofw_peer(child)) {
>> - ref = rtems_ofw_get_effective_phandle(child, xref);
>> - if (ref != -1)
>> - return ref;
>> + node_offset = fdt_path_offset(fdtp, "/");
>> + while ((node_offset = fdt_next_node(fdtp, node_offset, NULL)) > 0) {
>> + child = rtems_fdt_offset_to_phandle(node_offset);
>> Assuming this works, it is much better now :) Thanks.
Yes, it does. I checked it by creating a small test outside of RTEMS using
real DTB
files (Rpi.dtb and Beagle.dtb). I basically mmap the dtb file and
initialize fdtp with the
mapped address, and use this with libFDT and ofw.c to test and debug. This
creates
a much easier env to work with. Finally, when satisfied with the results I
test them
on real hardware.
Thanks,
Niteesh.
>> if (rtems_ofw_get_enc_prop(child, "phandle", &ref, sizeof(ref)) ==
>> -1 &&
>> rtems_ofw_get_enc_prop(child, "ibm,phandle", &ref, sizeof(ref))
>> == -1 &&
>> 2.17.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210206/e9b1e2bf/attachment.html>
