[PATCH v2 2/4] bsps/shared/ofw: Use strlcpy instead of strncpy
G S Niteesh Babu
niteesh.gs at gmail.com
Sat Feb 6 17:40:10 UTC 2021
Changed rtems_ofw_get_prop to use strlcpy instead of strncpy
to ensure the buffer is null terminated incase of overflow.
bsps/shared/ofw/ofw.c | 10 +++++++++-
1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/bsps/shared/ofw/ofw.c b/bsps/shared/ofw/ofw.c
index fa94bfbf05..886ad0252b 100644
--- a/bsps/shared/ofw/ofw.c
+++ b/bsps/shared/ofw/ofw.c
@@ -198,7 +198,15 @@ ssize_t rtems_ofw_get_prop(
if (prop == NULL && strcmp(propname, "name") == 0) {
prop = fdt_get_name(fdtp, offset, &len);
- strncpy(buf, prop, bufsize);
+ /* Node name's are 1-31 chars in length consisting of only
+ * ascii chars and are null terminated */
+ strlcpy(buf, prop, bufsize);
+ /* Return the length of the name including the null byte
+ * rather than the amount copied.
+ * This is the behaviour in libBSD ofw_fdt_getprop
return len + 1;
2.17.1
