[PATCH] powerpc/shared: ISA bus bridge fails to enable the openpic irq
Joel Sherrill
joel at rtems.org
Sat Feb 6 22:42:10 UTC 2021
On Sat, Feb 6, 2021, 2:09 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> - The call to enable the openpic irq for the ISA bridge falls
> because the IRQ used is offset by the ISA bus signals and
> the openpic call expects an IRA relative to it's signals.
Falls to fails
What's IRA
And its not it's
> - Add the MVME 2600/2700 to the list is an ISA bridge.
> Closes #4231
> bsps/powerpc/shared/irq/irq_init.c | 2 +-
> bsps/powerpc/shared/irq/openpic_i8259_irq.c | 2 +-
> 2 files changed, 2 insertions(+), 2 deletions(-)
> diff --git a/bsps/powerpc/shared/irq/irq_init.c
> b/bsps/powerpc/shared/irq/irq_init.c
> index 1a44992a5b..1042c9d1a8 100644
> --- a/bsps/powerpc/shared/irq/irq_init.c
> +++ b/bsps/powerpc/shared/irq/irq_init.c
> @@ -310,7 +310,7 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
> #endif
> known_cpi_isa_bridge = 1;
> - if ( currentBoard == MVME_2300 ) {
> + if ( currentBoard == MVME_2300 || currentBoard ==
> MVME_2600_2700_W_MVME761 ) {
> /* nothing to do for W83C553 bridge */
> diff --git a/bsps/powerpc/shared/irq/openpic_i8259_irq.c
> b/bsps/powerpc/shared/irq/openpic_i8259_irq.c
> index 4a9c393f7f..513b9ac3e0 100644
> --- a/bsps/powerpc/shared/irq/openpic_i8259_irq.c
> +++ b/bsps/powerpc/shared/irq/openpic_i8259_irq.c
> @@ -214,7 +214,7 @@ int BSP_setup_the_pic(rtems_irq_global_settings*
> config)
> * Must enable PCI/ISA bridge IRQ
> - openpic_enable_irq (BSP_PCI_ISA_BRIDGE_IRQ);
> + openpic_enable_irq (BSP_PCI_ISA_BRIDGE_IRQ -
> BSP_PCI_IRQ_LOWEST_OFFSET);
> #endif
> #endif
I think the patch itself is ok to commit. It would be good to know that it
doesn't negatively impact other BSPs with openpic and i8259. Which other
BSPs use this code?
And does this mean that no bsp with openpic and i8259 had working ISA
interrupts?
--joel
> 2.27.0
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210206/9a694520/attachment-0001.html>
