[RTEMS 5 PATCH] powerpc/shared: ISA bus bridge fails to enable the openpic irq
    chrisj at rtems.org
    chrisj at rtems.org
    Sun Feb  7 22:33:43 UTC 2021
- The call to enable the openpic irq for the ISA bridge falls
  because the IRQ used is offset by the ISA bus signals and
  the openpic call expects an IRA relative to it's signals.
- Add the MVME 2600/2700 to the list is an ISA bridge.
Closes #4233
 bsps/powerpc/shared/irq/irq_init.c          | 2 +-
 bsps/powerpc/shared/irq/openpic_i8259_irq.c | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/bsps/powerpc/shared/irq/irq_init.c b/bsps/powerpc/shared/irq/irq_init.c
index 1a44992a5b..1042c9d1a8 100644
--- a/bsps/powerpc/shared/irq/irq_init.c
+++ b/bsps/powerpc/shared/irq/irq_init.c
@@ -310,7 +310,7 @@ void BSP_rtems_irq_mng_init(unsigned cpuId)
 #endif
     known_cpi_isa_bridge = 1;
-  if ( currentBoard == MVME_2300 ) {
+  if ( currentBoard == MVME_2300 || currentBoard == MVME_2600_2700_W_MVME761 ) {
     /* nothing to do for W83C553 bridge */
diff --git a/bsps/powerpc/shared/irq/openpic_i8259_irq.c b/bsps/powerpc/shared/irq/openpic_i8259_irq.c
index 4a9c393f7f..513b9ac3e0 100644
--- a/bsps/powerpc/shared/irq/openpic_i8259_irq.c
+++ b/bsps/powerpc/shared/irq/openpic_i8259_irq.c
@@ -214,7 +214,7 @@ int BSP_setup_the_pic(rtems_irq_global_settings* config)
      * Must enable PCI/ISA bridge IRQ
-   	openpic_enable_irq (BSP_PCI_ISA_BRIDGE_IRQ);
+    openpic_enable_irq (BSP_PCI_ISA_BRIDGE_IRQ - BSP_PCI_IRQ_LOWEST_OFFSET);
 #endif
 #endif
2.24.1
