test for rtems_workspace_greedy_allocate
Chris Johns
chrisj at rtems.org
Mon Feb 8 03:41:06 UTC 2021
Hello,
I see the call `rtems_workspace_greedy_allocate` is in `src/rtems` and publicly
available via the installed header file `rtems/support.h`.
Are there tests for this and similar support calls?
I ask because tests in rtems.git and rtems-libbsd.git testsuites depend on this
call and it appears to be broken on psim and PowerPC hardware. Recent psim test
results from Joel show `spprivenv01.exe` failing and I think it is
`rtems_workspace_greedy_allocate` or friends that maybe the issue ..
https://lists.rtems.org/pipermail/build/2021-February/025169.html
Thanks
