[PATCH 3/4] bsp/riscv: work area size based on stack pointer
Daniel Hellstrom
daniel at gaisler.com
Mon Feb 8 19:44:14 UTC 2021
Remember the initial stack pointer in start.S. It can later be used to
determine top of RAM.
bsps/riscv/shared/start/bspgetworkarea-fromstack.c | 55 ++++++++++++++++++++++
bsps/riscv/shared/start/start.S | 15 ++++++
2 files changed, 70 insertions(+)
create mode 100644 bsps/riscv/shared/start/bspgetworkarea-fromstack.c
diff --git a/bsps/riscv/shared/start/bspgetworkarea-fromstack.c b/bsps/riscv/shared/start/bspgetworkarea-fromstack.c
new file mode 100644
index 0000000..b8a915e
--- /dev/null
+++ b/bsps/riscv/shared/start/bspgetworkarea-fromstack.c
@@ -0,0 +1,55 @@
+ * This set of routines are the BSP specific initialization
+ * support routines.
+ * COPYRIGHT (c) 1989-2020.
+ * On-Line Applications Research Corporation (OAR),
+ * Cobham Gaisler AB.
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#include <rtems/sysinit.h>
+ * These are provided by the linkcmds for ALL of the BSPs which use this file.
+extern char WorkAreaBase[];
+extern char RamEnd[];
+/* Set by BSP early start code. */
+extern uintptr_t bsp_sp_at_entry;
+static Memory_Area _Memory_Areas[ 1 ];
+static void bsp_memory_initialize( void )
+ char *end;
+ /* top of RAM inidicated by initial stack pointer */
+ end = (char *) bsp_sp_at_entry;
+ if (end == 0) {
+ /* fall back to linker symbol if not set */
+ end = RamEnd;
+ _Memory_Initialize( &_Memory_Areas[ 0 ], WorkAreaBase, end );
+RTEMS_SYSINIT_ITEM(
+ bsp_memory_initialize,
+ RTEMS_SYSINIT_MEMORY,
+ RTEMS_SYSINIT_ORDER_MIDDLE
+static const Memory_Information _Memory_Information =
+ MEMORY_INFORMATION_INITIALIZER( _Memory_Areas );
+const Memory_Information *_Memory_Get( void )
+ return &_Memory_Information;
diff --git a/bsps/riscv/shared/start/start.S b/bsps/riscv/shared/start/start.S
index 04a62a2..0bb5ddb 100644
--- a/bsps/riscv/shared/start/start.S
+++ b/bsps/riscv/shared/start/start.S
@@ -59,6 +59,9 @@ SYM(_start):
LADDR t0, _RISCV_Exception_handler
csrw mtvec, t0
+ /* Save stack pointer so it can mark end of work area later on */
+ mv t3, sp
/* Load stack pointer and branch to secondary processor start if necessary */
#ifdef RTEMS_SMP
LADDR sp, _ISR_Stack_area_begin
@@ -74,6 +77,9 @@ SYM(_start):
LADDR sp, _ISR_Stack_area_end
#endif
+ LADDR t0, bsp_sp_at_entry
+ SREG t3, 0(t0)
#ifdef BSP_START_COPY_FDT_FROM_U_BOOT
mv a0, a1
call bsp_fdt_copy
@@ -145,3 +151,12 @@ SYM(_start):
#endif
#endif /* RTEMS_SMP */
+ .section .data, "aw"
+ .align 3
+ .globl bsp_sp_at_entry
+ .type bsp_sp_at_entry, @object
+ .size bsp_sp_at_entry, 8
+bsp_sp_at_entry:
+ .dword 0
2.7.4
