Getting an error after a test ends
Richi Dubey richidubey at gmail.com
Tue Feb 9 08:29:39 UTC 2021
Thanks for your prompt response.
When I ran rtems-test for the WIP Strong APA, it showed a failure for
smpfatal04, whereas on debugging I see the failure after the END OF TEST.
I'll try running rtems-test again.
On Mon, Feb 8, 2021 at 11:07 AM Sebastian Huber <
> On 08/02/2021 06:08, Richi Dubey wrote:
> > On checking docs, I saw that SMP Fatal Code 0 points
> > to SMP_FATAL_BOOT_PROCESSOR_NOT_ASSIGNED_TO_SCHEDULER. This error is
> > thrown after the end of the test, so should I worry about it? -
> > Because rtems-tester said that this test fails.
> I don't see an rtems-test failure:
> Passed:        616
> Failed:          3
> User Input:      6
> Expected Fail:   0
> Indeterminate:   0
> Benchmark:       3
> Timeout:         0
> Test too long:   0
> Invalid:         0
> Wrong Version:   0
> Wrong Build:     0
> Wrong Tools:     0
> Total:         628
> Failures:
>   dl06.exe
>   minimum.exe
>   smpirqs01.exe
> User Input:
>   dl10.exe
>   monitor.exe
>   termios.exe
>   top.exe
>   fileio.exe
>   capture.exe
> Benchmark:
>   dhrystone.exe
>   linpack.exe
>   whetstone.exe
> Average test time: 0:00:00.090734
> Testing time     : 0:00:56.980887
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20210209/a94c6920/attachment.html>
