[PATCH 3/8] c-user: Clarify partition manager documentation
Sebastian Huber
Tue Feb 9 09:43:23 UTC 2021
c-user/partition/directives.rst | 6 ++++++
1 file changed, 6 insertions(+)
diff --git a/c-user/partition/directives.rst b/c-user/partition/directives.rst
index 0d35136..2340409 100644
--- a/c-user/partition/directives.rst
+++ b/c-user/partition/directives.rst
@@ -191,6 +191,9 @@ The following constraints apply to this directive:
* The directive may obtain and release the object allocator mutex. This may
cause the calling task to be preempted.
+* When the directive operates on a global object, the directive sends a message
+ to remote nodes. This may preempt the calling task.
* The number of partitions available to the application is configured through
the :ref:`CONFIGURE_MAXIMUM_PARTITIONS` application configuration option.
@@ -374,6 +377,9 @@ The following constraints apply to this directive:
* The calling task does not have to be the task that created the object. Any
local task that knows the object identifier can delete the object.
2.26.2
