[PATCH 0/8] Generate documentation for managers
Sebastian Huber
Tue Feb 9 09:43:20 UTC 2021
This patch adds the next round of generated documentation. Patches 1 to
3 try to unify the documentation accross managers. The other patches
add the generated documentation for the Semaphore, Barrier, and User
Extensions Managers.
Here is the updated document for review:
https://ftp.rtems.org/pub/rtems/people/sebh/c-user.pdf
Sebastian Huber (8):
c-user: Clarify timer manager documentation
c-user: Clarify event manager documentation
c-user: Clarify partition manager documentation
c-user: Add labels to the manager chapters
c-user: Add control block acronyms
c-user: Generate semaphore manager documentation
c-user: Generate barrier manager documentation
c-user: Generate user extensions manager docs
c-user/barrier/directives.rst | 569 +++++----
c-user/barrier/index.rst | 2 +
c-user/barrier/introduction.rst | 45 +-
c-user/board_support_packages.rst | 2 +-
c-user/clock/index.rst | 2 +
c-user/config/scheduler-general.rst | 2 +-
c-user/dual-ported-memory/index.rst | 2 +
c-user/event/directives.rst | 60 +-
c-user/event/index.rst | 2 +
c-user/event/introduction.rst | 2 +-
c-user/glossary.rst | 14 +-
c-user/interrupt/index.rst | 2 +
c-user/io/index.rst | 2 +
c-user/message/index.rst | 2 +
c-user/object-services/index.rst | 2 +
c-user/partition/directives.rst | 6 +
c-user/partition/index.rst | 2 +
c-user/rate-monotonic/index.rst | 2 +
c-user/region/index.rst | 2 +
c-user/scheduling-concepts/index.rst | 2 +-
c-user/semaphore/directives.rst | 1485 ++++++++++++++---------
c-user/semaphore/index.rst | 2 +
c-user/semaphore/introduction.rst | 52 +-
c-user/signal/index.rst | 2 +
c-user/task/index.rst | 2 +
c-user/timer/directives.rst | 198 ++-
c-user/timer/index.rst | 2 +
c-user/timer/introduction.rst | 2 +-
c-user/user-extensions/directives.rst | 326 +++--
c-user/user-extensions/index.rst | 2 +-
c-user/user-extensions/introduction.rst | 36 +-
31 files changed, 1865 insertions(+), 968 deletions(-)
2.26.2
